[geos-commits] [SCM] GEOS branch main updated. e0ff2cd9eda39cf7a3283e6321b0c69eca5db49b
Thu Oct 1 05:34:02 PDT 2026
the project "GEOS".
The branch, main has been updated
       via  e0ff2cd9eda39cf7a3283e6321b0c69eca5db49b (commit)
      from  7c25167af9fd326cd957ad588296495ac188d231 (commit)
revisions in full, below.
commit e0ff2cd9eda39cf7a3283e6321b0c69eca5db49b
Author: Mohd Quamar Tyagi <104281681+Tyagiquamar at users.noreply.github.com>
Date:   Thu Oct 1 18:03:32 2026 +0530
    GEOSProject_r: throw IllegalArgumentException and handle empty points (#1547)
    Fixes #1534
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 179015f24..e118726e7 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -4773,8 +4773,8 @@ extern "C" {
         return execute(extHandle, -1.0, [&]() {
             const Point* point = dynamic_cast<const Point*>(p);
-            if(!point) {
-                throw std::runtime_error("third argument of GEOSProject_r must be Point");
+            if(!point || point->isEmpty()) {
+                throw IllegalArgumentException("third argument of GEOSProject_r must be non-empty Point");
             const geos::geom::Coordinate inputPt(*p->getCoordinate());
             const auto inputLine = convertToLineIfNeeded(extHandle, g);
diff --git a/tests/unit/capi/GEOSProjectTest.cpp b/tests/unit/capi/GEOSProjectTest.cpp
index a8f550809..6c3ac7d4c 100644
--- a/tests/unit/capi/GEOSProjectTest.cpp
+++ b/tests/unit/capi/GEOSProjectTest.cpp
@@ -143,4 +143,40 @@ void object::test<6>
     ensure_equals("GEOSProjectNormalized result does not match", dist_norm, 0.5, 1e-3);
+// Empty point as second argument returns -1.0 instead of crashing
+// https://github.com/libgeos/geos/issues/1534
+template<>
+template<>
+void object::test<7>
+    geom1_ = GEOSGeomFromWKT("LINESTRING (0 0, 0 2)");
+    geom2_ = GEOSGeomFromWKT("POINT EMPTY");
+    ensure_equals(GEOSProject(geom1_, geom2_), -1.0);
+    ensure_equals(GEOSProjectNormalized(geom1_, geom2_), -1.0);
+// Invalid second argument reports IllegalArgumentException
+template<>
+template<>
+void object::test<8>
+    useContext();
+    geom1_ = fromWKT("LINESTRING (0 0, 0 2)");
+    geom2_ = fromWKT("LINESTRING (0 0, 0 2)");
+    std::string errorMsg;
+    GEOSContext_setErrorMessageHandler_r(ctxt_, [](const char* message, void* userdata) {
+        static_cast<std::string*>(userdata)->append(message);
+    }, &errorMsg);
+    ensure_equals(GEOSProject_r(ctxt_, geom1_, geom2_), -1.0);
+    ensure("error message contains IllegalArgumentException",
+           errorMsg.find("IllegalArgumentException") != std::string::npos);
 } // namespace tut
Summary of changes:
 capi/geos_ts_c.cpp                  |  4 ++--
 tests/unit/capi/GEOSProjectTest.cpp | 36 ++++++++++++++++++++++++++++++++++++
 2 files changed, 38 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
