[geos-commits] [SCM] GEOS branch main updated. 701457b424a834b7da398d6abb60c642addce642
git at osgeo.org
git at osgeo.org
Mon Mar 9 08:54:47 PDT 2026
the project "GEOS".
The branch, main has been updated
via 701457b424a834b7da398d6abb60c642addce642 (commit)
from 88a40b383ef4bb30fd72f8ac3f255bfc7060ead7 (commit)
revisions in full, below.
commit 701457b424a834b7da398d6abb60c642addce642
Author: Mike Taves <mwtoews at gmail.com>
Date: Tue Mar 10 04:54:25 2026 +1300
CI: update various GitHub Actions (#1392)
* CI: update various GitHub Actions
* Simplify run commands use use cmake -S . -B build
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 37b039887..5885f3b90 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -188,11 +188,10 @@ jobs:
python3 -m pip install --disable-pip-version-check --user cmake==${{ matrix.ci.cmake }}
echo "$(python3 -m site --user-base)/bin" >> $GITHUB_PATH
- - name: 'Check Out'
- uses: actions/checkout at v4
+ - uses: actions/checkout at v6
- name: Retrieve build cache
- uses: actions/cache/restore at v4
+ uses: actions/cache/restore at v5
with:
path: .ccache
@@ -205,8 +204,6 @@ jobs:
CXXFLAGS: "-m${{ matrix.ci.arch }}"
run: |
set -e
- mkdir build
- cd build
cmake --version
cmake ${{ matrix.ci.cmake_extra }} \
-D CMAKE_BUILD_TYPE=${{ matrix.ci.build_type }} \
@@ -215,13 +212,13 @@ jobs:
-D CMAKE_CXX_STANDARD=${{ matrix.ci.cxxstd }} \
-D BUILD_DOCUMENTATION=YES \
-D USE_CCACHE=ON \
- make -j $(nproc)
- cmake --build . --target docs
+ -S . -B build
+ cmake --build build -j $(nproc)
+ cmake --build build --target docs
ccache --show-stats
- name: Save build cache
- uses: actions/cache/save at v4
+ uses: actions/cache/save at v5
with:
path: .ccache
key: ${{ steps.restore-cache.outputs.cache-primary-key }}
@@ -243,7 +240,7 @@ jobs:
- name: 'Upload Valgrind Log'
if: failure()
- uses: actions/upload-artifact at v4
+ uses: actions/upload-artifact at v7
with:
path: build/Testing/Temporary/MemoryChecker.**.log
@@ -251,8 +248,8 @@ jobs:
- name: Generate coverage report
if: matrix.ci.build_type == 'Coverage'
+ working-directory: ./build
run: |
- cd build
lcov --ignore-errors=gcov,negative --capture --directory CMakeFiles --output-file coverage.info
- name: Upload Coverage to Codecov
@@ -275,8 +272,7 @@ jobs:
build_type: ['Debug', 'Release']
steps:
- name: 'Setup'
uses: msys2/setup-msys2 at v2
@@ -290,8 +286,8 @@ jobs:
mingw-w64-x86_64-gcc
with:
path: .ccache
key: windows-mingw-${{ matrix.build_type}}-${{ github.ref_name }}-${{ github.run_id }}
@@ -301,19 +297,17 @@ jobs:
env:
CCACHE_DIR: ${{ github.workspace }}\.ccache
run: |
- mkdir build
- cd build
cmake --version
cmake \
-G "MSYS Makefiles" \
-D CMAKE_BUILD_TYPE=${{ matrix.build_type}} \
-D USE_CCACHE=ON \
- cmake --build . -j 4
+ -S . -B build
+ cmake --build build -j 4
ccache --show-stats --verbose
with:
path: .ccache
@@ -334,16 +328,13 @@ jobs:
arch: arm64
steps:
# ccache not supported for this generator and/or Debug
- name: 'Build'
shell: cmd
run: |
- md build
- cd build
cmake --version
cmake ^
-G "Visual Studio 17 2022" ^
@@ -351,9 +342,9 @@ jobs:
-D CMAKE_BUILD_TYPE=Debug ^
-D CMAKE_CXX_STANDARD=17 ^
-D BUILD_SHARED_LIBS=ON ^
+ -S . -B build
IF %ERRORLEVEL% NEQ 0 exit /B 1
- cmake --build . --config Debug -j 4 -- /p:CL_MPcount=4
+ cmake --build build --config Debug -j 4 -- /p:CL_MPcount=4
- name: 'Test'
working-directory: build
@@ -378,12 +369,11 @@ jobs:
runs-on: ${{ matrix.ci.os }}
steps:
with:
path: .ccache
key: msvc-ninja-${{ matrix.ci.os }}-${{ matrix.ci.cxxstd }}-${{ matrix.ci.arch }}-${{ github.ref_name }}-${{ github.run_id }}
@@ -402,8 +392,6 @@ jobs:
shell: cmd
run: |
- md build
- cd build
cmake --version
cmake ^
-G Ninja ^
@@ -411,14 +399,14 @@ jobs:
-D CMAKE_CXX_STANDARD=${{ matrix.ci.cxxstd }} ^
-D USE_CCACHE=ON ^
+ -S . -B build
- cmake --build . --config Release -j 4
+ cmake --build build --config Release -j 4
with:
path: .ccache
@@ -462,12 +450,11 @@ jobs:
which clang++
clang++ --version
with:
path: .ccache
key: ${{ runner.os }}-${{ matrix.xcode }}-${{ matrix.build_type}}-${{ matrix.cxxstd }}-${{ github.ref_name }}-${{ github.run_id }}
@@ -476,19 +463,17 @@ jobs:
- name: 'Build'
run: |
set -e
- mkdir build
- cd build
cmake --version
cmake \
-D CMAKE_BUILD_TYPE=${{ matrix.build_type }} \
-D CMAKE_CXX_STANDARD=${{ matrix.cxxstd }} \
-D USE_CCACHE=ON \
- cmake --build . --config ${{ matrix.build_type }} -j 4
+ -S . -B build
+ cmake --build build --config ${{ matrix.build_type }} -j 4
ccache --show-stats
with:
path: .ccache
@@ -501,10 +486,10 @@ jobs:
runs-on: ubuntu-latest
steps:
- - uses: actions/checkout at v5
with:
path: .ccache
@@ -523,16 +508,14 @@ jobs:
set -e
export CCACHE_DIR=$PWD/.ccache
cmake --version
- cmake -S . -B _build -D USE_CCACHE=ON ..
- cmake --build _build -j $(nproc)
+ cmake -S . -B build -D USE_CCACHE=ON
ccache --show-stats
- cd _build
- ctest --output-on-failure
- cd ..
- rm -rf _build
+ (cd build && ctest --output-on-failure)
+ rm -rf build
with:
path: .ccache
@@ -548,10 +531,10 @@ jobs:
sudo -E apt-get autopurge -y needrestart
sudo -E apt-get -yq --no-install-suggests --no-install-recommends install make cmake emscripten ccache
with:
path: .ccache
@@ -561,18 +544,16 @@ jobs:
- name: Build
run: |
set -e
- mkdir build
- cd build
cmake --version
emcmake cmake \
-D BUILD_SHARED_LIBS=OFF \
-D USE_CCACHE=ON \
- cmake --build . -j $(nproc)
+ -S . -B build
ccache --show-stats
with:
path: .ccache
@@ -592,8 +573,7 @@ jobs:
sudo -E apt-get -yq --no-install-suggests --no-install-recommends install cppcheck
python3 -m pip install --disable-pip-version-check --user codespell
- name: 'cppcheck'
run: ./tools/cppcheck.sh
@@ -616,8 +596,7 @@ jobs:
python3 -m pip install --disable-pip-version-check --user cmake==3.15.*
with:
path: geos
diff --git a/.github/workflows/codeql.yml b/.github/workflows/codeql.yml
index 556a2143e..46eb081ac 100644
--- a/.github/workflows/codeql.yml
+++ b/.github/workflows/codeql.yml
@@ -36,12 +36,11 @@ jobs:
# Learn more about CodeQL language support at https://aka.ms/codeql-docs/language-support
steps:
- - name: Checkout repository
# Initializes the CodeQL tools for scanning.
- name: Initialize CodeQL
- uses: github/codeql-action/init at v3
+ uses: github/codeql-action/init at v4
with:
languages: ${{ matrix.language }}
# If you wish to specify custom queries, you can do so here or in a config file.
@@ -64,6 +63,6 @@ jobs:
make -j$(nproc)
- name: Perform CodeQL Analysis
- uses: github/codeql-action/analyze at v3
+ uses: github/codeql-action/analyze at v4
with:
category: "/language:${{matrix.language}}"
diff --git a/.github/workflows/container.yml b/.github/workflows/container.yml
index 0505fd9e1..07a0abb8c 100644
--- a/.github/workflows/container.yml
+++ b/.github/workflows/container.yml
@@ -22,14 +22,13 @@ jobs:
steps:
- name: Set up Docker Buildx
- uses: docker/setup-buildx-action at v2
+ uses: docker/setup-buildx-action at v4
- name: Login to GitHub Container Registry
- uses: docker/login-action at v2
+ uses: docker/login-action at v4
with:
registry: ghcr.io
username: ${{ github.repository_owner }}
@@ -40,7 +39,7 @@ jobs:
cp tools/ci/geosop/Dockerfile .
- name: Build and Push
- uses: docker/build-push-action at v4
+ uses: docker/build-push-action at v7
with:
context: .
# platforms: linux/amd64,linux/arm64
diff --git a/.github/workflows/release.yml b/.github/workflows/release.yml
index 0cd89dd4e..2edbafad7 100644
--- a/.github/workflows/release.yml
+++ b/.github/workflows/release.yml
@@ -32,8 +32,7 @@ jobs:
uname -a
sudo -E apt-get -yq --no-install-suggests --no-install-recommends install make doxygen
- name: Get tag
@@ -68,7 +67,7 @@ jobs:
- name: Create Release
if: ${{ steps.tag.outputs.tag == steps.version.outputs.geosversion }}
- uses: softprops/action-gh-release at v1
+ uses: softprops/action-gh-release at v2
with:
body_path: ${{ steps.notes.outputs.geosnotes }}
name: Release ${{ steps.version.outputs.geosversion }}
diff --git a/.github/workflows/web.yml b/.github/workflows/web.yml
index 7a14b534c..c059e4210 100644
--- a/.github/workflows/web.yml
+++ b/.github/workflows/web.yml
@@ -27,7 +27,7 @@ jobs:
- name: 'Check Out 📗'
+ uses: actions/checkout at v6
- name: 'Hugo Build 🛠'
# ...or replace 'master' with a full version tag, such as: v0.64.1
@@ -51,7 +51,7 @@ jobs:
cp -ra build.cmake/doxygen/doxygen_docs/html/* public_html/doxygen
- name: 'Deploy 🚀'
- uses: JamesIves/github-pages-deploy-action at v4.4.1
+ uses: JamesIves/github-pages-deploy-action at v4
with:
branch: gh-pages # The branch the action should deploy to.
folder: public_html # The folder the action should deploy.
Summary of changes:
.github/workflows/ci.yml | 101 ++++++++++++++++------------------------
.github/workflows/codeql.yml | 7 ++-
.github/workflows/container.yml | 9 ++--
.github/workflows/release.yml | 5 +-
.github/workflows/web.yml | 4 +-
5 files changed, 51 insertions(+), 75 deletions(-)
hooks/post-receive
More information about the geos-commits
