[geos-commits] [SCM] GEOS branch main updated. 7312930ea53f1f3954ad3f455ef549576f69743e
git at osgeo.org
git at osgeo.org
Fri Oct 2 05:53:47 PDT 2026
the project "GEOS".
The branch, main has been updated
via 7312930ea53f1f3954ad3f455ef549576f69743e (commit)
from e8d427e4f8d323b68a8f1f6d2c99e68522ec16d2 (commit)
revisions in full, below.
commit 7312930ea53f1f3954ad3f455ef549576f69743e
Author: Daniel Baston <dbaston at gmail.com>
Date: Fri Oct 2 08:53:22 2026 -0400
CurveBuilder: Copy Z/M values at shared endpoints of mixed-dimension sequences (#1545)
References https://github.com/libgeos/geos/issues/1541
diff --git a/include/geos/algorithm/LineToCurveConverter.h b/include/geos/algorithm/LineToCurveConverter.h
index b14b3f98a..c0efb0c06 100644
--- a/include/geos/algorithm/LineToCurveConverter.h
+++ b/include/geos/algorithm/LineToCurveConverter.h
@@ -53,17 +53,6 @@ private:
void addLineCoords(const geom::CoordinateSequence& points, std::size_t from, std::size_t to);
- void finishArc();
- void finishLine();
- std::shared_ptr<geom::CoordinateSequence> lineCoords;
- std::shared_ptr<geom::CoordinateSequence> arcCoords;
- std::vector<std::unique_ptr<geom::SimpleCurve>> curves;
- const geom::GeometryFactory& factory;
geom::util::CurveBuilder curveBuilder;
/// Declared as non-copyable
diff --git a/include/geos/geom/util/CurveBuilder.h b/include/geos/geom/util/CurveBuilder.h
index 27fccd2fa..ab5913bf8 100644
--- a/include/geos/geom/util/CurveBuilder.h
+++ b/include/geos/geom/util/CurveBuilder.h
@@ -40,6 +40,9 @@ public:
// Add all coordinates in the provided sequence
void add(const CoordinateSequence& seq, bool isCurved);
+ // Add all coordinates in the provided sequence (optionally reversed)
+ void add(const CoordinateSequence& seq, bool isCurved, bool isForward);
// Add coordinates between the specified indices (inclusive)
void add(const CoordinateSequence& seq, std::size_t from, std::size_t to, bool isCurved);
@@ -62,28 +65,29 @@ public:
bool hasActiveSequence() const {
- return m_pts != nullptr;
+ return !m_pts.empty();
bool isCurved() const {
- return m_isCurved;
+ return hasActiveSequence() && m_pts.back().second;
void setOutputLinearRing(bool outputLinearRing) {
m_outputLinearRing = outputLinearRing;
-private:
- void finishCurve();
+ void matchRingZM();
- std::vector<std::unique_ptr<SimpleCurve>> m_curves;
- std::unique_ptr<CoordinateSequence> m_pts{nullptr};
+ // Declare type as noncopyable
+ CurveBuilder(const CurveBuilder& other) = delete;
+ CurveBuilder& operator=(const CurveBuilder& rhs) = delete;
+private:
+ std::vector<std::pair<std::unique_ptr<CoordinateSequence>, bool>> m_pts;
const GeometryFactory& m_gfact;
const bool m_hasZ;
const bool m_hasM;
bool m_outputLinearRing{true};
- bool m_isCurved{false};
\ No newline at end of file
diff --git a/include/geos/operation/polygonize/EdgeRing.h b/include/geos/operation/polygonize/EdgeRing.h
index 5f8b7df5b..281b200d9 100644
--- a/include/geos/operation/polygonize/EdgeRing.h
+++ b/include/geos/operation/polygonize/EdgeRing.h
@@ -82,10 +82,6 @@ private:
return *getRingInternal()->getEnvelopeInternal();
- static void addEdge(const geom::CoordinateSequence* coords,
- bool isForward,
- geom::CoordinateSequence* coordList);
algorithm::locate::PointOnGeometryLocator* getLocator() const;
bool contains(const EdgeRing& otherRing) const;
diff --git a/src/geom/util/CurveBuilder.cpp b/src/geom/util/CurveBuilder.cpp
index 28859a7cc..2996a81f4 100644
--- a/src/geom/util/CurveBuilder.cpp
+++ b/src/geom/util/CurveBuilder.cpp
@@ -20,6 +20,9 @@
#include <geos/geom/CoordinateSequence.h>
#include <geos/geom/GeometryFactory.h>
#include <geos/geom/LineString.h>
+#include <geos/util/GEOSException.h>
+#include <cmath>
namespace geos::geom::util {
@@ -47,108 +50,186 @@ CurveBuilder::add(const Curve& geom)
void
CurveBuilder::add(const CoordinateSequence& coords, bool isCurved)
- getSeq(isCurved).add(coords, false);
+ add(coords, isCurved, true);
void
-CurveBuilder::add(const CoordinateSequence& coords, std::size_t from, std::size_t to, bool isCurved)
+CurveBuilder::add(const CoordinateSequence& coords, bool isCurved, bool isForward)
- getSeq(isCurved).add(coords, from, to, false);
+ if (coords.isEmpty()) {
+ return;
+ if (isForward) {
+ add(coords, 0, coords.size() - 1, isCurved);
+ } else {
+ add(coords, coords.size() - 1, 0, isCurved);
+void
+CurveBuilder::add(const CoordinateSequence& src, std::size_t from, std::size_t to, bool isCurved)
+ CoordinateSequence& dst = getSeq(isCurved);
+ const std::size_t insertionPos = dst.size();
+ if (from > to) {
+ for(std::size_t i = from + 1; i > to; --i) {
+ src.applyAt(i-1, [&dst](const auto& coord) {
+ dst.add(coord, false);
+ } else {
+ dst.add(src, from, to, false);
+ // When adding a sequence whose initial point is the same as the current final point, we may need to
+ // copy Z/M values from the initial point to the final point, or vice-versa.
+ if (!m_hasZ && !m_hasM) {
+ return;
+ if (insertionPos == 0 && m_pts.size() == 1) {
+ return;
+ CoordinateSequence& prev = insertionPos == 0 ? *m_pts[m_pts.size() - 2].first : dst;
+ std::size_t prevPos = insertionPos == 0 ? prev.size() - 1 : insertionPos - 1;
+ std::size_t currPos = insertionPos == 0 ? 0 : insertionPos - 1;
+ const bool firstPointEqualsLast = prev.getAt<CoordinateXY>(prevPos).equals2D(src.getAt<CoordinateXY>(from));
+ if (!firstPointEqualsLast) {
+ return;
+ if (m_hasZ) {
+ const double currZ = src.getZ(from);
+ const double prevZ = prev.getZ(prevPos);
+ if (std::isnan(prevZ) && !std::isnan(currZ)) {
+ prev.setZ(prevPos, currZ);
+ if (std::isnan(currZ) && !std::isnan(prevZ)) {
+ dst.setZ(currPos, prevZ);
+ if (m_hasM) {
+ const double currM = src.getM(from);
+ const double prevM = prev.getM(prevPos);
+ if (std::isnan(prevM) && !std::isnan(currM)) {
+ prev.setM(prevPos, currM);
+ if (std::isnan(currM) && !std::isnan(prevM)) {
+ dst.setM(currPos, prevM);
+void
+CurveBuilder::matchRingZM()
+ if (m_pts.empty()) {
+ return;
+ CoordinateSequence& firstSeq = *m_pts.front().first;
+ CoordinateSequence& lastSeq = *m_pts.back().first;
+ if (!firstSeq.front<CoordinateXY>().equals2D(lastSeq.back<CoordinateXY>())) {
+ throw geos::util::GEOSException("CurveBuilder::matchRingZM called on non-ring");
+ if (m_hasZ) {
+ const double firstZ = firstSeq.getZ(0);
+ const double lastZ = lastSeq.getZ(lastSeq.size() - 1);
+ if (std::isnan(firstZ) && !std::isnan(lastZ)) {
+ firstSeq.setZ(0, lastZ);
+ if (std::isnan(lastZ) && !std::isnan(firstZ)) {
+ lastSeq.setZ(lastSeq.size() - 1, firstZ);
+ if (m_hasM) {
+ const double firstM = firstSeq.getM(0);
+ const double lastM = lastSeq.getM(lastSeq.size() - 1);
+ if (std::isnan(firstM) && !std::isnan(lastM)) {
+ firstSeq.setM(0, lastM);
+ if (std::isnan(lastM) && !std::isnan(firstM)) {
+ lastSeq.setM(lastSeq.size() - 1, firstM);
void
CurveBuilder::closeRing()
- if (m_curves.empty() && (m_pts == nullptr || m_pts->isEmpty())) {
return;
CoordinateXYZM first;
- if (!m_curves.empty()) {
- m_curves.front()->getCoordinatesRO()->getAt(0, first);
- } else {
- m_pts->getAt(0, first);
+ m_pts.front().first->getAt(0, first);
CoordinateXYZM last;
- if (m_pts && !m_pts->isEmpty()) {
- m_pts->getAt(m_pts->size() - 1, last);
- } else {
- const auto* seq = m_curves.back()->getCoordinatesRO();
- seq->getAt(seq->size() - 1, last);
+ m_pts.back().first->getAt(m_pts.back().first->size() - 1, last);
if (first.equals2D(last)) {
+ matchRingZM();
return;
- if (m_pts && m_isCurved) {
- finishCurve();
+ if (isCurved()) {
getSeq(false).add(last);
getSeq(false).add(first);
-void
-CurveBuilder::finishCurve()
- m_curves.push_back(m_gfact.createCircularString(std::move(m_pts)));
- m_pts = nullptr;
-void
-CurveBuilder::finishLine()
- m_curves.push_back(m_gfact.createLineString(std::move(m_pts)));
- m_pts = nullptr;
std::unique_ptr<Curve>
CurveBuilder::getGeometry()
- if (m_pts) {
- if (m_isCurved) {
- finishCurve();
- } else {
+ return m_gfact.createLineString(std::make_unique<CoordinateSequence>(0, m_hasZ, m_hasM));
- if (m_outputLinearRing && m_curves.empty() && m_pts->isRing()) {
- m_curves.push_back(m_gfact.createLinearRing(std::move(m_pts)));
- } else {
- finishLine();
+ if (m_pts.size() == 1) {
+ auto& [pts, isCurve] = m_pts.front();
+ if (isCurve) {
+ return m_gfact.createCircularString(std::move(pts));
+ if (m_outputLinearRing && pts->isRing()) {
+ return m_gfact.createLinearRing(std::move(pts));
+ return m_gfact.createLineString(std::move(pts));
+ std::vector<std::unique_ptr<SimpleCurve>> curves;
+ for (auto& [pts, isCurve] : m_pts) {
+ if (isCurve) {
+ curves.push_back(m_gfact.createCircularString(std::move(pts)));
+ } else {
+ curves.push_back(m_gfact.createLineString(std::move(pts)));
- if (m_curves.empty()) {
- auto seq = std::make_unique<CoordinateSequence>(0, m_hasZ, m_hasM);
- return m_gfact.createLineString(std::move(seq));
- if (m_curves.size() == 1) {
- return std::move(m_curves[0]);
- return m_gfact.createCompoundCurve(std::move(m_curves));
+ return m_gfact.createCompoundCurve(std::move(curves));
CoordinateSequence&
CurveBuilder::getSeq(bool isCurved)
- if (m_pts) {
- if (m_isCurved && !isCurved) {
- finishCurve();
- } else if (isCurved && !m_isCurved) {
- finishLine();
+ if (m_pts.empty() || m_pts.back().second != isCurved) {
+ m_pts.emplace_back(std::make_unique<CoordinateSequence>(0, m_hasZ, m_hasM), isCurved);
- if (!m_pts) {
- m_pts = std::make_unique<CoordinateSequence>(0, m_hasZ, m_hasM);
- m_isCurved = isCurved;
- return *m_pts;
+ return *m_pts.back().first;
diff --git a/src/operation/linemerge/EdgeString.cpp b/src/operation/linemerge/EdgeString.cpp
index 54fbbae5c..3b826c8dc 100644
--- a/src/operation/linemerge/EdgeString.cpp
+++ b/src/operation/linemerge/EdgeString.cpp
@@ -64,26 +64,9 @@ addCoordinates(geom::util::CurveBuilder& curveBuilder, const SimpleCurve* curve,
const CoordinateSequence& srcCoords = *curve->getCoordinatesRO();
- // Patch Z value in last coordinate, if needed
- if (curveBuilder.hasActiveSequence() && curve->hasZ()) {
- CoordinateSequence& dstCoords = curveBuilder.getSeq(curveBuilder.isCurved());
- if (std::isnan(dstCoords.getZ(dstCoords.getSize() - 1))) {
- dstCoords.setZ(dstCoords.getSize() - 1, forward ? srcCoords.getZ(0) : srcCoords.getZ(srcCoords.getSize() - 1));
- // Patch M value in last coordinate, if needed
- if (curveBuilder.hasActiveSequence() && curve->hasM()) {
- if (std::isnan(dstCoords.getM(dstCoords.getSize() - 1))) {
- dstCoords.setM(dstCoords.getSize() - 1, forward ? srcCoords.getM(0) : srcCoords.getM(srcCoords.getSize() - 1));
const bool isCurved = curve->getGeometryTypeId() == GEOS_CIRCULARSTRING;
- CoordinateSequence& dstCoords = curveBuilder.getSeq(isCurved);
- dstCoords.add(srcCoords, false, forward);
+ curveBuilder.add(srcCoords, isCurved, forward);
diff --git a/src/operation/polygonize/EdgeRing.cpp b/src/operation/polygonize/EdgeRing.cpp
index 8917c1bf7..2ce1bd724 100644
--- a/src/operation/polygonize/EdgeRing.cpp
+++ b/src/operation/polygonize/EdgeRing.cpp
@@ -305,13 +305,12 @@ EdgeRing::getRingInternal() const
for(const auto& de : deList) {
const auto edge = detail::down_cast<PolygonizeEdge*>(de->getEdge());
const bool isCurved = edge->getLine()->getGeometryTypeId() == GEOS_CIRCULARSTRING;
+ const bool isForward = de->getEdgeDirection();
- CoordinateSequence& ringPts = builder.getSeq(isCurved);
- addEdge(edge->getLine()->getCoordinatesRO(),
- de->getEdgeDirection(), &ringPts);
+ builder.add(*edge->getLine()->getCoordinatesRO(), isCurved, isForward);
+ builder.matchRingZM();
ring = builder.getGeometry();
@@ -326,36 +325,6 @@ EdgeRing::getRingOwnership()
return std::move(ring);
-/*private*/
-void
-EdgeRing::addEdge(const CoordinateSequence* srcCoords, bool isForward,
- CoordinateSequence* dstCoords)
- const std::size_t npts = srcCoords->getSize();
- if (!dstCoords->isEmpty() && !srcCoords->isEmpty()) {
- if (srcCoords->hasZ() && std::isnan(dstCoords->getZ(dstCoords->size() - 1))) {
- dstCoords->setZ(dstCoords->size() - 1, isForward ? srcCoords->getZ(0) : srcCoords->getZ(srcCoords->getSize() - 1));
- if (srcCoords->hasM() && std::isnan(dstCoords->getM(dstCoords->size() - 1))) {
- dstCoords->setM(dstCoords->size() - 1, isForward ? srcCoords->getM(0) : srcCoords->getM(srcCoords->getSize() - 1));
- if(isForward) {
- dstCoords->add(*srcCoords, 0, npts - 1, false);
- else {
- for(std::size_t i = npts; i > 0; --i) {
- srcCoords->applyAt(i-1, [&dstCoords](const auto& coord) {
- dstCoords->add(coord, false);
EdgeRing*
EdgeRing::getOuterHole() const {
// Only shells can have outer holes
diff --git a/tests/unit/geom/util/CurveBuilderTest.cpp b/tests/unit/geom/util/CurveBuilderTest.cpp
index d7e801746..05a44fe48 100644
--- a/tests/unit/geom/util/CurveBuilderTest.cpp
+++ b/tests/unit/geom/util/CurveBuilderTest.cpp
@@ -174,4 +174,86 @@ void object::test<8>()
ensure_equals_geometry(static_cast<const Geometry*>(result.get()), expected.get());
+template<>
+template<>
+void object::test<9>()
+ set_test_name("Z/M matched when combining mixed-dimension sequences");
+ CurveBuilder builder(*factory_, true, true);
+ builder.add(*reader_.read<LineString>("LINESTRING (0 0, 1 1)"));
+ // Patch Z Linear <- Linear
+ builder.add(*reader_.read<LineString>("LINESTRING Z (1 1 5, 2 2 4)"));
+ // Patch Z Linear -> Linear
+ builder.add(*reader_.read<LineString>("LINESTRING (2 2, 5 0)"));
+ // Patch M Linear <- Curve
+ builder.add(*reader_.read<CircularString>("CIRCULARSTRING M (5 0 8, 6 1 7, 7 0 8)"));
+ // Patch M Curve -> Curve
+ builder.add(*reader_.read<CircularString>("CIRCULARSTRING (7 0, 8 -1, 9 0)"));
+ // Patch Z Curve <- Linear
+ builder.add(*reader_.read<LineString>("LINESTRING (9 0 11, 10 20 12)"));
+ auto result = builder.getGeometry();
+ auto expected = reader_.read("COMPOUNDCURVE ZM ((0 0 NaN NaN, 1 1 5 NaN, 2 2 4 NaN, 5 0 NaN 8), CIRCULARSTRING ZM (5 0 NaN 8, 6 1 NaN 7, 7 0 NaN 8, 8 -1 NaN NaN, 9 0 11 NaN), (9 0 11 NaN, 10 20 12 NaN))");
+ ensure_equals_geometry_xyzm(static_cast<const Geometry*>(result.get()), expected.get());
+template<>
+template<>
+void object::test<10>()
+ set_test_name("Z/M matched when calling closeRing on open CircularString");
+ builder.add(*reader_.read<CircularString>("CIRCULARSTRING ZM (0 0 100 200, 1 1 200 400, 2 0 300 600)"));
+ builder.closeRing();
+ auto expected = reader_.read("COMPOUNDCURVE ZM (CIRCULARSTRING(0 0 100 200, 1 1 200 400, 2 0 300 600), (2 0 300 600, 0 0 100 200))");
+template<>
+template<>
+void object::test<11>()
+ set_test_name("Z/M matched when calling closeRing on closed CircularString ZM -> LineString");
+ builder.add(*reader_.read<LineString>("LINESTRING (2 0, 0 0)"));
+template<>
+template<>
+void object::test<12>()
+ set_test_name("Z/M matched when calling closeRing on closed CircularString -> LineString ZM");
+ builder.add(*reader_.read<CircularString>("CIRCULARSTRING (0 0, 1 1, 2 0)"));
+ builder.add(*reader_.read<LineString>("LINESTRING ZM (2 0 300 600, 0 0 100 200)"));
+ auto expected = reader_.read("COMPOUNDCURVE ZM (CIRCULARSTRING(0 0 100 200, 1 1 NaN NaN, 2 0 300 600), (2 0 300 600, 0 0 100 200))");
} // namespace tut
diff --git a/tests/unit/operation/polygonize/PolygonizeTest.cpp b/tests/unit/operation/polygonize/PolygonizeTest.cpp
index 502fc2c84..9c6002a62 100644
--- a/tests/unit/operation/polygonize/PolygonizeTest.cpp
+++ b/tests/unit/operation/polygonize/PolygonizeTest.cpp
@@ -62,8 +62,8 @@ struct test_polygonizetest_data {
void
printAll(std::ostream& os, T& cnt)
- for(typename T::iterator i = cnt.begin(), e = cnt.end(); i != e; ++i) {
- os << **i << std::endl;
+ for(auto& geom : cnt) {
+ os << geom->toString() << std::endl;
@@ -71,9 +71,8 @@ struct test_polygonizetest_data {
bool
contains(T& cnt, const Geom* g)
- const auto& element = *i;
- if(element->equalsExact(g)) {
+ for(const auto& element : cnt) {
+ if(element->equalsIdentical(g)) {
return true;
@@ -92,9 +91,9 @@ struct test_polygonizetest_data {
<< ob.size() << endl;
return false;
- for(typename T::iterator i = ex.begin(), e = ex.end(); i != e; ++i) {
- if(! contains(ob, i->get())) {
- cout << "Expected " << wktwriter.write(i->get())
+ for(const auto& expected : ex) {
+ if(! contains(ob, expected.get())) {
+ cout << "Expected " << wktwriter.write(expected.get())
<< " not found" << endl;
return false;
@@ -395,7 +394,7 @@ void object::test<11>()
"POLYGON ZM ((0 0 0 0, 0 10 1 2, 10 10 2 3, 10 0 3 4, 0 0 0 0))",
- "POLYGON ZM ((10 0 3 4, 10 10 2 3, 20 0 NaN 9, 10 0 3 4))"
+ "POLYGON ZM ((10 0 3 4, 10 10 2 3, 20 0 NaN 9, 10 0 3 8))"
false,
POLYGONS);
@@ -481,5 +480,23 @@ void object::test<15>()
doTest(input, expected, false, POLYGONS);
+template<>
+template<>
+void object::test<16>()
+ set_test_name("mixed-dimension curved and linear inputs");
+ std::vector<std::string> input{
+ "LINESTRING Z (-5 0 10, 5 0 20)",
+ "CIRCULARSTRING (-5 0, 0 5, 5 0)"
+ std::vector<std::string> expected{
+ "CURVEPOLYGON Z (COMPOUNDCURVE((-5 0 10, 5 0 20), CIRCULARSTRING (5 0 20, 0 5 NaN, -5 0 10)))"
+ doTest(input, expected, false, POLYGONS);
} // namespace tut
Summary of changes:
include/geos/algorithm/LineToCurveConverter.h | 11 --
include/geos/geom/util/CurveBuilder.h | 20 ++-
include/geos/operation/polygonize/EdgeRing.h | 4 -
src/geom/util/CurveBuilder.cpp | 195 +++++++++++++++------
src/operation/linemerge/EdgeString.cpp | 21 +--
src/operation/polygonize/EdgeRing.cpp | 37 +---
tests/unit/geom/util/CurveBuilderTest.cpp | 82 +++++++++
tests/unit/operation/polygonize/PolygonizeTest.cpp | 35 +++-
8 files changed, 263 insertions(+), 142 deletions(-)
hooks/post-receive
More information about the geos-commits
