[geos-commits] [SCM] GEOS branch main updated. 9d1676ca58c6878445b679d6b3228b96fab7d4e4
Wed Jun 10 00:25:45 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  9d1676ca58c6878445b679d6b3228b96fab7d4e4 (commit)
      from  7b2e578f4444678aa081af6c484266ed2f6392bc (commit)
revisions in full, below.
commit 9d1676ca58c6878445b679d6b3228b96fab7d4e4
Author: dependabot[bot] <49699333+dependabot[bot]@users.noreply.github.com>
Date:   Wed Jun 10 09:25:14 2026 +0200
    Bump the all-actions group across 1 directory with 4 updates (#1443)
    Bumps the all-actions group with 4 updates in the / directory: [actions/checkout](https://github.com/actions/checkout), [vmactions/freebsd-vm](https://github.com/vmactions/freebsd-vm), [github/codeql-action](https://github.com/github/codeql-action) and [softprops/action-gh-release](https://github.com/softprops/action-gh-release).
    Updates `actions/checkout` from 6 to 6.0.2
    - [Release notes](https://github.com/actions/checkout/releases)
    - [Changelog](https://github.com/actions/checkout/blob/main/CHANGELOG.md)
    - [Commits](https://github.com/actions/checkout/compare/v6...v6.0.2)
    Updates `vmactions/freebsd-vm` from 1 to 1.4.5
    - [Release notes](https://github.com/vmactions/freebsd-vm/releases)
    - [Commits](https://github.com/vmactions/freebsd-vm/compare/v1...v1.4.5)
    Updates `github/codeql-action` from 4 to 4.36.0
    - [Release notes](https://github.com/github/codeql-action/releases)
    - [Changelog](https://github.com/github/codeql-action/blob/main/CHANGELOG.md)
    - [Commits](https://github.com/github/codeql-action/compare/v4...v4.36.0)
    Updates `softprops/action-gh-release` from 2 to 3
    - [Release notes](https://github.com/softprops/action-gh-release/releases)
    - [Changelog](https://github.com/softprops/action-gh-release/blob/master/CHANGELOG.md)
    - [Commits](https://github.com/softprops/action-gh-release/compare/v2...v3)
    updated-dependencies:
    - dependency-name: actions/checkout
      dependency-version: 6.0.2
      dependency-type: direct:production
      update-type: version-update:semver-patch
      dependency-group: all-actions
    - dependency-name: vmactions/freebsd-vm
      dependency-version: 1.4.5
      update-type: version-update:semver-minor
    - dependency-name: github/codeql-action
      dependency-version: 4.36.0
    - dependency-name: softprops/action-gh-release
      dependency-version: '3'
      update-type: version-update:semver-major
    Signed-off-by: dependabot[bot] <support at github.com>
    Co-authored-by: dependabot[bot] <49699333+dependabot[bot]@users.noreply.github.com>
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 232969889..5f7a5e237 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -197,7 +197,7 @@ jobs:
         python3 -m pip install --disable-pip-version-check --user cmake==${{ matrix.ci.cmake }}
         echo "$(python3 -m site --user-base)/bin" >> $GITHUB_PATH
-    - uses: actions/checkout at v6
+    - uses: actions/checkout at v6.0.2
     - name: Retrieve build cache
       uses: actions/cache/restore at v5
@@ -281,7 +281,7 @@ jobs:
         build_type: ['Debug', 'Release']
     steps:
     - name: 'Setup'
       uses: msys2/setup-msys2 at v2
@@ -337,7 +337,7 @@ jobs:
             arch: arm64
     steps:
     # ccache not supported for this generator and/or Debug
@@ -378,7 +378,7 @@ jobs:
     runs-on: ${{ matrix.ci.os }}
     steps:
@@ -459,7 +459,7 @@ jobs:
         which clang++
         clang++ --version
@@ -495,7 +495,7 @@ jobs:
     runs-on: ubuntu-latest
     steps:
@@ -506,7 +506,7 @@ jobs:
         restore-keys: freebsd
     - name: Build and test
-      uses: vmactions/freebsd-vm at v1
+      uses: vmactions/freebsd-vm at v1.4.5
       with:
         release: "15.0"
         envs: CCACHE_COMPRESS CCACHE_COMPRESSLEVEL CCACHE_MAXSIZE
@@ -540,7 +540,7 @@ jobs:
         sudo -E apt-get autopurge -y needrestart
         sudo -E apt-get -yq --no-install-suggests --no-install-recommends install make cmake emscripten ccache
@@ -582,7 +582,7 @@ jobs:
         sudo -E apt-get -yq --no-install-suggests --no-install-recommends install cppcheck
         python3 -m pip install --disable-pip-version-check --user codespell
     - name: 'cppcheck'
       run: ./tools/cppcheck.sh
@@ -605,7 +605,7 @@ jobs:
         python3 -m pip install --disable-pip-version-check --user cmake==3.15.*
       with:
         path: geos
diff --git a/.github/workflows/codeql.yml b/.github/workflows/codeql.yml
index 46eb081ac..39126ac0d 100644
--- a/.github/workflows/codeql.yml
+++ b/.github/workflows/codeql.yml
@@ -36,11 +36,11 @@ jobs:
         # Learn more about CodeQL language support at https://aka.ms/codeql-docs/language-support
     steps:
     # Initializes the CodeQL tools for scanning.
     - name: Initialize CodeQL
-      uses: github/codeql-action/init at v4
+      uses: github/codeql-action/init at v4.36.0
       with:
         languages: ${{ matrix.language }}
         # If you wish to specify custom queries, you can do so here or in a config file.
@@ -63,6 +63,6 @@ jobs:
           make -j$(nproc)
     - name: Perform CodeQL Analysis
-      uses: github/codeql-action/analyze at v4
+      uses: github/codeql-action/analyze at v4.36.0
       with:
         category: "/language:${{matrix.language}}"
diff --git a/.github/workflows/container.yml b/.github/workflows/container.yml
index 42a93ec20..d9168c715 100644
--- a/.github/workflows/container.yml
+++ b/.github/workflows/container.yml
@@ -24,7 +24,7 @@ jobs:
     steps:
     - name: Docker meta
diff --git a/.github/workflows/release.yml b/.github/workflows/release.yml
index 2edbafad7..2920c83ae 100644
--- a/.github/workflows/release.yml
+++ b/.github/workflows/release.yml
@@ -32,7 +32,7 @@ jobs:
         uname -a
         sudo -E apt-get -yq --no-install-suggests --no-install-recommends install make doxygen
     - name: Get tag
@@ -67,7 +67,7 @@ jobs:
     - name: Create Release
       if: ${{ steps.tag.outputs.tag == steps.version.outputs.geosversion }}
-      uses: softprops/action-gh-release at v2
+      uses: softprops/action-gh-release at v3
       with:
         body_path: ${{ steps.notes.outputs.geosnotes }}
         name: Release ${{ steps.version.outputs.geosversion }}
diff --git a/.github/workflows/web.yml b/.github/workflows/web.yml
index c059e4210..cdd46c346 100644
--- a/.github/workflows/web.yml
+++ b/.github/workflows/web.yml
@@ -27,7 +27,7 @@ jobs:
     - name: 'Check Out 📗'
+      uses: actions/checkout at v6.0.2
     - name: 'Hugo Build 🛠'
       # ...or replace 'master' with a full version tag, such as: v0.64.1
Summary of changes:
 .github/workflows/ci.yml        | 20 ++++++++++----------
 .github/workflows/codeql.yml    |  6 +++---
 .github/workflows/container.yml |  2 +-
 .github/workflows/release.yml   |  4 ++--
 .github/workflows/web.yml       |  2 +-
 5 files changed, 17 insertions(+), 17 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
