[geos-commits] [SCM] GEOS branch main updated. b4ffacf814c0095b7631ed2e0b2757aaf3d6b33b
git at osgeo.org
git at osgeo.org
Tue Mar 24 13:46:22 PDT 2026
the project "GEOS".
The branch, main has been updated
via b4ffacf814c0095b7631ed2e0b2757aaf3d6b33b (commit)
from afe57da9baff42e27afdbec613bb0fa8394eaba5 (commit)
revisions in full, below.
commit b4ffacf814c0095b7631ed2e0b2757aaf3d6b33b
Author: Mike Taves <mwtoews at gmail.com>
Date: Wed Mar 25 09:45:58 2026 +1300
CI: build container tags using docker/metadata-action (#1400)
diff --git a/.github/workflows/container.yml b/.github/workflows/container.yml
index 07a0abb8c..0c755d659 100644
--- a/.github/workflows/container.yml
+++ b/.github/workflows/container.yml
@@ -9,6 +9,8 @@ on:
push:
branches:
- main
+ tags:
paths-ignore:
- 'web/**'
@@ -24,8 +26,17 @@ jobs:
- uses: actions/checkout at v6
- - name: Set up Docker Buildx
- uses: docker/setup-buildx-action at v4
+ - name: Docker meta
+ id: meta
+ uses: docker/metadata-action at v6
+ with:
+ images: ghcr.io/libgeos/geosop
+ # generate Docker tags based on the following events/attributes
+ tags: |
+ type=ref,event=branch
+ type=semver,pattern={{major}}.{{minor}}
+ type=semver,pattern={{version}}
+ type=sha
- name: Login to GitHub Container Registry
uses: docker/login-action at v4
@@ -34,6 +45,9 @@ jobs:
username: ${{ github.repository_owner }}
password: ${{ secrets.GITHUB_TOKEN }}
+ - name: Set up Docker Buildx
+ uses: docker/setup-buildx-action at v4
- name: Get Dockerfile
run: |
cp tools/ci/geosop/Dockerfile .
@@ -42,11 +56,6 @@ jobs:
uses: docker/build-push-action at v7
with:
context: .
- # platforms: linux/amd64,linux/arm64
- platforms: linux/amd64
push: true
- tags: |
- ghcr.io/libgeos/geosop:latest
+ tags: ${{ steps.meta.outputs.tags }}
+ labels: ${{ steps.meta.outputs.labels }}
diff --git a/tools/ci/geosop/Dockerfile b/tools/ci/geosop/Dockerfile
index 5854cd3bc..a20b783bf 100644
--- a/tools/ci/geosop/Dockerfile
+++ b/tools/ci/geosop/Dockerfile
@@ -1,28 +1,38 @@
-FROM docker.osgeo.org/geos/build-test:alpine AS base
-ARG VERSION=47f145e
+ARG BASEIMAGE="alpine:3.23"
+ARG GEOS_VERSION
+FROM ${BASEIMAGE} AS builder
+RUN apk add --no-cache \
+ cmake \
+ ninja \
+ g++ \
+ gcc
-WORKDIR /source
ADD . /source
-#RUN wget --quiet https://github.com/libgeos/geos/archive/${VERSION}.tar.gz --output-document - \
-#| tar xz --directory=. --strip-components=1
+ARG GEOS_VERSION
+ENV GEOS_VERSION=${GEOS_VERSION}
+RUN if [ -n "${GEOS_VERSION}" ]; then \
+ rm -rf /source && mkdir /source && \
+ wget https://github.com/libgeos/geos/archive/${GEOS_VERSION}.tar.gz \
+ --output-document - | tar xz --directory=/source --strip-components=1; \
+ fi
-WORKDIR /build
-RUN cmake -D CMAKE_BUILD_TYPE=Release -D BUILD_BENCHMARKS=OFF -D BUILD_TESTING=OFF /source \
- && make install \
- && cp bin/geosop /usr/local/bin/geosop
+RUN cmake -S /source -B /build -G Ninja \
+ -D CMAKE_BUILD_TYPE=Release \
+ -D CMAKE_INSTALL_LIBDIR=lib \
+ -D BUILD_BENCHMARKS=OFF \
+ -D BUILD_DOCUMENTATION=OFF \
+ -D BUILD_TESTING=OFF \
+ && cmake --build /build \
+ && cmake --install /build --prefix /install --strip
-WORKDIR /install/bin
-RUN cp --no-dereference /usr/local/bin/geos* . \
- && for i in ./*; do strip -s $i 2>/dev/null || /bin/true; done
+FROM ${BASEIMAGE} AS runner
-WORKDIR /install/lib
-RUN cp --no-dereference /usr/local/lib*/libgeos*.so.* . \
-FROM alpine
RUN apk add --no-cache libstdc++
-COPY --from=base /install/bin/geos* /usr/local/bin/
-COPY --from=base /install/lib/libgeos* /usr/local/lib/
+COPY --from=builder /install/bin/geosop /usr/local/bin/geosop
+COPY --from=builder /install/lib/libgeos.* /usr/local/lib/
ENTRYPOINT ["geosop"]
Summary of changes:
.github/workflows/container.yml | 27 +++++++++++++++--------
tools/ci/geosop/Dockerfile | 48 +++++++++++++++++++++++++----------------
2 files changed, 47 insertions(+), 28 deletions(-)
hooks/post-receive
More information about the geos-commits
