[geos-commits] [SCM] GEOS branch main updated. ad2d66fb863fdfdc213dc6f07d8349e839bf801d
Tue Jul 14 10:54:15 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  ad2d66fb863fdfdc213dc6f07d8349e839bf801d (commit)
      from  1d559c659e0862d5e4ff738391a9258d048d68b9 (commit)
revisions in full, below.
commit ad2d66fb863fdfdc213dc6f07d8349e839bf801d
Author: Daniel Baston <dbaston at gmail.com>
Date:   Tue Jul 14 13:53:53 2026 -0400
    XMLTester: add --test-index and --case-index arguments (#1477)
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index 3e4aac3a0..c493890de 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -419,11 +419,17 @@ XMLTester::parseRun(const tinyxml2::XMLNode* node)
     wkbwriter.reset(new io::WKBWriter());
     const tinyxml2::XMLNode* casenode;
+    int icase = 1;
     for(casenode = node->FirstChildElement("case");
             casenode;
             casenode = casenode->NextSiblingElement("case")) {
         try {
-            parseCase(casenode);
+            if (caseNum == 0 || icase == caseNum) {
+                parseCase(casenode);
+            icase++;
         catch(const std::exception& exc) {
             std::cerr << exc.what() << std::endl;
@@ -592,12 +598,16 @@ XMLTester::parseCase(const tinyxml2::XMLNode* node)
     ++caseCount;
     testCount = 0;
+    int itest = 1;
     const tinyxml2::XMLNode* testnode;
     for(testnode = node->FirstChildElement("test");
             testnode;
             testnode = testnode->NextSiblingElement("test")) {
-       runTest(testnode);
+        if (testNum == 0 || itest == testNum) {
+            runTest(testnode);
+        itest++;
     totalTestCount += testCount;
@@ -1426,7 +1436,9 @@ usage(char* me, int exitcode, std::ostream& os)
        << "--test-valid-output  Test output validity" << std::endl
        << "--test-valid-input   Test input validity" << std::endl
        << "--sql-output         Produce SQL output" << std::endl
-       << "--wkb-output         Print Geometries as HEXWKB" << std::endl;
+       << "--wkb-output         Print Geometries as HEXWKB" << std::endl
+       << "--case-index [n]     Run only the specified case number (1-indexed)" << std::endl
+       << "--test-index [n]     Run only the specified test number (1-indexed)" << std::endl;
     std::exit(exitcode);
@@ -1482,6 +1494,16 @@ main(int argC, char* argV[])
                 tester.setTestInputValidity(true);
                 continue;
+            if (!std::strcmp(argV[i], "--case-index")) {
+                int caseNum = std::atoi(argV[++i]);
+                tester.setCaseNumber(caseNum);
+                continue;
+            if (!std::strcmp(argV[i], "--test-index")) {
+                int opNum = std::atoi(argV[++i]);
+                tester.setTestNumber(opNum);
+                continue;
             std::string source = argV[i];
diff --git a/tests/xmltester/XMLTester.h b/tests/xmltester/XMLTester.h
index 4a10b9fb1..170bb5d18 100644
--- a/tests/xmltester/XMLTester.h
+++ b/tests/xmltester/XMLTester.h
@@ -56,6 +56,9 @@ private:
     int testFileCount;
     int totalTestCount;
+    int caseNum = 0;
+    int testNum = 0;
     const std::string* curr_file;
     std::string curr_case_desc;
@@ -89,6 +92,14 @@ public:
     int setVerbosityLevel(int val);
+    void setCaseNumber(int num) {
+        caseNum = num;
+    void setTestNumber(int num) {
+        testNum = num;
     void setTestOutputValidity(bool val)
         testValidOutput = val;
Summary of changes:
 tests/xmltester/XMLTester.cpp | 28 +++++++++++++++++++++++++---
 tests/xmltester/XMLTester.h   | 11 +++++++++++
 2 files changed, 36 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
