[geos-commits] [SCM] GEOS branch main updated. 159cc1f9dba3ee820e31123af4f90a2b6e090546
git at osgeo.org
git at osgeo.org
Sun Nov 1 18:52:09 PST 2026
the project "GEOS".
The branch, main has been updated
via 159cc1f9dba3ee820e31123af4f90a2b6e090546 (commit)
via 080bf38feb81ffae17dd6d7e48b7601e468ef1b0 (commit)
via 1c29a5fa73afabaa78d4310ea48187097723611b (commit)
from 1441ad5b48a86e8ff99a2f693fe777377d0f766f (commit)
revisions in full, below.
commit 159cc1f9dba3ee820e31123af4f90a2b6e090546
Author: Alejandro Pacheco <ale at alepacheco.dev>
Date: Thu Oct 29 07:27:45 2026 +0100
CircularArc: fix copy assignment of arc not starting at position 0
The copy assignment operator copied the three points of the arc into a
new CoordinateSequence, but kept the position of the arc in the original
sequence, so an arc assigned from one that did not start at position 0
referred to points past the end of its copy.
Implement copy assignment with the copy constructor and move assignment.
diff --git a/src/geom/CircularArc.cpp b/src/geom/CircularArc.cpp
index 44414c0ad..1ae2e9e9f 100644
--- a/src/geom/CircularArc.cpp
+++ b/src/geom/CircularArc.cpp
@@ -145,28 +145,10 @@ CircularArc::CircularArc(CircularArc&& other) noexcept {
CircularArc&
CircularArc::operator=(const CircularArc& other)
- if (this == &other) {
- return *this;
+ if (this != &other) {
+ *this = CircularArc(other);
- if (m_own_coordinates) {
- delete m_seq;
- m_seq = new CoordinateSequence(0, other.getCoordinateSequence()->hasZ(), other.getCoordinateSequence()->hasM());
- m_pos = other.m_pos;
- m_own_coordinates = true;
- m_orientation = other.m_orientation;
- m_orientation_known = other.m_orientation_known;
- m_center = other.m_center;
- m_center_known = other.m_center_known;
- m_radius = other.m_radius;
- m_radius_known = other.m_radius_known;
- CoordinateSequence* seq = const_cast<CoordinateSequence*>(m_seq);
- seq->reserve(3);
- seq->add(*other.getCoordinateSequence(), other.getCoordinatePosition(), other.getCoordinatePosition() + 2);
return *this;
diff --git a/tests/unit/geom/CircularArcTest.cpp b/tests/unit/geom/CircularArcTest.cpp
index 47078db1f..3d33a3110 100644
--- a/tests/unit/geom/CircularArcTest.cpp
+++ b/tests/unit/geom/CircularArcTest.cpp
@@ -3,6 +3,7 @@
#include <geos/algorithm/Orientation.h>
#include <geos/geom/Coordinate.h>
#include <geos/geom/CircularArc.h>
+#include <geos/geom/CoordinateSequence.h>
#include <geos/constants.h>
using geos::geom::CoordinateXY;
@@ -176,4 +177,31 @@ void object::test<7>() {
+template<>
+template<>
+void object::test<8>() {
+ set_test_name("copy assignment from arc that does not start at the beginning of its CoordinateSequence");
+ CoordinateSequence seq{
+ CoordinateXY(0, 0),
+ CoordinateXY(1, 1),
+ CoordinateXY(2, 0),
+ CoordinateXY(3, -1),
+ CoordinateXY(4, 0)
+ CircularArc second(seq, 2);
+ CircularArc arc = CircularArc::create(CoordinateXY(0, 0), CoordinateXY(1, 1), CoordinateXY(2, 0));
+ arc = second;
+ ensure_equals(arc.p0(), CoordinateXY(2, 0));
+ ensure_equals(arc.p1(), CoordinateXY(3, -1));
+ ensure_equals(arc.p2(), CoordinateXY(4, 0));
+ // arc has its own copy of the points
+ seq.setAt(CoordinateXY(5, 5), 2);
commit 080bf38feb81ffae17dd6d7e48b7601e468ef1b0
CompoundCurve: update component curves in geometryChanged()
CompoundCurve::geometryChangedAction() recomputed its envelope from the
envelopes of its component curves, but those curves are not visited by
apply_rw(GeometryComponentFilter*), so their envelopes (and the cached
arcs of a CircularString) were not updated. After apply_rw() and
geometryChanged(), as done by GEOSGeom_transformXY, a CompoundCurve kept
the envelope of its original coordinates.
Call geometryChanged() on each component curve before recomputing the
envelope.
diff --git a/include/geos/geom/CompoundCurve.h b/include/geos/geom/CompoundCurve.h
index d090be2af..50146b8bb 100644
--- a/include/geos/geom/CompoundCurve.h
+++ b/include/geos/geom/CompoundCurve.h
@@ -119,6 +119,11 @@ protected:
void geometryChangedAction() override
+ // The component curves are not visited by apply_rw(GeometryComponentFilter*),
+ // so update them before computing the envelope from theirs.
+ for (auto& curve : curves) {
+ curve->geometryChanged();
envelope = computeEnvelopeInternal();
diff --git a/tests/unit/geom/CompoundCurveTest.cpp b/tests/unit/geom/CompoundCurveTest.cpp
index d6f5cbfde..040f3fd8d 100644
--- a/tests/unit/geom/CompoundCurveTest.cpp
+++ b/tests/unit/geom/CompoundCurveTest.cpp
@@ -454,4 +454,30 @@ void object::test<13>()
ensure_equals_exact_geometry_xyzm(curved.get(), cc_.get(), 0);
+template<>
+template<>
+void object::test<14>()
+ set_test_name("getEnvelopeInternal() after apply_rw(const CoordinateFilter*) and geometryChanged()");
+ struct TranslateFilter : public geos::geom::CoordinateFilter {
+ void filter_rw(CoordinateXY* c) const override
+ c->x += 10;
+ TranslateFilter filter;
+ cc_->apply_rw(&filter);
+ cc_->geometryChanged();
+ auto expected = wktreader_.read<CompoundCurve>("COMPOUNDCURVE(CIRCULARSTRING(10 0, 11 1, 12 0), (12 0, 12 2))");
+ ensure_equals(*cc_->getEnvelopeInternal(), *expected->getEnvelopeInternal());
+ for (std::size_t i = 0; i < cc_->getNumCurves(); i++) {
+ ensure_equals(*cc_->getCurveN(i)->getEnvelopeInternal(), *expected->getCurveN(i)->getEnvelopeInternal());
+ ensure_equals("length", cc_->getLength(), expected->getLength(), 1e-12);
commit 1c29a5fa73afabaa78d4310ea48187097723611b
CircularString: clear cached arcs when coordinates change
CircularString::getArcs() caches CircularArcs that refer to positions in
the CircularString's CoordinateSequence and cache their center, radius
and orientation. The cache was cleared when normalize() reversed an open
CircularString, but not when:
- normalize() of a closed CircularString replaced the CoordinateSequence
to change the start point, or reversed it
- apply_rw() modified the coordinates, or first replaced a shared
CoordinateSequence with a copy
- geometryChanged() was called after an external change
In these cases the arcs described the old coordinates, or referred to a
CoordinateSequence that had since been freed. For example, the length of
a CircularString returned by GEOSGeom_transformXY could be the length of
its input, and calling GEOSNormalize on a closed CircularString after
GEOSLength left its arcs referring to freed memory.
Clear the cache in each of these cases. The apply_rw() overloads are
overridden because SimpleCurve::apply_rw() can replace shared coordinates
before the caller has a chance to call geometryChanged().
diff --git a/NEWS.md b/NEWS.md
index a6510e8d4..dc9ffb1fb 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -10,6 +10,7 @@
- GeometrySplitter: Allow splitting a MultiSurface (GH-1520, Dan Baston)
- GEOSGridIntersectionFractions: Set cells outside geometry bounding box to zero (GH-1532, Dan Baston)
- GEOSisSimpleDetail returns locations with input SRID (Sandro Santilli)
+ - CircularString: clear cached arcs when coordinates change (Alejandro Pacheco)
- New things:
- Expose code revision: GEOS_REVISION, GEOSrevision, geos-config --revision
diff --git a/include/geos/geom/CircularString.h b/include/geos/geom/CircularString.h
index af5fb6555..fd282f180 100644
--- a/include/geos/geom/CircularString.h
+++ b/include/geos/geom/CircularString.h
@@ -25,11 +25,16 @@ class GEOS_DLL CircularString : public SimpleCurve {
public:
using SimpleCurve::SimpleCurve;
+ using SimpleCurve::apply_rw;
friend class GeometryFactory;
~CircularString() override;
+ void apply_rw(const CoordinateFilter* filter) override;
+ void apply_rw(CoordinateSequenceFilter& filter) override;
std::unique_ptr<CircularString> clone() const;
const std::vector<CircularArc>& getArcs() const;
@@ -82,6 +87,7 @@ protected:
envelope = computeEnvelopeInternal(false);
+ arcs.clear();
CircularString* getCurvedImpl(const algorithm::LineToCurveParams&) const override {
@@ -105,6 +111,9 @@ private:
void normalizeClosed();
+ /// Arcs describing `points`, created on demand by getArcs(). They refer to
+ /// positions in `points` (or, in a copy, to copies of the points of the
+ /// original) and must be cleared whenever `points` is replaced or modified.
mutable std::vector<CircularArc> arcs;
diff --git a/src/geom/CircularString.cpp b/src/geom/CircularString.cpp
index 400094df8..4ec463453 100644
--- a/src/geom/CircularString.cpp
+++ b/src/geom/CircularString.cpp
@@ -40,6 +40,22 @@ CircularString::CircularString(const std::shared_ptr<const CoordinateSequence>&
CircularString::~CircularString() = default;
+// SimpleCurve::apply_rw may replace shared coordinates with a copy, and
+// callers are not required to call geometryChanged(), so clear the arcs here.
+void
+CircularString::apply_rw(const CoordinateFilter* filter)
+ arcs.clear();
+ SimpleCurve::apply_rw(filter);
+void
+CircularString::apply_rw(CoordinateSequenceFilter& filter)
+ arcs.clear();
CircularString::clone() const
@@ -145,11 +161,13 @@ CircularString::normalizeClosed() {
coords->reverse();
points = std::move(coords);
+ arcs.clear();
} else if (reverse) {
if (points.use_count() > 1) {
points = points->clone();
const_cast<CoordinateSequence*>(points.get())->reverse();
+ arcs.clear();
diff --git a/tests/unit/geom/CircularStringTest.cpp b/tests/unit/geom/CircularStringTest.cpp
index 3be6a7b7e..41cf5a77d 100644
--- a/tests/unit/geom/CircularStringTest.cpp
+++ b/tests/unit/geom/CircularStringTest.cpp
@@ -6,7 +6,9 @@
#include <geos/geom/CircularString.h>
#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/CoordinateFilter.h>
+#include <geos/geom/CoordinateSequenceFilter.h>
#include <geos/geom/IntersectionMatrix.h>
#include <geos/io/WKTReader.h>
#include <geos/util/UnsupportedOperationException.h>
@@ -50,6 +52,29 @@ struct test_circularstring_data {
ensure_equals_exact_geometry_xyzm(cs.get(), expected.get(), 0);
+ // Check that the arcs of a CircularString refer to its current coordinates and
+ // match the arcs of a new CircularString created from the same coordinates.
+ void checkArcs(const CircularString& cs) const {
+ auto expected = factory_->createCircularString(*cs.getCoordinatesRO());
+ const auto& arcs = cs.getArcs();
+ const auto& expectedArcs = expected->getArcs();
+ ensure_equals("number of arcs", arcs.size(), expectedArcs.size());
+ for (std::size_t i = 0; i < arcs.size(); i++) {
+ ensure("arc refers to coordinates of CircularString", arcs[i].getCoordinateSequence() == cs.getCoordinatesRO());
+ ensure_equals("arc position", arcs[i].getCoordinatePosition(), 2*i);
+ ensure_equals_xy(arcs[i].p0(), expectedArcs[i].p0());
+ ensure_equals_xy(arcs[i].p1(), expectedArcs[i].p1());
+ ensure_equals_xy(arcs[i].p2(), expectedArcs[i].p2());
+ ensure_equals("orientation", arcs[i].getOrientation(), expectedArcs[i].getOrientation());
+ ensure_equals_xy(arcs[i].getCenter(), expectedArcs[i].getCenter());
+ ensure_equals("radius", arcs[i].getRadius(), expectedArcs[i].getRadius());
+ ensure_equals("length", cs.getLength(), expected->getLength());
void checkLinearizeMaxDeviation(const std::string& wkt_in, const std::string& wkt_expected, double maxDeviation, double tol=1e-12) {
auto ctl = CurveToLineParams::maxDeviation(maxDeviation);
checkLinearize(wkt_in, wkt_expected, ctl, tol);
@@ -535,4 +560,149 @@ void object::test<27>()
ensure_equals_xyzm(seq->getAt<XYZM>(5), XYZM{2.5, -4.33, 6 + (30.0 - 6)*(2.0/3), 8 + (40.0 - 8)*(2.0/3)}, 1e-3);
+template<>
+template<>
+void object::test<28>()
+ set_test_name("getArcs() after normalize() of closed CircularString");
+ for (const char* wkt : {
+ // circle, start point is OK but need to reverse points
+ "CIRCULARSTRING (-5 0, 0 -5, 5 0, 0 5, -5 0)",
+ // circle, need to change start point but orientation is OK
+ "CIRCULARSTRING (5 0, 0 -5, -5 0, 0 5, 5 0)",
+ // circle, need to change start point and orientation
+ "CIRCULARSTRING (5 0, 0 5, -5 0, 0 -5, 5 0)",
+ // half-moon, start point is OK but need to make CW
+ "CIRCULARSTRING (0 0, -3 5, 0 10, -5 5, 0 0)",
+ // half-moon, need to change start point but orientation is OK
+ "CIRCULARSTRING (0 10, -3 5, 0 0, -5 5, 0 10)"
+ auto cs = wktreader_.read<CircularString>(wkt);
+ cs->getLength(); // create arcs, computing their center, radius and orientation
+ cs->normalize();
+ checkArcs(*cs);
+template<>
+template<>
+void object::test<29>()
+ set_test_name("getArcs() after normalize() of closed CircularString with shared coordinates");
+ // start point is OK but need to reverse points
+ // need to change start point but orientation is OK
+ // need to change start point and orientation
+ auto other = wktreader_.read<CircularString>(wkt);
+ auto cs = factory_->createCircularString(other->getSharedCoordinates());
+ cs->normalize();
+ other.reset(); // destroy the coordinates used by cs before normalize()
+ checkArcs(*cs);
+template<>
+template<>
+void object::test<30>()
+ set_test_name("getArcs() after apply_rw(const CoordinateFilter*)");
+ struct ScaleFilter : public geos::geom::CoordinateFilter {
+ void filter_rw(XY* c) const override
+ c->x *= 2;
+ c->y *= 2;
+ ScaleFilter filter;
+ // coordinates modified in place
+ cs_->getLength(); // create arcs, computing their center, radius and orientation
+ cs_->apply_rw(&filter);
+ checkArcs(*cs_);
+ // coordinates copied before modification because they are shared
+ auto cs = factory_->createCircularString(cs_->getSharedCoordinates());
+ cs->apply_rw(&filter);
+ checkArcs(*cs);
+ cs_.reset(); // destroy the coordinates used by cs before apply_rw()
+ checkArcs(*cs);
+ // arcs copied by clone()
+ auto copy = cs->clone();
+ copy->apply_rw(&filter);
+ checkArcs(*copy);
+template<>
+template<>
+void object::test<31>()
+ set_test_name("getArcs() after apply_rw(CoordinateSequenceFilter&)");
+ struct ScaleFilter : public geos::geom::CoordinateSequenceFilter {
+ explicit ScaleFilter(double p_factor) : factor(p_factor) {}
+ void filter_rw(CoordinateSequence& seq, std::size_t i) override
+ auto& c = seq.getAt<XY>(i);
+ c.x *= factor;
+ c.y *= factor;
+ bool isDone() const override
+ return false;
+ bool isGeometryChanged() const override
+ return factor != 1;
+ double factor;
+ ScaleFilter scale(2);
+ cs_->apply_rw(scale);
+ checkArcs(*cs_);
+ // coordinates unchanged, but copied before the filter is applied because they are shared
+ ScaleFilter identity(1);
+ cs->apply_rw(identity);
+ checkArcs(*cs);
+ checkArcs(*cs);
+template<>
+template<>
+void object::test<32>()
+ set_test_name("getArcs() after geometryChanged()");
+ auto& pts = *const_cast<CoordinateSequence*>(cs_->getCoordinatesRO());
+ pts.setAt(XY(1, 2), 1);
+ cs_->geometryChanged();
+ checkArcs(*cs_);
Summary of changes:
NEWS.md | 1 +
include/geos/geom/CircularString.h | 9 ++
include/geos/geom/CompoundCurve.h | 5 +
src/geom/CircularArc.cpp | 22 +----
src/geom/CircularString.cpp | 18 ++++
tests/unit/geom/CircularArcTest.cpp | 28 ++++++
tests/unit/geom/CircularStringTest.cpp | 170 +++++++++++++++++++++++++++++++++
tests/unit/geom/CompoundCurveTest.cpp | 26 +++++
8 files changed, 259 insertions(+), 20 deletions(-)
hooks/post-receive
More information about the geos-commits
