[geos-commits] [SCM] GEOS branch main updated. 861ed20b38bb26067f5a552302b30d3637c03bdf
git at osgeo.org
git at osgeo.org
Tue Mar 24 10:42:42 PDT 2026
the project "GEOS".
The branch, main has been updated
via 861ed20b38bb26067f5a552302b30d3637c03bdf (commit)
from 5e4f5981551ec79836ac25bda4fce0b707187fc0 (commit)
revisions in full, below.
commit 861ed20b38bb26067f5a552302b30d3637c03bdf
Author: Daniel Baston <dbaston at gmail.com>
Date: Tue Mar 24 13:42:22 2026 -0400
LineLimiter: Avoid dropping M values (#1408)
diff --git a/include/geos/operation/overlayng/EdgeNodingBuilder.h b/include/geos/operation/overlayng/EdgeNodingBuilder.h
index cae8a44e7..0927241ba 100644
--- a/include/geos/operation/overlayng/EdgeNodingBuilder.h
+++ b/include/geos/operation/overlayng/EdgeNodingBuilder.h
@@ -140,7 +140,7 @@ private:
* limit the line to the clip envelope.
- std::vector<std::unique_ptr<CoordinateSequence>>& limit(const LineString* line);
+ std::vector<std::unique_ptr<CoordinateSequence>>& limit(const LineString* line) const;
* If a clipper is present,
diff --git a/include/geos/operation/overlayng/LineLimiter.h b/include/geos/operation/overlayng/LineLimiter.h
index 8a9b27f49..91f00eeec 100644
--- a/include/geos/operation/overlayng/LineLimiter.h
+++ b/include/geos/operation/overlayng/LineLimiter.h
@@ -54,6 +54,7 @@ namespace overlayng { // geos.operation.overlayng
class GEOS_DLL LineLimiter {
using Envelope = geos::geom::Envelope;
using Coordinate = geos::geom::Coordinate;
+ using CoordinateXY = geos::geom::CoordinateXY;
using CoordinateSequence = geos::geom::CoordinateSequence;
private:
@@ -61,14 +62,21 @@ private:
// Members
const Envelope* limitEnv;
std::unique_ptr<geom::CoordinateSequence> ptList;
- const Coordinate* lastOutside;
+ const CoordinateXY* lastOutside;
std::vector<std::unique_ptr<CoordinateSequence>> sections;
+ bool hasZ{false};
+ bool hasM{false};
// Methods
- void addPoint(const Coordinate* p);
- void addOutside(const Coordinate* p);
- bool isLastSegmentIntersecting(const Coordinate* p);
- bool isSectionOpen();
+ template<typename CoordType>
+ void addPoint(const CoordType& p);
+ void addOutside(const CoordType& p);
+ bool isLastSegmentIntersecting(const CoordinateXY& p) const;
+ bool isSectionOpen() const;
void startSection();
void finishSection();
diff --git a/src/operation/overlayng/EdgeNodingBuilder.cpp b/src/operation/overlayng/EdgeNodingBuilder.cpp
index d63f4acb3..b063770f1 100644
--- a/src/operation/overlayng/EdgeNodingBuilder.cpp
+++ b/src/operation/overlayng/EdgeNodingBuilder.cpp
@@ -414,7 +414,7 @@ EdgeNodingBuilder::isToBeLimited(const LineString* line) const
/*private*/
-EdgeNodingBuilder::limit(const LineString* line)
+EdgeNodingBuilder::limit(const LineString* line) const
const CoordinateSequence* pts = line->getCoordinatesRO();
return limiter->limit(pts);
diff --git a/src/operation/overlayng/LineLimiter.cpp b/src/operation/overlayng/LineLimiter.cpp
index 57036e248..f1410f424 100644
--- a/src/operation/overlayng/LineLimiter.cpp
+++ b/src/operation/overlayng/LineLimiter.cpp
@@ -34,32 +34,36 @@ LineLimiter::limit(const CoordinateSequence *pts)
lastOutside = nullptr;
ptList.reset(nullptr);
sections.clear();
+ hasZ = pts->hasZ();
+ hasM = pts->hasM();
- for (std::size_t i = 0; i < pts->size(); i++) {
- const Coordinate* p = &(pts->getAt(i));
- if (limitEnv->intersects(*p)) {
+ pts->forEach([this](const auto& p) {
+ if (limitEnv->intersects(p)) {
addPoint(p);
else {
addOutside(p);
// finish last section, if any
finishSection();
return sections;
/*private*/
+template<typename CoordType>
void
-LineLimiter::addPoint(const Coordinate* p)
+LineLimiter::addPoint(const CoordType& p)
- startSection();
- ptList->add(*p, false);
+ startSection<CoordType>();
+ ptList->add(p, false);
/*private*/
void
-LineLimiter::addOutside(const Coordinate* p)
+LineLimiter::addOutside(const CoordType& p)
bool segIntersects = isLastSegmentIntersecting(p);
if (!segIntersects) {
@@ -67,16 +71,16 @@ LineLimiter::addOutside(const Coordinate* p)
else {
if(lastOutside != nullptr) {
- addPoint(lastOutside);
+ addPoint(*static_cast<const CoordType*>(lastOutside));
addPoint(p);
- lastOutside = p;
+ lastOutside = &p;
/*private*/
bool
-LineLimiter::isLastSegmentIntersecting(const Coordinate* p)
+LineLimiter::isLastSegmentIntersecting(const CoordinateXY& p) const
if (lastOutside == nullptr) {
// last point must have been inside
@@ -84,26 +88,27 @@ LineLimiter::isLastSegmentIntersecting(const Coordinate* p)
return true;
return false;
- return limitEnv->intersects(*lastOutside, *p);
+ return limitEnv->intersects(*lastOutside, p);
/*private*/
bool
-LineLimiter::isSectionOpen()
+LineLimiter::isSectionOpen() const
return ptList != nullptr;
/*private*/
void
LineLimiter::startSection()
if (!isSectionOpen()) {
- ptList = detail::make_unique<CoordinateSequence>();
+ ptList = std::make_unique<CoordinateSequence>(0, hasZ, hasM);
if (lastOutside != nullptr) {
- ptList->add(*lastOutside, false);
+ ptList->add(*static_cast<const CoordType*>(lastOutside), false);
@@ -125,7 +130,7 @@ LineLimiter::finishSection()
assert(!ptList->hasRepeatedPoints());
//ptList->erase(std::unique(ptList->begin(), ptList->end()), ptList->end());
- sections.emplace_back(ptList.release());
+ sections.push_back(std::move(ptList));
diff --git a/tests/unit/operation/overlayng/LineLimiterTest.cpp b/tests/unit/operation/overlayng/LineLimiterTest.cpp
index 025200b97..af9ef9334 100644
--- a/tests/unit/operation/overlayng/LineLimiterTest.cpp
+++ b/tests/unit/operation/overlayng/LineLimiterTest.cpp
@@ -49,7 +49,7 @@ struct test_linelimiter_data {
// std::cout << "--expect--" << std::endl;
// std::cout << w.write(expected.get()) << std::endl;
- ensure_equals_geometry(expected.get(), result.get());
+ ensure_equals_geometry_xyzm(expected.get(), result.get());
std::unique_ptr<Geometry>
@@ -170,7 +170,17 @@ void object::test<8> ()
checkLimit(wkt, env, expected);
+template<>
+template<>
+void object::test<9>()
+ set_test_name("M values preserved");
+ std::string wkt= "LINESTRING M (7 17 1, 23 17 2, 23 13 3, 7 13 4)";
+ Envelope env(10,20,10,20);
+ std::string expected = "MULTILINESTRING M ((7 17 1, 23 17 2), (23 13 3, 7 13 4))";
+ checkLimit(wkt, env, expected);
} // namespace tut
diff --git a/tests/unit/operation/overlayng/OverlayNGZTest.cpp b/tests/unit/operation/overlayng/OverlayNGZTest.cpp
index 732d7eb25..d8625d3cb 100644
--- a/tests/unit/operation/overlayng/OverlayNGZTest.cpp
+++ b/tests/unit/operation/overlayng/OverlayNGZTest.cpp
@@ -326,4 +326,16 @@ void object::test<22> ()
"POLYGON M ((2 6 7, 3 9 3.875, 9 9 2, 9 5 5.5, 7 6 8, 2 6 7))");
+template<>
+template<>
+void object::test<23> ()
+ set_test_name("LINESTRING XYM / LINESTRING XYM intersection");
+ // inputs need > 20 vertices to activate LineLimiter
+ checkIntersection("LINESTRING M (4 12 6,3.5 10.5 6.2,3 9 6.5,2.5 7.5 6.8,2 6 7,3.7 6 7.3,5.3 6 7.7,7 6 8,8.3 5.3 8.3,9.7 4.7 8.7,11 4 9,11.7 5.8 9.2,12.3 7.7 9.3,13 9.5 9.5,13.7 11.3 9.7,14.3 13.2 9.8,15 15 10,13.2 14.5 9.3,11.3 14 8.7,9.5 13.5 8,7.7 13 7.3,5.8 12.5 6.7,4 12 6)",
+ "LINESTRING M (1 9 1,2.3 9 1.2,3.7 9 1.3,5 9 1.5,6.3 9 1.7,7.7 9 1.8,9 9 2,9 7.7 2.2,9 6.3 2.3,9 5 2.5,9 3.7 2.7,9 2.3 2.8,9 1 3,7.7 1 3.2,6.3 1 3.3,5 1 3.5,3.7 1 3.7,2.3 1 3.8,1 1 4,1 2.3 3.5,1 3.7 3,1 5 2.5,1 6.3 2,1 7.7 1.5,1 9 1)",
+ "MULTIPOINT M ((3 9 6.5), (9 5 2.5))");
} // namespace tut
Summary of changes:
.../geos/operation/overlayng/EdgeNodingBuilder.h | 2 +-
include/geos/operation/overlayng/LineLimiter.h | 18 ++++++++---
src/operation/overlayng/EdgeNodingBuilder.cpp | 2 +-
src/operation/overlayng/LineLimiter.cpp | 37 ++++++++++++----------
tests/unit/operation/overlayng/LineLimiterTest.cpp | 12 ++++++-
tests/unit/operation/overlayng/OverlayNGZTest.cpp | 12 +++++++
6 files changed, 59 insertions(+), 24 deletions(-)
hooks/post-receive
More information about the geos-commits
