[geos-commits] [SCM] GEOS branch main updated. be17b189a8accbf68d5f76f8b45237fd2307011c
Tue Mar 31 15:27:05 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  be17b189a8accbf68d5f76f8b45237fd2307011c (commit)
       via  224d1448e5086c2f0017c4c58b05a25823d27173 (commit)
      from  8b2ee5e04ea2f3d9b088505cb12d270fa805c51f (commit)
revisions in full, below.
commit be17b189a8accbf68d5f76f8b45237fd2307011c
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Mar 31 15:23:11 2026 -0700
    Add
    extern size_t GEOS_DLL *GEOSMinimumSpanningTree(const GEOSGeometry * const geoms[], unsigned int ngeoms);
    for an input set of LineString, build a connected graph using start/end points
    as nodes, and calculate the Minimum Spanning Tree for the graph, returning
    for each input LineString a non-zero number of the edge is in the
    MST and zero otherwise. Different non-zero numbers correspond to member
    ship in different MST of unconnected regions of the graph.
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index 54d29bba9..1341f6365 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -1123,6 +1123,12 @@ extern "C" {
         return GEOSLineMerge_r(handle, g);
+    std::size_t*
+    GEOSMinimumSpanningTree(const Geometry* const* geoms, unsigned int ngeoms)
+        return GEOSMinimumSpanningTree_r(handle, geoms, ngeoms);
     Geometry*
     GEOSLineMergeDirected(const Geometry* g)
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index b38029835..2c21576fc 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -1229,6 +1229,12 @@ extern GEOSGeometry GEOS_DLL *GEOSLineMerge_r(
     GEOSContextHandle_t handle,
     const GEOSGeometry* g);
+/** \see GEOSMinimumSpanningTree */
+extern size_t GEOS_DLL *GEOSMinimumSpanningTree_r(
+    GEOSContextHandle_t handle,
+    const GEOSGeometry * const geoms[],
+    unsigned int ngeoms);
 /** \see GEOSLineMergeDirected */
 extern GEOSGeometry GEOS_DLL *GEOSLineMergeDirected_r(
@@ -5413,8 +5419,25 @@ extern GEOSGeometry GEOS_DLL *GEOSDensify(
 extern GEOSGeometry GEOS_DLL *GEOSLineMerge(const GEOSGeometry* g);
-* Merges a set of LineStrings,
-* joining them at nodes which have cardinality 2.
+ * Computes the Minimum Spanning Tree of the given Curves.
+ * The input is an array of Curves (LineString, CircularString, CompoundCurve)
+ * which form the edges of a graph.
+ * The nodes of the graph are the endpoints of the Curves.
+ * Coincident endpoints are treated as the same node.
+ * \param geoms Input array of Curves. Non-Curve geometries are ignored.
+ * \param ngeoms Number of geometries in the input array.
+ * \return An array of size_t of size ngeoms. 0 if the edge is not in the MST.
+ *         Values > 0 indicate the component ID of the subtree the edge belongs to.
+ *         The caller is responsible for freeing the returned array using GEOSFree().
+ *         Returns NULL if ngeoms is 0 or on error.
+ * \since 3.15.0
+extern size_t GEOS_DLL *GEOSMinimumSpanningTree(const GEOSGeometry * const geoms[], unsigned int ngeoms);
+ * Merges a set of LineStrings,* joining them at nodes which have cardinality 2.
 * and where the lines have the same direction.
 * This means that lines do not have their direction reversed.
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 05c83acdf..d183be9ea 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -85,6 +85,7 @@
 #include <geos/operation/grid/Grid.h>
 #include <geos/operation/grid/GridIntersection.h>
 #include <geos/operation/linemerge/LineMerger.h>
+#include <geos/operation/spanning/SpanningTree.h>
 #include <geos/operation/intersection/Rectangle.h>
 #include <geos/operation/intersection/RectangleIntersection.h>
 #include <geos/operation/overlay/snap/GeometrySnapper.h>
@@ -2705,6 +2706,46 @@ extern "C" {
+    std::size_t*
+    GEOSMinimumSpanningTree_r(GEOSContextHandle_t extHandle, const Geometry* const* geoms, unsigned int ngeoms)
+        using geos::operation::spanning::SpanningTree;
+        using geos::geom::Curve;
+        if (ngeoms == 0 || geoms == nullptr) {
+            return nullptr;
+        return execute(extHandle, [&]() {
+            std::vector<const Curve*> curvevec(ngeoms);
+            for (unsigned int i = 0; i < ngeoms; ++i) {
+                if (geoms[i]) {
+                    auto typeId = geoms[i]->getGeometryTypeId();
+                    if (typeId == geos::geom::GEOS_LINESTRING ||
+                        typeId == geos::geom::GEOS_CIRCULARSTRING ||
+                        typeId == geos::geom::GEOS_COMPOUNDCURVE) {
+                        curvevec[i] = static_cast<const Curve*>(geoms[i]);
+                    else {
+                        curvevec[i] = nullptr;
+                else {
+            std::vector<std::size_t> result;
+            SpanningTree::mst(curvevec, result);
+            std::size_t* result_buf = static_cast<std::size_t*>(malloc(ngeoms * sizeof(std::size_t)));
+            if (result_buf) {
+                std::copy(result.begin(), result.end(), result_buf);
+            return result_buf;
     Geometry*
     GEOSLineMergeDirected_r(GEOSContextHandle_t extHandle, const Geometry* g)
diff --git a/include/geos/operation/spanning/SpanningTree.h b/include/geos/operation/spanning/SpanningTree.h
new file mode 100644
index 000000000..9c35cac37
--- /dev/null
+++ b/include/geos/operation/spanning/SpanningTree.h
@@ -0,0 +1,59 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2026 Paul Ramsey
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+#pragma once
+#include <geos/export.h>
+#include <vector>
+// Forward declarations
+namespace geos {
+namespace geom {
+class Curve;
+namespace geos {
+namespace operation { // geos::operation
+namespace spanning { // geos::operation::spanning
+/** \brief
+ * Constructs a Minimum Spanning Tree (MST) from a set of Curves.
+ * The input is a vector of Curves (LineString, CircularString, CompoundCurve)
+ * The algorithm uses Kruskal's algorithm to find the MST.
+class GEOS_DLL SpanningTree {
+public:
+    /** \brief
+     * @param curves Input vector of Curves.
+     * @param result Output vector of size_t. 0 if the edge is not in the MST.
+     *               The vector will be resized to match the input size.
+    static void mst(const std::vector<const geom::Curve*>& curves, std::vector<std::size_t>& result);
+} // namespace geos::operation::spanning
diff --git a/src/operation/spanning/SpanningTree.cpp b/src/operation/spanning/SpanningTree.cpp
index 000000000..41c12abf6
--- /dev/null
+++ b/src/operation/spanning/SpanningTree.cpp
@@ -0,0 +1,159 @@
+#include <geos/geom/Curve.h>
+#include <geos/geom/Point.h>
+#include <geos/geom/Coordinate.h>
+#include <vector>
+#include <algorithm>
+#include <unordered_map>
+#include <numeric>
+using namespace geos::geom;
+namespace geos {
+namespace {
+    // Internal edge representation for Kruskal's
+    struct MSTEdge {
+        std::size_t u;
+        std::size_t v;
+        double weight;
+        std::size_t originalIndex;
+    // Union-Find data structure using vector for efficiency
+    struct UnionFind {
+        std::vector<std::size_t> parent;
+        std::vector<int> rank;
+        UnionFind(std::size_t n) : parent(n), rank(n, 0) {
+            std::iota(parent.begin(), parent.end(), 0);
+        std::size_t find(std::size_t i) {
+            if (parent[i] == i)
+                return i;
+            else
+                parent[i] = find(parent[i]);
+            return parent[i]; // path compression
+        bool unite(std::size_t i, std::size_t j) {
+            std::size_t root_i = find(i);
+            std::size_t root_j = find(j);
+            if (root_i != root_j) {
+                // Union by rank
+                if (rank[root_i] < rank[root_j])
+                    parent[root_i] = root_j;
+                else if (rank[root_i] > rank[root_j])
+                    parent[root_j] = root_i;
+                else {
+                    rank[root_j]++;
+                return true;
+            return false;
+    // Helper for coordinate to node ID mapping
+    struct NodeMapping {
+        std::unordered_map<CoordinateXY, std::size_t, CoordinateXY::HashCode> coordToId;
+        std::size_t getId(const CoordinateXY& c) {
+            auto it = coordToId.find(c);
+            if (it != coordToId.end()) return it->second;
+            std::size_t id = coordToId.size();
+            coordToId[c] = id;
+            return id;
+        std::size_t size() const {
+            return coordToId.size();
+} // anonymous namespace
+void
+SpanningTree::mst(const std::vector<const geom::Curve*>& curves, std::vector<std::size_t>& result)
+    // Resize result to match input and initialize with 0
+    result.assign(curves.size(), 0);
+    if (curves.empty()) return;
+    NodeMapping mapping;
+    std::vector<MSTEdge> edges;
+    for (std::size_t i = 0; i < curves.size(); ++i) {
+        const Curve* curve = curves[i];
+        if (!curve || curve->isEmpty()) continue;
+        auto startPoint = curve->getStartPoint();
+        auto endPoint = curve->getEndPoint();
+        if (!startPoint || !endPoint) continue;
+        CoordinateXY startCoord(*(startPoint->getCoordinate()));
+        CoordinateXY endCoord(*(endPoint->getCoordinate()));
+        // Ignore zero-length edges (where start == end in 2D)
+        if (startCoord.equals2D(endCoord)) continue;
+        std::size_t u = mapping.getId(startCoord);
+        std::size_t v = mapping.getId(endCoord);
+        double length = curve->getLength();
+        edges.push_back({u, v, length, i});
+    if (edges.empty()) return;
+    // Sort edges by length
+    std::sort(edges.begin(), edges.end(), [](const MSTEdge& a, const MSTEdge& b) {
+        return a.weight < b.weight;
+    // Kruskal's algorithm
+    UnionFind uf(mapping.size());
+    std::vector<const MSTEdge*> treeEdges;
+    for (const auto& edge : edges) {
+        if (uf.unite(edge.u, edge.v)) {
+            treeEdges.push_back(&edge);
+    // Assign component IDs
+    std::size_t componentId = 0;
+    std::unordered_map<std::size_t, std::size_t> rootToComponentId;
+    for (const auto* edge : treeEdges) {
+        std::size_t root = uf.find(edge->u);
+        if (rootToComponentId.find(root) == rootToComponentId.end()) {
+            rootToComponentId[root] = ++componentId;
+        result[edge->originalIndex] = rootToComponentId[root];
diff --git a/tests/unit/capi/GEOSMinimumSpanningTreeTest.cpp b/tests/unit/capi/GEOSMinimumSpanningTreeTest.cpp
index 000000000..ce9b3f3cb
--- /dev/null
+++ b/tests/unit/capi/GEOSMinimumSpanningTreeTest.cpp
@@ -0,0 +1,175 @@
+// Test Suite for C-API GEOSMinimumSpanningTree
+#include <tut/tut.hpp>
+// geos
+#include <geos_c.h>
+#include <vector>
+#include "capi_test_utils.h"
+namespace tut {
+// Test Group
+// Common data used in test cases.
+struct test_capigeosmst_data : public capitest::utility {
+typedef test_group<test_capigeosmst_data> group;
+typedef group::object object;
+group test_capigeosmst_group("capi::GEOSMinimumSpanningTree");
+// Test Cases
+// Standard case
+template<>
+template<>
+void object::test<1> ()
+    constexpr int size = 3;
+    GEOSGeometry* geoms[size];
+    geoms[0] = GEOSGeomFromWKT("LINESTRING(0 0, 10 0)"); // 10
+    geoms[1] = GEOSGeomFromWKT("LINESTRING(10 0, 5 10)"); // ~11.18
+    geoms[2] = GEOSGeomFromWKT("LINESTRING(5 10, 0 0)"); // ~11.18
+    size_t* result = GEOSMinimumSpanningTree(geoms, size);
+    ensure(nullptr != result);
+    int count = 0;
+    for (int i = 0; i < size; ++i) {
+        if (result[i] > 0) count++;
+    ensure_equals(count, 2);
+    ensure(result[0] > 0); // Shortest edge must be in
+    // Check component IDs are same
+    size_t compId = 0;
+        if (result[i] > 0) {
+            if (compId == 0) compId = result[i];
+            else ensure_equals(result[i], compId);
+    GEOSFree(result);
+    for(auto& input : geoms) {
+        GEOSGeom_destroy(input);
+// Disconnected graph
+template<>
+template<>
+void object::test<2> ()
+    constexpr int size = 2;
+    geoms[1] = GEOSGeomFromWKT("LINESTRING(20 0, 30 0)");
+    ensure(result[1] > 0);
+    ensure(result[0] != result[1]);
+    GEOSFree(result);
+// Mixed inputs (non-linestrings)
+template<>
+template<>
+void object::test<3> ()
+    geoms[1] = GEOSGeomFromWKT("POINT(5 5)");
+    geoms[2] = GEOSGeomFromWKT("POLYGON((0 0, 1 0, 1 1, 0 1, 0 0))");
+    ensure_equals(result[1], 0u);
+    ensure_equals(result[2], 0u);
+    GEOSFree(result);
+// Empty input
+template<>
+template<>
+void object::test<4> ()
+    size_t* result = GEOSMinimumSpanningTree(nullptr, 0);
+    ensure(nullptr == result);
+// Null array entries
+template<>
+template<>
+void object::test<5> ()
+    geoms[1] = 0;
+    GEOSFree(result);
+    GEOSGeom_destroy(geoms[0]);
+// Curved inputs
+template<>
+template<>
+void object::test<6> ()
+    geoms[0] = GEOSGeomFromWKT("CIRCULARSTRING(0 0, 5 5, 10 0)");
+    geoms[1] = GEOSGeomFromWKT("COMPOUNDCURVE((10 0, 10 10), CIRCULARSTRING(10 10, 5 15, 0 10), (0 10, 0 0))");
+    // Forms a loop, MST should pick one.
+    int count = 0;
+    ensure_equals(count, 1);
+    GEOSFree(result);
+} // namespace tut
diff --git a/tests/unit/operation/spanning/SpanningTreeTest.cpp b/tests/unit/operation/spanning/SpanningTreeTest.cpp
index 000000000..e12fb6052
--- /dev/null
+++ b/tests/unit/operation/spanning/SpanningTreeTest.cpp
@@ -0,0 +1,308 @@
+// Test Suite for geos::operation::spanning::SpanningTree class.
+// tut
+// geos
+#include <geos/io/WKTReader.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/LineString.h>
+#include <geos/geom/GeometryCollection.h>
+// std
+#include <memory>
+#include <string>
+#include <vector>
+#include <numeric>
+#include <set>
+namespace tut {
+// Test Group
+// Common data used by tests
+struct test_spanning_data {
+    geos::io::WKTReader wktreader;
+    test_spanning_data()
+        : wktreader()
+    std::unique_ptr<geos::geom::Geometry>
+    readWKT(const std::string& inputWKT)
+        return std::unique_ptr<geos::geom::Geometry>(wktreader.read(inputWKT));
+    std::vector<const geos::geom::Curve*>
+    toCurves(const geos::geom::Geometry* geom) {
+        std::vector<const geos::geom::Curve*> curves;
+        if (const geos::geom::GeometryCollection* gc = dynamic_cast<const geos::geom::GeometryCollection*>(geom)) {
+            for (std::size_t i = 0; i < gc->getNumGeometries(); ++i) {
+                if (const geos::geom::Curve* c = dynamic_cast<const geos::geom::Curve*>(gc->getGeometryN(i))) {
+                    curves.push_back(c);
+        } else if (const geos::geom::Curve* c = dynamic_cast<const geos::geom::Curve*>(geom)) {
+        return curves;
+typedef test_group<test_spanning_data> group;
+group test_spanning_group("geos::operation::spanning::SpanningTree");
+// Test Cases
+// Basic triangle test
+template<> template<>
+void object::test<1>()
+    // Triangle with side lengths 10, ~11.18, ~11.18
+    // MST should pick the shortest edge (10) and one of the others.
+    // Lengths:
+    // 0: (0 0, 10 0) -> 10
+    // 1: (10 0, 5 10) -> sqrt(25+100) = 11.18
+    // 2: (5 10, 0 0) -> sqrt(25+100) = 11.18
+    std::string wkt = "MULTILINESTRING((0 0, 10 0), (10 0, 5 10), (5 10, 0 0))";
+    auto geom = readWKT(wkt);
+    auto curves = toCurves(geom.get());
+    geos::operation::spanning::SpanningTree::mst(curves, result);
+    ensure_equals(result.size(), 3u);
+    // Count edges in MST (should be 2)
+    int count = 0;
+    for (std::size_t r : result) {
+        if (r > 0) count++;
+    // Edge 0 (length 10) must be included
+    // Component IDs should be the same (connected graph)
+    std::size_t compId = result[0];
+        if (r > 0) ensure_equals(r, compId);
+void object::test<2>()
+    std::string wkt = "MULTILINESTRING((0 0, 10 0), (20 0, 30 0))";
+    ensure_equals(result.size(), 2u);
+    // Should be different components
+// Complex graph
+void object::test<3>()
+    std::string wkt = "MULTILINESTRING("
+        "(0 0, 10 0), (10 0, 10 10), (10 10, 0 10), (0 10, 0 0), " // 0-3: Sides (10)
+        "(0 0, 10 10), (10 0, 0 10))"; // 4-5: Diagonals (~14.14)
+    ensure_equals(result.size(), 6u);
+    int count = 0;
+    std::set<std::size_t> components;
+        if (r > 0) {
+            count++;
+            components.insert(r);
+    // A square with 2 diagonals has 4 vertices. MST should have 3 edges.
+    // Wait, 4 edges for square + 2 diagonals = 6 edges.
+    // Vertices: 4.
+    // MST edges = Vertices - 1 = 3.
+    // result should have 3 non-zero entries.
+    ensure_equals(count, 3);
+    // Should be 1 component
+    ensure_equals(components.size(), 1u);
+    // Diagonals should not be included as they are longer
+    ensure_equals(result[4], 0u);
+    ensure_equals(result[5], 0u);
+// Empty input
+void object::test<4>()
+    ensure(result.empty());
+// Null pointers and empty geometries
+void object::test<5>()
+    auto factory = geos::geom::GeometryFactory::create();
+    auto empty = factory->createLineString();
+    curves.push_back(nullptr);
+    curves.push_back(empty.get());
+    ensure_equals(result[0], 0u);
+// Short lines (zero length) - should be ignored
+void object::test<6>()
+    std::string wkt = "MULTILINESTRING((0 0, 0 0))";
+    ensure_equals(result.size(), 1u);
+// Loops (start == end)
+void object::test<7>()
+    std::string wkt = "MULTILINESTRING((0 0, 10 10, 0 0))";
+    // A single loop doesn't form a tree with 2 nodes?
+    // Actually, start and end are the same node. So 1 node, 1 edge.
+    // Kruskal: find(start) == find(end), so not included.
+// Multi-edges (two edges between same nodes)
+void object::test<8>()
+    std::string wkt = "MULTILINESTRING((0 0, 10 0), (0 0, 10 0))";
+    // One should be in, one out.
+    int count = 0;
+    for (std::size_t r : result) if (r > 0) count++;
+// Mixed Curved geometries
+void object::test<9>()
+    std::string wkt = "GEOMETRYCOLLECTION("
+        "CIRCULARSTRING(0 0, 5 5, 10 0),"
+        "LINESTRING(10 0, 10 10),"
+        "COMPOUNDCURVE(CIRCULARSTRING(10 10, 5 15, 0 10), (0 10, 0 0))"
+    ensure_equals(curves.size(), 3u);
+    int count = 0;
+    // Debug:
+    // for (std::size_t i = 0; i < curves.size(); ++i) {
+    //    std::cout << "Curve " << i << " length=" << curves[i]->getLength() << " result=" << result[i] << std::endl;
+    // Geometries:
+    // C0: (0,0) -> (10,0) via (5,5). Length: PI*5 ~= 15.7
+    // C1: (10,0) -> (10,10). Length: 10
+    // C2: (10,10) -> (0,0) via (5,15) and (0,10).
+    //     Part 1: (10,10) -> (0,10) via (5,15). Length: PI*5 ~= 15.7
+    //     Part 2: (0,10) -> (0,0). Length: 10
+    //     Total C2 length ~= 25.7
+    // Nodes: (0,0), (10,0), (10,10).
+    // Wait, (0,10) is NOT a node because it's INTERNAL to COMPOUNDCURVE C2.
+    // So we have 3 nodes: N0(0,0), N1(10,0), N2(10,10).
+    // Edges:
+    // E0: N0-N1 (Length 15.7)
+    // E1: N1-N2 (Length 10)
+    // E2: N2-N0 (Length 25.7)
+    // MST should pick E1 (10) and E0 (15.7). Total 2 edges.
+    // My expectation of 3 was wrong because I thought there were 4 nodes.
+// Simple square
+void object::test<10>()
+    std::string wkt = "MULTILINESTRING((0 0,1 0),(1 1,1 0),(0 0,1 1),(0 0,0 1),(1 1,0 1),(1 0,0 1))";
+    // MULTILINESTRING((0 0,1 0),(1 1,1 0),(0 0,0 1))
+    int count = 0;
+        //std::cout << r << std::endl;
+} // namespace tut
commit 224d1448e5086c2f0017c4c58b05a25823d27173
Date:   Tue Mar 31 15:16:07 2026 -0700
    Squashed commit of the following:
    commit b3c8a8b4d269c9359c3cec2f5fdfac4e6626d3ec
    Merge: cc404b809 8b2ee5e04
    Date:   Tue Mar 31 15:11:14 2026 -0700
        Merge branch 'main' into main-coverage-edges
    commit cc404b80924b97eed4b3ff43ea0c7ae312696b32
    Date:   Tue Mar 31 13:44:42 2026 -0700
        change API slightly
    commit bb1bfbcc25ae194d82d32a4d108102959fa9f804
    Date:   Mon Mar 30 16:59:09 2026 -0700
        CoverageEdges first draft
    Add
    extern GEOSGeometry GEOS_DLL *GEOSCoverageEdges(const GEOSGeometry *input, int edgetype)
    which returns the edges of a polygonal coverage. With edgetype == 0 all edges
    are returned, edgetype == 1 just exterior, edgetype == 2 just interior edges.
diff --git a/NEWS.md b/NEWS.md
index 3f8bf9b43..79fb62aa5 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -3,6 +3,7 @@
 2026-xx-xx
 - New things:
+  - Add GEOSCoverageEdges (Paul Ramsey)
   - Add new C API functions for Hausdorff distance (GH-1352, Sven Jensen)
   - Add GEOSSubdivideByGrid (GH-1232, Dan Baston)
index e74070e3e..54d29bba9 100644
@@ -1100,6 +1100,15 @@ extern "C" {
             handle, input);
+    GEOSGeometry *
+    GEOSCoverageEdges(
+        const GEOSGeometry * input,
+        int edgetype)
+        return GEOSCoverageEdges_r(
+            handle, input, edgetype);
     Geometry*
     GEOSRemoveRepeatedPoints(
         const Geometry* g,
index 1116b0024..b38029835 100644
@@ -938,6 +938,13 @@ GEOSCoverageSimplifyVW_r(
     double tolerance,
     int preserveBoundary);
+/** \see GEOSCoverageEdges */
+extern GEOSGeometry GEOS_DLL *
+GEOSCoverageEdges_r(
+    const GEOSGeometry* input,
+    int edgetype);
 /** \see GEOSCoverageCleanParams_create */
 extern GEOSCoverageCleanParams GEOS_DLL *
 GEOSCoverageCleanParams_create_r(
@@ -4630,8 +4637,18 @@ extern GEOSGeometry GEOS_DLL * GEOSCoverageSimplifyVW(
-* Create a default GEOSCoverageCleanParams object for controlling
-* the way invalid polygon interactions are repaired by \ref GEOSCoverageCleanWithParams.
+ * Returns a MultiLineString representing the unique edges of a polygonal coverage.
+ * \param input a GeometryCollection or MultiPolygon representing the coverage.
+ * \param edgetype selection type: 0 = ALL, 1 = EXTERIOR (non-shared), 2 = INTERIOR (shared).
+ * \return a MultiLineString of unique edges, or NULL on error.
+ * \since 3.15
+extern GEOSGeometry GEOS_DLL *GEOSCoverageEdges(const GEOSGeometry *input, int edgetype);
+ * Create a default GEOSCoverageCleanParams object for controlling* the way invalid polygon interactions are repaired by \ref GEOSCoverageCleanWithParams.
 * \return A newly allocated GEOSCoverageCleanParams. NULL on exception.
 * Caller is responsible for freeing with GEOSCoverageCleanParams_destroy().
index e57a00343..05c83acdf 100644
@@ -28,6 +28,7 @@
 #include <geos/algorithm/distance/DiscreteFrechetDistance.h>
 #include <geos/algorithm/hull/ConcaveHull.h>
 #include <geos/algorithm/hull/ConcaveHullOfPolygons.h>
+#include <geos/coverage/CoverageEdges.h>
 #include <geos/coverage/CoverageCleaner.h>
 #include <geos/coverage/CoverageSimplifier.h>
 #include <geos/coverage/CoverageUnion.h>
@@ -4817,5 +4818,16 @@ extern "C" {
         return GEOSCoverageCleanWithParams_r(extHandle, input, nullptr);
+    GEOSGeometry *
+    GEOSCoverageEdges_r(GEOSContextHandle_t extHandle,
+        int edgetype)
+        using geos::coverage::CoverageEdges;
+        return execute(extHandle, [&]() -> Geometry* {
+            return CoverageEdges::GetEdges(input, edgetype).release();
 } /* extern "C" */
diff --git a/include/geos/coverage/CoverageEdges.h b/include/geos/coverage/CoverageEdges.h
index 000000000..b1b6a847a
--- /dev/null
+++ b/include/geos/coverage/CoverageEdges.h
@@ -0,0 +1,61 @@
+ * Copyright (C) 2026 Paul Ramsey <pramsey at cleverelephant.ca>
+#pragma once
+#include <memory>
+#include <vector>
+namespace geos {
+namespace geom {
+class Geometry;
+namespace geos {      // geos
+namespace coverage { // geos::coverage
+ * Utility to extract unique edges from a polygonal coverage.
+ * @author Paul Ramsey
+class GEOS_DLL CoverageEdges {
+public:
+    * @param coverage a vector of polygons in the coverage
+    * @param type selection type: 0 = ALL, 1 = EXTERIOR (non-shared), 2 = INTERIOR (shared)
+    * @return a MultiLineString of unique edges
+    static std::unique_ptr<geom::Geometry> GetEdges(const std::vector<const geom::Geometry*>& coverage, int type = 0);
+    * @param coverage a GeometryCollection or MultiPolygon representing the coverage
+    static std::unique_ptr<geom::Geometry> GetEdges(const geom::Geometry* coverage, int type = 0);
+} // namespace geos::coverage
diff --git a/src/coverage/CoverageEdges.cpp b/src/coverage/CoverageEdges.cpp
index 000000000..3c2dd6933
--- /dev/null
+++ b/src/coverage/CoverageEdges.cpp
@@ -0,0 +1,76 @@
+#include <geos/coverage/CoverageRingEdges.h>
+#include <geos/coverage/CoverageEdge.h>
+#include <geos/geom/MultiLineString.h>
+#include <geos/geom/util/PolygonExtracter.h>
+/* public static */
+std::unique_ptr<geom::Geometry>
+CoverageEdges::GetEdges(const std::vector<const geom::Geometry*>& coverage, int type)
+    if (coverage.empty()) {
+        return nullptr;
+    const geom::GeometryFactory* factory = coverage[0]->getFactory();
+    CoverageRingEdges cre(coverage);
+    std::vector<CoverageEdge*> selectedEdges;
+    for (auto* edge : cre.getEdges()) {
+        if (type == 2) { // INTERIOR
+            if (edge->getRingCount() > 1)
+                selectedEdges.push_back(edge);
+        else if (type == 1) { // EXTERIOR
+            if (edge->getRingCount() == 1)
+        else { // ALL (0 and default)
+    return CoverageEdge::createLines(selectedEdges, factory);
+CoverageEdges::GetEdges(const geom::Geometry* input, int type)
+    std::vector<const geom::Polygon*> polygons;
+    geom::util::PolygonExtracter::getPolygons(*input, polygons);
+    if (polygons.empty()) {
+        return input->getFactory()->createMultiLineString();
+    std::vector<const geom::Geometry*> coverage;
+    for (const auto* poly : polygons) {
+        coverage.push_back(poly);
+    return GetEdges(coverage, type);
diff --git a/tests/unit/capi/GEOSCoverageEdgesTest.cpp b/tests/unit/capi/GEOSCoverageEdgesTest.cpp
index 000000000..c2ca7046d
--- /dev/null
+++ b/tests/unit/capi/GEOSCoverageEdgesTest.cpp
@@ -0,0 +1,51 @@
+// Test Suite for GEOSCoverageEdges CAPI function.
+// geos
+namespace tut {
+// Test Group
+// Common data used by all tests
+struct test_geoscoverageedges_data : public capitest::utility
+    test_geoscoverageedges_data() {}
+typedef test_group<test_geoscoverageedges_data> group;
+group test_geoscoverageedges_data("capi::GEOSCoverageEdges");
+// testTwoAdjacentInterior
+template<>
+template<>
+    input_ = fromWKT("GEOMETRYCOLLECTION (POLYGON ((1 1, 1 6, 6 5, 9 6, 9 1, 1 1)), POLYGON ((1 9, 6 9, 6 5, 1 6, 1 9)))");
+    result_ = GEOSCoverageEdges(input_, 2); // INTERIOR
+    expected_ = fromWKT("MULTILINESTRING ((1 6, 6 5))");
+    ensure_geometry_equals(result_, expected_);
+// testTwoAdjacentExterior
+template<>
+template<>
+    result_ = GEOSCoverageEdges(input_, 1); // EXTERIOR
+    expected_ = fromWKT("MULTILINESTRING ((1 6, 1 1, 9 1, 9 6, 6 5), (1 6, 1 9, 6 9, 6 5))");
+} // namespace tut
diff --git a/tests/unit/coverage/CoverageEdgesTest.cpp b/tests/unit/coverage/CoverageEdgesTest.cpp
index 000000000..1f3f520da
--- /dev/null
+++ b/tests/unit/coverage/CoverageEdgesTest.cpp
@@ -0,0 +1,113 @@
+// Test Suite for geos::coverage::CoverageEdges class.
+#include <utility.h>
+// geos
+using geos::coverage::CoverageEdges;
+namespace tut {
+// Test Group
+struct test_coverageedges_data
+    WKTReader r;
+    WKTWriter w;
+    test_coverageedges_data() {
+    void
+    checkEdges(const std::string& wkt, int type, const std::string& wktExpected)
+        std::unique_ptr<Geometry> geom = r.read(wkt);
+        std::unique_ptr<Geometry> edgeLines = CoverageEdges::GetEdges(geom.get(), type);
+        std::unique_ptr<Geometry> expected = r.read(wktExpected);
+        ensure_equals_geometry(edgeLines.get(), expected.get());
+typedef test_group<test_coverageedges_data> group;
+group test_coverageedges_data("geos::coverage::CoverageEdges");
+// testTwoAdjacentAll
+template<>
+template<>
+    checkEdges(
+        "GEOMETRYCOLLECTION (POLYGON ((1 1, 1 6, 6 5, 9 6, 9 1, 1 1)), POLYGON ((1 9, 6 9, 6 5, 1 6, 1 9)))",
+        0,
+        "MULTILINESTRING ((1 6, 1 1, 9 1, 9 6, 6 5), (1 6, 1 9, 6 9, 6 5), (1 6, 6 5))"
+template<>
+template<>
+    checkEdges(
+        2, // INTERIOR
+        "MULTILINESTRING ((1 6, 6 5))"
+template<>
+template<>
+    checkEdges(
+        1, // EXTERIOR
+        "MULTILINESTRING ((1 6, 1 1, 9 1, 9 6, 6 5), (1 6, 1 9, 6 9, 6 5))"
+// testAdjacentSquaresInterior
+template<>
+template<>
+    std::string wkt = "GEOMETRYCOLLECTION (POLYGON ((1 3, 2 3, 2 2, 1 2, 1 3)), POLYGON ((3 3, 3 2, 2 2, 2 3, 3 3)), POLYGON ((3 1, 2 1, 2 2, 3 2, 3 1)), POLYGON ((1 1, 1 2, 2 2, 2 1, 1 1)))";
+    checkEdges(wkt, 2, // INTERIOR
+        "MULTILINESTRING ((1 2, 2 2), (2 1, 2 2), (2 2, 2 3), (2 2, 3 2))");
+// testTouchingAtPointInterior
+template<>
+template<>
+    // Two polygons touching only at a point (1 1)
+    std::string wkt = "GEOMETRYCOLLECTION (POLYGON ((0 0, 0 1, 1 1, 1 0, 0 0)), POLYGON ((1 1, 1 2, 2 2, 2 1, 1 1)))";
+        "MULTILINESTRING EMPTY");
+// testTouchingAtPointExterior
+template<>
+template<>
+    checkEdges(wkt, 1, // EXTERIOR
+        "MULTILINESTRING ((0 0, 0 1, 1 1, 1 0, 0 0), (1 1, 1 2, 2 2, 2 1, 1 1))");
+} // namespace tut
Summary of changes:
 NEWS.md                                            |   1 +
 capi/geos_c.cpp                                    |  15 +
 capi/geos_c.h.in                                   |  48 +++-
 capi/geos_ts_c.cpp                                 |  53 ++++
 include/geos/coverage/CoverageEdges.h              |  61 ++++
 include/geos/operation/spanning/SpanningTree.h     |  59 ++++
 src/coverage/CoverageEdges.cpp                     |  76 +++++
 src/operation/spanning/SpanningTree.cpp            | 159 +++++++++++
 tests/unit/capi/GEOSCoverageEdgesTest.cpp          |  51 ++++
 tests/unit/capi/GEOSMinimumSpanningTreeTest.cpp    | 175 ++++++++++++
 tests/unit/coverage/CoverageEdgesTest.cpp          | 113 ++++++++
 tests/unit/operation/spanning/SpanningTreeTest.cpp | 308 +++++++++++++++++++++
 12 files changed, 1115 insertions(+), 4 deletions(-)
 create mode 100644 include/geos/coverage/CoverageEdges.h
 create mode 100644 include/geos/operation/spanning/SpanningTree.h
 create mode 100644 src/coverage/CoverageEdges.cpp
 create mode 100644 src/operation/spanning/SpanningTree.cpp
 create mode 100644 tests/unit/capi/GEOSCoverageEdgesTest.cpp
 create mode 100644 tests/unit/capi/GEOSMinimumSpanningTreeTest.cpp
 create mode 100644 tests/unit/coverage/CoverageEdgesTest.cpp
 create mode 100644 tests/unit/operation/spanning/SpanningTreeTest.cpp
hooks/post-receive
More information about the geos-commits mailing list
