[geos-commits] [SCM] GEOS branch main updated. 2a5ce498a499916cf9b8e3c830b3e644d03f2c9f
git at osgeo.org
git at osgeo.org
Wed Jul 15 06:19:30 PDT 2026
the project "GEOS".
The branch, main has been updated
via 2a5ce498a499916cf9b8e3c830b3e644d03f2c9f (commit)
from fdc70563162eb1784929c68263f4ad67ce809761 (commit)
revisions in full, below.
commit 2a5ce498a499916cf9b8e3c830b3e644d03f2c9f
Author: Daniel Baston <dbaston at gmail.com>
Date: Wed Jul 15 09:19:04 2026 -0400
RayCrossingCounter: Fix some incorrect results for curved geometries (#1479)
diff --git a/include/geos/geom/CircularArc.h b/include/geos/geom/CircularArc.h
index a2a4dd151..86f2b2c23 100644
--- a/include/geos/geom/CircularArc.h
+++ b/include/geos/geom/CircularArc.h
@@ -209,11 +209,6 @@ public:
double distance(const CoordinateXY& p1, const CoordinateXY& p2) const;
double distance(const CircularArc& other) const;
- /// Return true if the arc is pointing positive in the y direction
- /// at the location of a specified point. The point is assumed to
- /// be on the arc.
- bool isUpwardAtPoint(const CoordinateXY& q) const;
CircularArc reverse() const;
// Split an arc at a specified point.
diff --git a/src/algorithm/RayCrossingCounter.cpp b/src/algorithm/RayCrossingCounter.cpp
index 3d212beb6..7377d11c7 100644
--- a/src/algorithm/RayCrossingCounter.cpp
+++ b/src/algorithm/RayCrossingCounter.cpp
@@ -102,7 +102,7 @@ RayCrossingCounter::processSequence(const geom::CoordinateSequence& seq, bool is
if (isLinear) {
for(std::size_t i = 1; i < seq.size(); i++) {
- const geom::CoordinateXY& p1 = seq.getAt<geom::CoordinateXY>(i-1);;
+ const geom::CoordinateXY& p1 = seq.getAt<geom::CoordinateXY>(i-1);
const geom::CoordinateXY& p2 = seq.getAt<geom::CoordinateXY>(i);
countSegment(p1, p2);
@@ -190,21 +190,34 @@ RayCrossingCounter::countSegment(const geom::CoordinateXY& p1,
bool
RayCrossingCounter::shouldCountCrossing(const geom::CircularArc& arc, const geom::CoordinateXY& q) {
+ const auto& c = arc.getCenter();
// To avoid double-counting shared vertices, we count an intersection point if
// a) is in the interior of the arc
// b) is at the starting point of the arc, and the arc is directed upward at that point
// c) is at the ending point of the arc is directed downward at that point
if (q.equals2D(arc.p0())) {
- return arc.isUpwardAtPoint(q);
+ if (arc.isCCW()) {
+ return q.x > c.x || (q.x == c.x && q.y < c.y);
+ } else {
+ return q.x < c.x || (q.x == c.x && q.y < c.y);
} else if (q.equals2D(arc.p2())) {
- return !arc.isUpwardAtPoint(q);
+ } else {
} else {
- return true;
+ // Ignore rays tangent to the arc interior. This is topologically equivalent
+ // to the ray intersecting adjacent upward and downward segments, which would
+ // cancel out.
+ return q.x != arc.getCenter().x;
-/// Return an array of 0-2 intersection points between an arc and a horizontal
-/// ray extending righward from a point. If fewer than 2 intersection points exist,
+/// Return an array of 0-2 unique intersection points between an arc and a horizontal
+/// ray extending rightward from a point. If fewer than 2 intersection points exist,
/// some Coordinates in the returned array will be equal to CoordinateXY::getNull().
std::array<geom::CoordinateXY, 2>
RayCrossingCounter::pointsIntersectingHorizontalRay(const geom::CircularArc& arc, const geom::CoordinateXY& origin) {
@@ -241,7 +254,7 @@ RayCrossingCounter::pointsIntersectingHorizontalRay(const geom::CircularArc& arc
if (intPt1.x >= origin.x && arc.containsPointOnCircle(intPt1)) {
ret[pos++] = intPt1;
- if (intPt2.x >= origin.x && arc.containsPointOnCircle(intPt2)) {
+ if (intPt2 != intPt1 && intPt2.x >= origin.x && arc.containsPointOnCircle(intPt2)) {
ret[pos++] = intPt2;
@@ -270,7 +283,7 @@ RayCrossingCounter::countArc(const geom::CircularArc& arc)
return;
- // Evaluate all arcs whose enveleope is to the right of the test point.
+ // Evaluate all arcs whose envelope is to the right of the test point.
if (arcEnvelope.getMaxY() >= point.y && arcEnvelope.getMinY() <= point.y) {
if (arc.containsPoint(point)) {
isPointOnSegment = true;
diff --git a/src/geom/CircularArc.cpp b/src/geom/CircularArc.cpp
index 038fd1d18..44414c0ad 100644
--- a/src/geom/CircularArc.cpp
+++ b/src/geom/CircularArc.cpp
@@ -393,21 +393,6 @@ CircularArc::addLinearizedPoints(CoordinateSequence& seq, const algorithm::Curve
seq.add(*getCoordinateSequence(), getCoordinatePosition() + 2, getCoordinatePosition() + 2);
-bool
-CircularArc::isUpwardAtPoint(const CoordinateXY& q) const
- auto quad = geom::Quadrant::quadrant(getCenter(), q);
- bool isUpward;
- if (getOrientation() == algorithm::Orientation::CLOCKWISE) {
- isUpward = (quad == geom::Quadrant::SW || quad == geom::Quadrant::NW);
- } else {
- isUpward = (quad == geom::Quadrant::SE || quad == geom::Quadrant::NE);
- return isUpward;
CircularArc
CircularArc::reverse() const
diff --git a/tests/unit/algorithm/LocatePointInRingTest.cpp b/tests/unit/algorithm/LocatePointInRingTest.cpp
index 1a70b9d15..aed2943a5 100644
--- a/tests/unit/algorithm/LocatePointInRingTest.cpp
+++ b/tests/unit/algorithm/LocatePointInRingTest.cpp
@@ -295,6 +295,71 @@ void object::test<12>()
runPtLocator(Location::BOUNDARY, CoordinateXY(11.230120879533454, 62.84897119848748), wkt);
+template<>
+template<>
+void object::test<13>()
+ std::string wkt = "CURVEPOLYGON(COMPOUNDCURVE ("
+ "(220 140, 60 140, 60 260, 220 240),"
+ "CIRCULARSTRING (220 240, 230 230, 220 220, 190 230, 160 220, 155 210, 160 200, 174.18861169915812 207.4341649025257, 190 210),"
+ "(190 210, 190 180, 160 180, 160 160, 220 160, 220 140)))";
+ for (int y = 195; y <= 245; y++) {
+ runPtLocator(Location::INTERIOR, {80, static_cast<double>(y)}, wkt);
+template<>
+template<>
+void object::test<14>()
+ std::string wkt = "CURVEPOLYGON(COMPOUNDCURVE ((-10 100, 0 110, 10 100), CIRCULARSTRING (10 100, 35 75, 10 50, 35 25, 10 0), (10 0, 0 -10, -10 0), CIRCULARSTRING (-10 0, -35 25, -10 50, -35 75, -10 100)))";
+ runPtLocator(Location::EXTERIOR, {-20, 0}, wkt);
+ runPtLocator(Location::INTERIOR, {0, 0}, wkt);
+ runPtLocator(Location::EXTERIOR, {-20, 50}, wkt);
+ runPtLocator(Location::INTERIOR, {0, 50}, wkt);
+ runPtLocator(Location::EXTERIOR, {-20, 100}, wkt);
+ runPtLocator(Location::INTERIOR, {0, 100}, wkt);
+template<>
+template<>
+void object::test<15>()
+ std::string wkt = "CURVEPOLYGON(COMPOUNDCURVE (CIRCULARSTRING(0 0, 10 10, 20 0), (20 0, 30 10, 40 0), CIRCULARSTRING (40 0, 50 -10, 60 0), (60 0, 70 -10, 80 0), CIRCULARSTRING (80 0, 70 10, 80 20), (80 20, 100 20), CIRCULARSTRING (100 20, 120 0, 100 -20), (100 -20, 100 0), CIRCULARSTRING (100 0, 50 -50, 0 0)))";
+ // scanline at y = 0
+ runPtLocator(Location::EXTERIOR, {-10, 0}, wkt);
+ runPtLocator(Location::INTERIOR, {10, 0}, wkt);
+ runPtLocator(Location::INTERIOR, {30, 0}, wkt);
+ runPtLocator(Location::EXTERIOR, {50, 0}, wkt);
+ runPtLocator(Location::EXTERIOR, {70, 0}, wkt);
+ runPtLocator(Location::INTERIOR, {90, 0}, wkt);
+ runPtLocator(Location::INTERIOR, {110, 0}, wkt);
+ runPtLocator(Location::EXTERIOR, {130, 0}, wkt);
+ // scanline at y = 5
+ runPtLocator(Location::EXTERIOR, {0, 5}, wkt);
+ runPtLocator(Location::INTERIOR, {10, 5}, wkt);
+ runPtLocator(Location::EXTERIOR, {20, 5}, wkt);
+ runPtLocator(Location::INTERIOR, {30, 5}, wkt);
+ runPtLocator(Location::EXTERIOR, {40, 5}, wkt);
+ runPtLocator(Location::EXTERIOR, {50, 5}, wkt);
+ runPtLocator(Location::EXTERIOR, {60, 5}, wkt);
+ runPtLocator(Location::EXTERIOR, {70, 5}, wkt);
+ runPtLocator(Location::INTERIOR, {75, 5}, wkt);
+ runPtLocator(Location::INTERIOR, {80, 5}, wkt);
+ runPtLocator(Location::INTERIOR, {100, 5}, wkt);
+ runPtLocator(Location::INTERIOR, {110, 5}, wkt);
+ runPtLocator(Location::EXTERIOR, {120, 5}, wkt);
+ runPtLocator(Location::EXTERIOR, {125, 5}, wkt);
} // namespace tut
diff --git a/tests/unit/algorithm/locate/SimplePointInAreaLocatorTest.cpp b/tests/unit/algorithm/locate/SimplePointInAreaLocatorTest.cpp
index 0330c1fed..798df3ca6 100644
--- a/tests/unit/algorithm/locate/SimplePointInAreaLocatorTest.cpp
+++ b/tests/unit/algorithm/locate/SimplePointInAreaLocatorTest.cpp
@@ -37,7 +37,6 @@ void object::test<1>()
checkLocation(*g, {1, 1}, Location::BOUNDARY); // vertex of hole
checkLocation(*g, {2, 1}, Location::BOUNDARY); // boundary of hole
checkLocation(*g, {2.5, 1.5}, Location::EXTERIOR); // inside hole
Summary of changes:
include/geos/geom/CircularArc.h | 5 --
src/algorithm/RayCrossingCounter.cpp | 29 +++++++---
src/geom/CircularArc.cpp | 15 -----
tests/unit/algorithm/LocatePointInRingTest.cpp | 65 ++++++++++++++++++++++
.../locate/SimplePointInAreaLocatorTest.cpp | 1 -
5 files changed, 86 insertions(+), 29 deletions(-)
hooks/post-receive
More information about the geos-commits
