[geos-commits] [SCM] GEOS branch main updated. cc9a3cc95d160c58a68ded58fb6b83935ca856fe
git at osgeo.org
git at osgeo.org
Fri Oct 2 01:43:22 PDT 2026
the project "GEOS".
The branch, main has been updated
via cc9a3cc95d160c58a68ded58fb6b83935ca856fe (commit)
from 6f4340223234824350773dca530424e55a734e22 (commit)
revisions in full, below.
commit cc9a3cc95d160c58a68ded58fb6b83935ca856fe
Author: Mohd Quamar Tyagi <104281681+Tyagiquamar at users.noreply.github.com>
Date: Fri Oct 2 14:12:58 2026 +0530
geosop: report error and exit non-zero when input file cannot be opened (#1548)
* geosop: report error and exit non-zero when input file cannot be opened
When an input file path does not exist or cannot be opened, std::ifstream
previously failed silently and returned an empty list of geometries, causing
geosop to succeed with exit code 0.
Check whether std::ifstream is open in readWKTFile and readWKBFile, throw an exception, caught at CLI boundary
Fixes #1538
diff --git a/util/geosop/GeosOp.cpp b/util/geosop/GeosOp.cpp
index 398085519..844505039 100644
--- a/util/geosop/GeosOp.cpp
+++ b/util/geosop/GeosOp.cpp
@@ -25,6 +25,7 @@
#include <geos/io/WKBReader.h>
#include <geos/io/WKBStreamReader.h>
#include <geos/io/WKBWriter.h>
+#include <geos/util/GEOSException.h>
#if !defined(MISSING_FENV)
#define HAVE_FENV
@@ -181,8 +182,15 @@ int main(int argc, char** argv) {
- GeosOp geosop(cmdArgs);
- geosop.run(opArgs);
+ try {
+ GeosOp geosop(cmdArgs);
+ geosop.run(opArgs);
+ catch (const std::exception& ex) {
+ std::cerr << ex.what() << std::endl;
+ return 1;
+ return 0;
GeosOp::GeosOp(GeosOpArgs& arg)
@@ -271,6 +279,9 @@ readWKTFile(std::string src, int limit, int offset) {
return readWKTFile( std::cin, limit, offset );
std::ifstream f( src );
+ if (!f.is_open()) {
+ throw util::GEOSException("Cannot open file: " + src);
auto geoms = readWKTFile( f, limit, offset );
f.close();
return geoms;
@@ -299,6 +310,9 @@ readWKBFile(std::string src, int limit, int offset) {
return readWKBFile( std::cin, limit, offset );
auto geoms = readWKBFile( f, limit, offset );
f.close();
return geoms;
Summary of changes:
util/geosop/GeosOp.cpp | 18 ++++++++++++++++--
1 file changed, 16 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits
