[geos-commits] [SCM] GEOS branch main updated. 1ea477e8cae3e7da22ce645cf29665a9e21e8641
git at osgeo.org
git at osgeo.org
Sat Mar 7 17:10:45 PST 2026
the project "GEOS".
The branch, main has been updated
via 1ea477e8cae3e7da22ce645cf29665a9e21e8641 (commit)
from b896045021458077ae4c10e831b5d2461f54d3cc (commit)
revisions in full, below.
commit 1ea477e8cae3e7da22ce645cf29665a9e21e8641
Author: Daniel Baston <dbaston at gmail.com>
Date: Sat Mar 7 20:10:21 2026 -0500
DBSCAN: Fix unassigned clusters with minPoints <= 1 (#1386)
diff --git a/src/operation/cluster/DBSCANClusterFinder.cpp b/src/operation/cluster/DBSCANClusterFinder.cpp
index 1a87eb887..15da6c012 100644
--- a/src/operation/cluster/DBSCANClusterFinder.cpp
+++ b/src/operation/cluster/DBSCANClusterFinder.cpp
@@ -44,8 +44,10 @@ Clusters DBSCANClusterFinder::process(const std::vector<const geom::Geometry*> &
index::strtree::TemplateSTRtree<std::size_t> & tree,
UnionFind & uf) {
- std::vector<bool> in_a_cluster(components.size());
- std::vector<bool> is_in_core(components.size());
+ const bool allInputsInCluster = m_minPoints <= 1;
+ std::vector<bool> in_a_cluster(components.size(), allInputsInCluster);
+ std::vector<bool> is_in_core(components.size(), allInputsInCluster);
std::vector<size_t> hits;
std::vector<size_t> neighbors;
@@ -59,7 +61,7 @@ Clusters DBSCANClusterFinder::process(const std::vector<const geom::Geometry*> &
if (hits.size() < m_minPoints) {
- // We didn't find enough points do do anything even if they're all within eps.
+ // We didn't find enough points to do anything even if they're all within eps.
continue;
diff --git a/tests/unit/capi/GEOSClusterTest.cpp b/tests/unit/capi/GEOSClusterTest.cpp
index f96d91ce5..c8136720f 100644
--- a/tests/unit/capi/GEOSClusterTest.cpp
+++ b/tests/unit/capi/GEOSClusterTest.cpp
@@ -105,6 +105,8 @@ template<>
template<>
void object::test<2>()
+ set_test_name("DBSCAN");
input_ = fromWKT(
"GEOMETRYCOLLECTION ("
"POINT (0 0),"
@@ -118,6 +120,24 @@ void object::test<2>()
"POINT ( 3 0.1)"
+ GEOSClusterInfo* clusters = GEOSClusterDBSCAN(input_, 0.01, 0);
+ ensure_equals("nine clusters with eps=0.01, minPoints = 0", GEOSClusterInfo_getNumClusters(clusters), 9u);
+ GEOSClusterInfo_destroy(clusters);
+ GEOSClusterInfo* clusters = GEOSClusterDBSCAN(input_, 0.01, 1);
+ ensure_equals("nine clusters with eps=0.01, minPoints = 1", GEOSClusterInfo_getNumClusters(clusters), 9u);
+ GEOSClusterInfo* clusters = GEOSClusterDBSCAN(input_, 0.1, 1);
+ ensure_equals("five clusters with eps=0.1, minPoints = 1", GEOSClusterInfo_getNumClusters(clusters), 5u);
GEOSClusterInfo* clusters = GEOSClusterDBSCAN(input_, 1.01, 5);
ensure_equals("two clusters with minPoints = 5", GEOSClusterInfo_getNumClusters(clusters), 2u);
Summary of changes:
src/operation/cluster/DBSCANClusterFinder.cpp | 8 +++++---
tests/unit/capi/GEOSClusterTest.cpp | 20 ++++++++++++++++++++
2 files changed, 25 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits
