[geos-commits] [SCM] GEOS branch main updated. 77574b214701e0f2750b949e7f65cbdd49a4ce31
Tue Mar 24 09:14:17 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  77574b214701e0f2750b949e7f65cbdd49a4ce31 (commit)
      from  81ab2d7b01990811c3edb00f7407a20908dfe1cc (commit)
revisions in full, below.
commit 77574b214701e0f2750b949e7f65cbdd49a4ce31
Author: Daniel Baston <dbaston at gmail.com>
Date:   Tue Mar 24 12:13:49 2026 -0400
    RingClipper: Avoid dropping M values (#1407)
diff --git a/include/geos/operation/overlayng/RingClipper.h b/include/geos/operation/overlayng/RingClipper.h
index d8f6a186e..8bee13b31 100644
--- a/include/geos/operation/overlayng/RingClipper.h
+++ b/include/geos/operation/overlayng/RingClipper.h
@@ -61,6 +61,7 @@ namespace overlayng { // geos.operation.overlayng
 class GEOS_DLL RingClipper {
     using Coordinate = geos::geom::Coordinate;
+    using CoordinateXY = geos::geom::CoordinateXY;
     using CoordinateSequence = geos::geom::CoordinateSequence;
     using Envelope = geos::geom::Envelope;
@@ -87,10 +88,10 @@ private:
     * with an edge of the clip box.
     * The segment must be known to intersect the edge.
-    void intersection(const Coordinate& a, const Coordinate& b, int edgeIndex, Coordinate& rsltPt) const;
-    double intersectionLineY(const Coordinate& a, const Coordinate& b, double y) const;
-    double intersectionLineX(const Coordinate& a, const Coordinate& b, double x) const;
-    bool isInsideEdge(const Coordinate& p, int edgeIndex) const;
+    void intersection(const CoordinateXY& a, const CoordinateXY& b, int edgeIndex, CoordinateXY& rsltPt) const;
+    static double intersectionLineY(const CoordinateXY& a, const CoordinateXY& b, double y);
+    static double intersectionLineX(const CoordinateXY& a, const CoordinateXY& b, double x);
+    bool isInsideEdge(const CoordinateXY& p, int edgeIndex) const;
 public:
diff --git a/src/operation/overlayng/RingClipper.cpp b/src/operation/overlayng/RingClipper.cpp
index cf108dd1e..2551990f8 100644
--- a/src/operation/overlayng/RingClipper.cpp
+++ b/src/operation/overlayng/RingClipper.cpp
@@ -15,6 +15,7 @@
 #include <geos/operation/overlayng/RingClipper.h>
 using geos::geom::CoordinateSequence;
+using geos::geom::CoordinateXYZM;
 namespace geos {      // geos
 namespace operation { // geos.operation
@@ -41,16 +42,16 @@ std::unique_ptr<CoordinateSequence>
 RingClipper::clipToBoxEdge(const CoordinateSequence* pts, int edgeIndex, bool closeRing) const
     // TODO: is it possible to avoid copying array 4 times?
-    std::unique_ptr<CoordinateSequence> ptsClip(new CoordinateSequence());
+    auto ptsClip = std::make_unique<CoordinateSequence>(0, pts->hasZ(), pts->hasM());
-    Coordinate p0;
+    CoordinateXYZM p0;
     pts->getAt(pts->size() - 1, p0);
     for (std::size_t i = 0; i < pts->size(); i++) {
-        Coordinate p1;
+        CoordinateXYZM p1;
         pts->getAt(i, p1);
         if (isInsideEdge(p1, edgeIndex)) {
             if (!isInsideEdge(p0, edgeIndex)) {
-                Coordinate intPt;
+                CoordinateXY intPt;
                 intersection(p0, p1, edgeIndex, intPt);
                 ptsClip->add(intPt, false);
@@ -59,7 +60,7 @@ RingClipper::clipToBoxEdge(const CoordinateSequence* pts, int edgeIndex, bool cl
         else if (isInsideEdge(p0, edgeIndex)) {
-            Coordinate intPt;
@@ -69,28 +70,26 @@ RingClipper::clipToBoxEdge(const CoordinateSequence* pts, int edgeIndex, bool cl
     // add closing point if required
-    if (closeRing && ptsClip->size() > 0) {
-        const Coordinate& start = ptsClip->getAt(0);
-        if (!start.equals2D(ptsClip->getAt(ptsClip->size() - 1))) {
-            ptsClip->add(start);
+    if (closeRing) {
+        ptsClip->closeRing();
     return ptsClip;
 /*private*/
 void
-RingClipper::intersection(const Coordinate& a, const Coordinate& b, int edgeIndex, Coordinate& rsltPt) const
+RingClipper::intersection(const CoordinateXY& a, const CoordinateXY& b, int edgeIndex, CoordinateXY& rsltPt) const
     switch (edgeIndex) {
     case BOX_BOTTOM:
-        rsltPt = Coordinate(intersectionLineY(a, b, clipEnv.getMinY()), clipEnv.getMinY());
+        rsltPt = CoordinateXY(intersectionLineY(a, b, clipEnv.getMinY()), clipEnv.getMinY());
         break;
     case BOX_RIGHT:
-        rsltPt = Coordinate(clipEnv.getMaxX(), intersectionLineX(a, b, clipEnv.getMaxX()));
+        rsltPt = CoordinateXY(clipEnv.getMaxX(), intersectionLineX(a, b, clipEnv.getMaxX()));
         break;
     case BOX_TOP:
-        rsltPt = Coordinate(intersectionLineY(a, b, clipEnv.getMaxY()), clipEnv.getMaxY());
+        rsltPt = CoordinateXY(intersectionLineY(a, b, clipEnv.getMaxY()), clipEnv.getMaxY());
         break;
     case BOX_LEFT:
     default:
@@ -101,7 +100,7 @@ RingClipper::intersection(const Coordinate& a, const Coordinate& b, int edgeInde
 /*private*/
 double
-RingClipper::intersectionLineY(const Coordinate& a, const Coordinate& b, double y) const
+RingClipper::intersectionLineY(const CoordinateXY& a, const CoordinateXY& b, double y)
     double m = (b.x - a.x) / (b.y - a.y);
     double intercept = (y - a.y) * m;
@@ -110,7 +109,7 @@ RingClipper::intersectionLineY(const Coordinate& a, const Coordinate& b, double
 /*private*/
 double
-RingClipper::intersectionLineX(const Coordinate& a, const Coordinate& b, double x) const
+RingClipper::intersectionLineX(const CoordinateXY& a, const CoordinateXY& b, double x)
     double m = (b.y - a.y) / (b.x - a.x);
     double intercept = (x - a.x) * m;
@@ -119,7 +118,7 @@ RingClipper::intersectionLineX(const Coordinate& a, const Coordinate& b, double
 /*private*/
 bool
-RingClipper::isInsideEdge(const Coordinate& p, int edgeIndex) const
+RingClipper::isInsideEdge(const CoordinateXY& p, int edgeIndex) const
     if (clipEnv.isNull()) {
         return false;
diff --git a/tests/unit/operation/overlayng/OverlayNGZTest.cpp b/tests/unit/operation/overlayng/OverlayNGZTest.cpp
index e9ee46377..732d7eb25 100644
--- a/tests/unit/operation/overlayng/OverlayNGZTest.cpp
+++ b/tests/unit/operation/overlayng/OverlayNGZTest.cpp
@@ -316,4 +316,14 @@ void object::test<21>()
         "LINESTRING ZM (0 0 2 9, 1 0 5 7)");
+template<>
+template<>
+void object::test<22> ()
+    set_test_name("POLYGON XYM / POLYGON XYM intersection");
+    checkIntersection("POLYGON M ((4 12 6, 2 6 7, 7 6 8, 11 4 9, 15 15 10, 4 12 6))", "POLYGON M ((1 9 1, 9 9 2, 9 1 3, 1 1 4, 1 9 1))",
+        "POLYGON M ((2 6 7, 3 9 3.875, 9 9 2, 9 5 5.5, 7 6 8, 2 6 7))");
 } // namespace tut
Summary of changes:
 include/geos/operation/overlayng/RingClipper.h    |  9 ++++---
 src/operation/overlayng/RingClipper.cpp           | 33 +++++++++++------------
 tests/unit/operation/overlayng/OverlayNGZTest.cpp | 10 +++++++
 3 files changed, 31 insertions(+), 21 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
