[geos-commits] [SCM] GEOS branch main updated. 7b2e578f4444678aa081af6c484266ed2f6392bc
Tue Jun 9 10:52:16 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  7b2e578f4444678aa081af6c484266ed2f6392bc (commit)
      from  e704204f34c95c24bfc3a8493c5cda2cbe3fe1c2 (commit)
revisions in full, below.
commit 7b2e578f4444678aa081af6c484266ed2f6392bc
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Jun 9 17:51:39 2026 +0000
    Add Arc distance test case from PostGIS
diff --git a/tests/unit/operation/distance/DistanceOpTest.cpp b/tests/unit/operation/distance/DistanceOpTest.cpp
index 7c2686773..082c91916 100644
--- a/tests/unit/operation/distance/DistanceOpTest.cpp
+++ b/tests/unit/operation/distance/DistanceOpTest.cpp
@@ -1003,6 +1003,18 @@ void object::test<51>()
     checkDistance(*g1, *g2, 0.5, 1e-6);
+template<>
+template<>
+void object::test<52>()
+    set_test_name("MultiSurface COMPOUNDCURVE and Polygon; PostGIS ticket #5989 reopened (Finnish coordinates)");
+    auto g1 = wktreader.read("MULTISURFACE(CURVEPOLYGON(COMPOUNDCURVE(CIRCULARSTRING(25493681.3085 6678739.6419,25493637.8256 6678776.2541,25493599.9716 6678818.6604),(25493599.9716 6678818.6604,25493583.8816 6678839.494,25493590.9591 6678844.9594,25493566.9698 6678851.9051,25493526.5793 6678861.0985,25493487.3853 6678868.2546,25493447.392 6678871.7846,25493429.5033 6678876.6846,25493435.0147 6678857.4594,25493454.9254 6678821.6192,25493452.4867 6678816.1292,25493402.3226 6678828.2153,25493354.7526 6678837.8291,25493349.0217 6678838.9873,25493310.914 6678843.6926,25493306.3784 6678859.9295,25493294.1011 6678858.7864,25493169.9028 6678847.2212,25493127.549 6678843.2773,25493057.8888 6678834.6763,25493017.4547 6678826.7261,25492928.2395 6678821.5524,25492909.1067 6678795.0681,25492946.9544 6678794.8193,25492967.1292 6678794.6866,25493010.8878 6678795.9163,25493111.5564 6678804.3109,25493113.4069 6678799.5694,25493134.2375 6678806.0729),CIRCULARSTRING(25493134.2375 6678806.0729,2549322
 3.038 6678812.0533,25493311.4919 6678802.1948,25493317.3589 6678800.9679,25493323.2107 6678799.6707),(25493323.2107 6678799.6707,25493362.6615 6678792.3924,25493364.6948 6678785.173,25493375.0512 6678781.6008,25493404.9736 6678771.2798),CIRCULARSTRING(25493404.9736 6678771.2798,25493486.8049 6678737.6728,25493566.8862 6678700.0859),(25493566.8862 6678700.0859,25493574.903 6678714.0761,25493600.2214 6678702.8803,25493654.1114 6678670.2493,25493669.7219 6678659.2147,25493677.0288 6678653.353,25493684.6468 6678648.4119,25493724.0447 6678623.7638,25493800.1925 6678583.5847,25493805.6261 6678586.1292,25493811.9258 6678582.3016,25493812.8413 6678583.0522,25493846.581 6678558.6541,25493884.2653 6678531.6272,25493900.9168 6678580.1258,25493830.7852 6678630.9518,25493789.0848 6678661.2736,25493746.1612 6678692.485,25493686.5413 6678735.8369,25493681.3085 6678739.6419))))");
+    auto g2 = wktreader.read("POLYGON ((25492929.752797972 6678919.124091367,25493008.675235115 6678876.783133076,25493098.02917443 6678854.33589699,25493139.669701554 6678977.913508233,25493122.946292613 6679011.427315322,25493050.53388224 6679068.791126598,25493140.33593199 6679140.958135231,25492931.688606273 6679401.2946243705,25492799.289171 6679295.949040241,25492651.5177725 6679115.144800108,25492929.752797972 6678919.124091367))");
+    checkDistance(*g1, *g2, 14.5, 1.0);
 // TODO: finish the tests by adding:
 // 	LINESTRING - *all*
Summary of changes:
 tests/unit/operation/distance/DistanceOpTest.cpp | 12 ++++++++++++
 1 file changed, 12 insertions(+)
hooks/post-receive
More information about the geos-commits mailing list
