[geos-commits] [SCM] GEOS branch main updated. 0d790d12b25a8e1d7310a55ec701e6bf54f73fb2
git at osgeo.org
git at osgeo.org
Mon Oct 5 09:35:41 PDT 2026
the project "GEOS".
The branch, main has been updated
via 0d790d12b25a8e1d7310a55ec701e6bf54f73fb2 (commit)
from c6af5613f1b5da92205e3cd45057499b90bfa0b8 (commit)
revisions in full, below.
commit 0d790d12b25a8e1d7310a55ec701e6bf54f73fb2
Author: Jeroen Bloemscheer <jbloemscheer at gmail.com>
Date: Mon Oct 5 18:35:13 2026 +0200
Port JTS DirectedHausdorffDistance (#1514)
Co-authored-by: Dan Baston <dbaston at gmail.com>
diff --git a/NEWS.md b/NEWS.md
index 6891059d3..a6510e8d4 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -1,6 +1,10 @@
## Changes in 3.16.0
2027-xx-xx
+- New things:
+ - Add DirectedHausdorffDistance and C API GEOSDirectedHausdorffDistance /
+ GEOSSymmetricHausdorffDistance (Martin Davis, Jeroen Bloemscheer, Dan Baston)
- Fixes/Improvements:
- Curve overlay robustness improvements (GH-1513, Dan Baston)
- GeometrySplitter: Allow splitting a MultiSurface (GH-1520, Dan Baston)
diff --git a/Version.txt b/Version.txt
index c1bb857ba..50e4eb502 100644
--- a/Version.txt
+++ b/Version.txt
@@ -15,9 +15,9 @@ GEOS_PATCH_WORD=dev
# - Deleting interfaces / compatibility issues - bump CURRENT, others to zero
# ( THIS MUST BE CAREFULLY AVOIDED )
-CAPI_INTERFACE_CURRENT=23
+CAPI_INTERFACE_CURRENT=24
CAPI_INTERFACE_REVISION=0
-CAPI_INTERFACE_AGE=22
+CAPI_INTERFACE_AGE=23
# JTS Port
JTS_PORT=1.20.0
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index b2918e466..a5459ee92 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -409,6 +409,30 @@ extern "C" {
return GEOSHausdorffDistanceDensifyWithPoints_r(handle, g1, g2, densifyFrac, dist, p1x, p1y, p2x, p2y);
+ int
+ GEOSDirectedHausdorffDistance(const Geometry* g1, const Geometry* g2, double* dist)
+ return GEOSDirectedHausdorffDistance_r(handle, g1, g2, dist);
+ int
+ GEOSDirectedHausdorffDistanceWithPoints(const Geometry* g1, const Geometry* g2, double* dist, double* p1x, double* p1y, double* p2x, double* p2y)
+ return GEOSDirectedHausdorffDistanceWithPoints_r(handle, g1, g2, dist, p1x, p1y, p2x, p2y);
+ int
+ GEOSDirectedHausdorffDistanceWithin(const Geometry* g1, const Geometry* g2, double maxDistance)
+ return GEOSDirectedHausdorffDistanceWithin_r(handle, g1, g2, maxDistance);
+ int
+ GEOSSymmetricHausdorffDistance(const Geometry* g1, const Geometry* g2, double* dist)
+ return GEOSSymmetricHausdorffDistance_r(handle, g1, g2, dist);
int
GEOSFrechetDistance(const Geometry* g1, const Geometry* g2, double* dist)
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 8121af536..00ec6b3ee 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -2184,6 +2184,36 @@ extern int GEOS_DLL GEOSHausdorffDistanceDensifyWithPoints_r(
double *p1x, double *p1y,
double *p2x, double *p2y);
+/** \see GEOSDirectedHausdorffDistance */
+extern int GEOS_DLL GEOSDirectedHausdorffDistance_r(
+ GEOSContextHandle_t handle,
+ const GEOSGeometry *g1,
+ const GEOSGeometry *g2,
+ double *dist);
+/** \see GEOSDirectedHausdorffDistanceWithPoints */
+extern int GEOS_DLL GEOSDirectedHausdorffDistanceWithPoints_r(
+ double *dist,
+ double *p1x, double *p1y,
+ double *p2x, double *p2y);
+/** \see GEOSDirectedHausdorffDistanceWithin */
+extern int GEOS_DLL GEOSDirectedHausdorffDistanceWithin_r(
+ double maxDistance);
+/** \see GEOSSymmetricHausdorffDistance */
+extern int GEOS_DLL GEOSSymmetricHausdorffDistance_r(
+ double *dist);
/** \see GEOSFrechetDistance */
extern int GEOS_DLL GEOSFrechetDistance_r(
@@ -4223,6 +4253,92 @@ extern int GEOS_DLL GEOSHausdorffDistanceDensifyWithPoints(
double* p2x, double* p2y);
+* Calculate the directed Hausdorff distance from g1 to g2,
+* the largest distance from any point of g1 to g2.
+* Empty inputs write NaN.
+* Approximated using a tolerance of the query envelope diameter / 1e4.
+* @INPUT_CURVES_CONVERTED_TO_LINES@
+* \param[in] g1 Query geometry
+* \param[in] g2 Target geometry
+* \param[out] dist Pointer to be filled in with distance result
+* \return 1 on success, 0 on exception.
+* \since 3.16
+extern int GEOS_DLL GEOSDirectedHausdorffDistance(
+ double *dist);
+* the largest distance from any point of g1 to g2,
+* and the coordinates of a point pair that realizes the distance
+* (a point of g1 and the nearest point of g2).
+* \param[out] p1x X coordinate of point on g1
+* \param[out] p1y Y coordinate of point on g1
+* \param[out] p2x X coordinate of point on g2
+* \param[out] p2y Y coordinate of point on g2
+* \since 3.16
+extern int GEOS_DLL GEOSDirectedHausdorffDistanceWithPoints(
+ double *dist,
+* Test whether every point of g1 lies within maxDistance of g2.
+* Empty inputs return 0.
+* Uses the same automatic approximation tolerance as GEOSDirectedHausdorffDistance.
+* \param[in] maxDistance the distance limit
+* \return 1 if fully within, 0 if not, 2 on exception.
+* \since 3.16
+extern int GEOS_DLL GEOSDirectedHausdorffDistanceWithin(
+* Calculate the Hausdorff distance between g1 and g2,
+* the larger of the two directed Hausdorff distances.
+* \param[in] g1 Input geometry
+* \param[in] g2 Input geometry
+* \since 3.16
+extern int GEOS_DLL GEOSSymmetricHausdorffDistance(
+ double *dist);
* Calculate the
* [Frechet distance](https://en.wikipedia.org/wiki/Fr%C3%A9chet_distance)
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index a69e944ea..56218cb3b 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -27,6 +27,7 @@
#include <geos/algorithm/construct/MaximumInscribedCircle.h>
#include <geos/algorithm/construct/LargestEmptyCircle.h>
#include <geos/algorithm/distance/DiscreteHausdorffDistance.h>
+#include <geos/algorithm/distance/DirectedHausdorffDistance.h>
#include <geos/algorithm/distance/DiscreteFrechetDistance.h>
#include <geos/algorithm/hull/ConcaveHull.h>
#include <geos/algorithm/hull/ConcaveHullOfPolygons.h>
@@ -135,6 +136,7 @@
#include <cstring>
#include <fstream>
#include <iostream>
+#include <limits>
#include <optional>
#include <sstream>
#include <string>
@@ -232,6 +234,7 @@ using geos::io::GeoJSONWriter;
using geos::algorithm::distance::DiscreteFrechetDistance;
using geos::algorithm::distance::DiscreteHausdorffDistance;
+using geos::algorithm::distance::DirectedHausdorffDistance;
using geos::algorithm::hull::ConcaveHull;
using geos::algorithm::hull::ConcaveHullOfPolygons;
@@ -1287,6 +1290,66 @@ extern "C" {
+ int
+ GEOSDirectedHausdorffDistance_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2, double* dist)
+ return execute(extHandle, 0, [&]() {
+ const auto input1 = convertToLineIfNeeded(extHandle, g1);
+ const auto input2 = convertToLineIfNeeded(extHandle, g2);
+ *dist = DirectedHausdorffDistance::distance(*input1, *input2);
+ return 1;
+ int
+ GEOSDirectedHausdorffDistanceWithPoints_r(GEOSContextHandle_t extHandle,
+ const Geometry* g1, const Geometry* g2,
+ double* dist, double* p1x, double* p1y,
+ double* p2x, double* p2y)
+ auto pts = DirectedHausdorffDistance::distancePoints(*input1, *input2);
+ if (!pts) {
+ *dist = std::numeric_limits<double>::quiet_NaN();
+ *p1x = *p1y = *p2x = *p2y = std::numeric_limits<double>::quiet_NaN();
+ return 1;
+ *dist = (*pts)[0].distance((*pts)[1]);
+ *p1x = (*pts)[0].x;
+ *p1y = (*pts)[0].y;
+ *p2x = (*pts)[1].x;
+ *p2y = (*pts)[1].y;
+ return 1;
+ int
+ GEOSDirectedHausdorffDistanceWithin_r(GEOSContextHandle_t extHandle,
+ const Geometry* g1, const Geometry* g2, double maxDistance)
+ return execute(extHandle, 2, [&]() {
+ return DirectedHausdorffDistance::isFullyWithinDistance(*input1, *input2, maxDistance) ? 1 : 0;
+ int
+ GEOSSymmetricHausdorffDistance_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2, double* dist)
+ *dist = DirectedHausdorffDistance::hausdorffDistance(*input1, *input2);
+ return 1;
int
GEOSFrechetDistance_r(GEOSContextHandle_t extHandle, const Geometry* g1, const Geometry* g2, double* dist)
diff --git a/include/geos/algorithm/distance/DirectedHausdorffDistance.h b/include/geos/algorithm/distance/DirectedHausdorffDistance.h
new file mode 100644
index 000000000..8ccbb4a22
--- /dev/null
+++ b/include/geos/algorithm/distance/DirectedHausdorffDistance.h
@@ -0,0 +1,300 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2026 Martin Davis
+ * Copyright (C) 2026 Jeroen Bloemscheer
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Last port: algorithm/distance/DirectedHausdorffDistance.java (aff11591)
+#pragma once
+#include <geos/export.h>
+#include <geos/geom/Coordinate.h>
+#include <array>
+#include <memory>
+#include <optional>
+#ifdef _MSC_VER
+#pragma warning(push)
+#pragma warning(disable: 4251) // warning C4251: needs to have dll-interface to be used by clients of class
+#endif
+namespace geos {
+namespace geom {
+class Envelope;
+class Geometry;
+namespace geos {
+namespace algorithm {
+namespace distance {
+ * Computes the directed Hausdorff distance from one geometry to another.
+ * The directed Hausdorff distance is the maximum distance any point
+ * on a query geometry A can be from a target geometry B.
+ * Equivalently, every point in the query geometry is within that distance
+ * of the target geometry.
+ * The class can compute a pair of points at which the distance is attained:
+ * [ farthest A point, nearest B point ].
+ * The directed Hausdorff distance (DHD) is defined as:
+ * DHD(A,B) = max a ∈ A (max b ∈ B (distance(a, b) )
+ * DHD is asymmetric: DHD(A,B) may not be equal to DHD(B,A).
+ * Hence it is not a distance metric.
+ * The Hausdorff distance is a symmetric distance metric defined as:
+ * HD(A,B) = max(DHD(A,B), DHD(B,A))
+ * This can be computed via the
+ * hausdorffDistancePoints(Geometry, Geometry) function.
+ * Points, lines and polygons are supported as input.
+ * If the query geometry is polygonal,
+ * the point at maximum distance may occur in the interior of a query polygon.
+ * For a polygonal target geometry the point always lies on the boundary.
+ * The directed Hausdorff distance can be used to test
+ * whether a geometry lies fully within a given distance of another one.
+ * The isFullyWithinDistance(Geometry, double) function
+ * is provided to execute this test efficiently.
+ * It implements heuristic checks and short-circuiting to improve performance.
+ * The class can be used in prepared mode.
+ * Creating an instance on a target geometry caches indexes for that geometry.
+ * Then farthestPoints(Geometry)
+ * or isFullyWithinDistance(Geometry, double)
+ * can be called efficiently for multiple query geometries.
+ * If the Hausdorff distance is attained at a non-vertex of the query geometry,
+ * the location must be approximated.
+ * The algorithm uses a distance tolerance to control the approximation accuracy.
+ * The tolerance is automatically determined to balance between accuracy and performance.
+ * If more accuracy is desired some function signatures are provided
+ * which allow specifying a distance tolerance.
+ * This algorithm is easier to use, more accurate,
+ * and much faster than DiscreteHausdorffDistance.
+ * \author Martin Davis
+class GEOS_DLL DirectedHausdorffDistance {
+public:
+ /// JTS returns Coordinate[]; std::array is the C++ equivalent pair.
+ using PointPair = std::array<geom::CoordinateXY, 2>;
+ * of a query geometry A from a target one B.
+ * @param a the query geometry
+ * @param b the target geometry
+ * @return the directed Hausdorff distance,
+ * or NaN if an input is empty
+ static double distance(const geom::Geometry& a, const geom::Geometry& b);
+ * of a query geometry A from a target one B,
+ * up to a given distance accuracy.
+ * @param tolerance the accuracy distance tolerance
+ static double distance(const geom::Geometry& a, const geom::Geometry& b,
+ double tolerance);
+ * Computes a line containing a pair of points which attain the directed Hausdorff distance
+ * @return a pair of points [ptA, ptB] demonstrating the distance,
+ * or empty if an input is empty
+ static std::optional<PointPair> distancePoints(
+ const geom::Geometry& a, const geom::Geometry& b);
+ * of a query geometry A from a target one B, up to a given distance accuracy.
+ const geom::Geometry& a, const geom::Geometry& b, double tolerance);
+ * Computes the symmetric Hausdorff distance between two geometries.
+ * This is the maximum of the two directed Hausdorff distances.
+ * @param a a geometry
+ * @param b a geometry
+ * @return the Hausdorff distance, or NaN if an input is empty
+ static double hausdorffDistance(const geom::Geometry& a, const geom::Geometry& b);
+ * Computes a pair of points which attain the symmetric Hausdorff distance
+ * between two geometries.
+ * @return a pair of points [ptA, ptB] demonstrating the Hausdorff distance,
+ static std::optional<PointPair> hausdorffDistancePoints(
+ * Computes whether a query geometry lies fully within a given distance of a target geometry.
+ * Equivalently, detects whether any point of the query geometry is farther
+ * from the target than the specified distance.
+ * This is the case if DHD(A, B) > maxDistance.
+ * @param maxDistance the distance limit
+ * @return true if the query geometry lies fully within the distance of the target
+ static bool isFullyWithinDistance(
+ const geom::Geometry& a, const geom::Geometry& b, double maxDistance);
+ * Computes whether a query geometry lies fully within a given distance of a target geometry,
+ double maxDistance, double tolerance);
+ * Create a new instance for a target geometry.
+ * @param geom the geometry to compute the distance from
+ explicit DirectedHausdorffDistance(const geom::Geometry& geom);
+ DirectedHausdorffDistance(const DirectedHausdorffDistance&) = delete;
+ DirectedHausdorffDistance& operator=(const DirectedHausdorffDistance&) = delete;
+ ~DirectedHausdorffDistance();
+ * Computes a pair of points which attain the directed Hausdorff distance
+ * of a query geometry A from the target B.
+ * If either geometry is empty the result is empty.
+ * @param geom the query geometry
+ * @return a pair of points [ptA, ptB] attaining the distance,
+ std::optional<PointPair> farthestPoints(const geom::Geometry& geom) const;
+ * of a query geometry A from the target B,
+ * @param tolerance the approximation distance tolerance
+ std::optional<PointPair> farthestPoints(const geom::Geometry& geom, double tolerance) const;
+ * Tests whether a query geometry lies fully within a given distance of the target geometry.
+ bool isFullyWithinDistance(const geom::Geometry& geom, double maxDistance) const;
+ * Tests whether a query geometry lies fully within a given distance of the target geometry,
+ const geom::Geometry& geom, double maxDistance, double tolerance) const;
+private:
+ class TargetDistance;
+ friend class DHDSegment;
+ static double pairDistance(const std::optional<PointPair>& pts);
+ static PointPair pair(const geom::CoordinateXY& p0, const geom::CoordinateXY& p1);
+ static double computeTolerance(const geom::Geometry& geom);
+ static bool isBeyond(
+ const geom::Envelope& envA, const geom::Envelope& envB, double maxDistance);
+ static bool isValidLimit(double limit);
+ static bool isBeyondLimit(double maxDist, double maxDistanceLimit);
+ static bool isWithinLimit(double maxDist, double maxDistanceLimit);
+ std::optional<PointPair> computeDistancePoints(
+ const geom::Geometry& geom, double tolerance, double maxDistanceLimit) const;
+ std::optional<PointPair> computeForPoints(
+ const geom::Geometry& geom, double maxDistanceLimit) const;
+ std::optional<PointPair> computeForEdges(
+ std::optional<PointPair> computeForAreaInterior(
+ const geom::Geometry& geom, double tolerance) const;
+ const geom::Geometry& target;
+ std::unique_ptr<TargetDistance> targetDistance;
+} // namespace distance
+} // namespace algorithm
+} // namespace geos
+#ifdef _MSC_VER
+#pragma warning(pop)
+#endif
diff --git a/include/geos/operation/distance/CoordinateSequenceLocation.h b/include/geos/operation/distance/CoordinateSequenceLocation.h
index 000000000..8686961ac
--- /dev/null
+++ b/include/geos/operation/distance/CoordinateSequenceLocation.h
@@ -0,0 +1,76 @@
+ * Last port: operation/distance/CoordinateSequenceLocation.java (aff11591)
+#pragma once
+#include <cstddef>
+namespace geos {
+namespace geom {
+class CoordinateSequence;
+namespace geos {
+namespace operation {
+ * A location on a FacetSequence.
+ * Location indexes are always the index of a sequence segment.
+ * Thus they are always less than the number of vertices
+ * in the sequence. The endpoint in a sequence
+ * has the index of the final segment in the sequence.
+ * If the sequence is a ring, the index of the final endpoint is
+ * normalized to 0.
+class GEOS_DLL CoordinateSequenceLocation {
+public:
+ CoordinateSequenceLocation(const geom::CoordinateSequence* seq,
+ std::size_t index,
+ const geom::CoordinateXY& pt);
+ const geom::CoordinateXY& getCoordinate() const;
+ std::size_t getIndex() const;
+ bool isSameSegment(const CoordinateSequenceLocation& f) const;
+ const geom::CoordinateXY& getEndPoint(int i) const;
+ std::size_t normalize(std::size_t index) const;
+private:
+ const geom::CoordinateSequence* seq;
+ std::size_t index;
+ geom::CoordinateXY pt;
+ bool isNext(std::size_t index, std::size_t index1) const;
+} // namespace operation
diff --git a/include/geos/operation/distance/FacetSequence.h b/include/geos/operation/distance/FacetSequence.h
index 61f9fd65b..2f09acd46 100644
--- a/include/geos/operation/distance/FacetSequence.h
+++ b/include/geos/operation/distance/FacetSequence.h
@@ -12,7 +12,7 @@
- * Last port: operation/distance/FacetSequence.java (f6187ee2 JTS-1.14)
+ * Last port: operation/distance/FacetSequence.java (aff11591)
@@ -20,6 +20,9 @@
#include <geos/geom/Envelope.h>
+#include <geos/operation/distance/CoordinateSequenceLocation.h>
+#include <vector>
namespace geos {
namespace geom {
@@ -61,6 +64,10 @@ private:
const geom::Coordinate& q0, const geom::Coordinate &q1,
std::vector<geom::Coordinate> *locs) const;
+ CoordinateSequenceLocation nearestLocationOnLine(const geom::CoordinateXY& pt) const;
+ static std::size_t normalize(const geom::CoordinateSequence& pts, std::size_t index);
void computeEnvelope();
public:
@@ -82,13 +89,21 @@ public:
* and another sequence.
* The locations are presented in the same order as the input sequences.
- * @return a pair of {@link Coordinate}s for the nearest points
+ * @return a pair of Coordinates for the nearest points
std::vector<geom::Coordinate> nearestLocations(const FacetSequence& facetSeq) const;
+ * Computes the location of the nearest point of this sequence
+ * to a query point.
+ * @param p the query point
+ * @return the nearest location on this sequence
+ CoordinateSequenceLocation nearestLocation(const geom::CoordinateXY& p) const;
diff --git a/include/geos/operation/distance/IndexedFacetDistance.h b/include/geos/operation/distance/IndexedFacetDistance.h
index 6739efbf0..46e23c034 100644
--- a/include/geos/operation/distance/IndexedFacetDistance.h
+++ b/include/geos/operation/distance/IndexedFacetDistance.h
@@ -12,12 +12,13 @@
- * Last port: operation/distance/IndexedFacetDistance.java (f6187ee2 JTS-1.14)
+ * Last port: operation/distance/IndexedFacetDistance.java (aff11591)
#pragma once
#include <geos/operation/distance/FacetSequenceTreeBuilder.h>
namespace geos {
@@ -102,6 +103,21 @@ public:
/// \return the nearest points
std::unique_ptr<geom::CoordinateSequence> nearestPoints(const geom::Geometry* g) const;
+ * Computes the nearest point on the target geometry
+ * to a point.
+ * @param p the point coordinate
+ * @return the nearest point on the target geometry
+ geom::CoordinateXY nearestPoint(const geom::CoordinateXY& p) const;
+ double distance(const geom::CoordinateXY& p) const;
+ double distance(const geom::CoordinateXY& p0, const geom::CoordinateXY& p1) const;
private:
struct FacetDistance {
diff --git a/src/algorithm/distance/DirectedHausdorffDistance.cpp b/src/algorithm/distance/DirectedHausdorffDistance.cpp
index 000000000..a5a4aa6ab
--- /dev/null
+++ b/src/algorithm/distance/DirectedHausdorffDistance.cpp
@@ -0,0 +1,659 @@
+#include <geos/algorithm/construct/IndexedPointInPolygonsLocator.h>
+#include <geos/algorithm/construct/LargestEmptyCircle.h>
+#include <geos/geom/CoordinateSequence.h>
+#include <geos/geom/Dimension.h>
+#include <geos/geom/Envelope.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/GeometryComponentFilter.h>
+#include <geos/geom/LineString.h>
+#include <geos/geom/Location.h>
+#include <geos/geom/Point.h>
+#include <geos/operation/distance/IndexedFacetDistance.h>
+#include <geos/util/IllegalArgumentException.h>
+#include <cmath>
+#include <limits>
+#include <queue>
+#include <utility>
+#include <vector>
+using geos::algorithm::construct::IndexedPointInPolygonsLocator;
+using geos::algorithm::construct::LargestEmptyCircle;
+using geos::geom::CoordinateXY;
+using geos::geom::Dimension;
+using geos::geom::Envelope;
+using geos::geom::Geometry;
+using geos::geom::GeometryComponentFilter;
+using geos::geom::LineString;
+using geos::geom::Location;
+using geos::geom::Point;
+using geos::operation::distance::IndexedFacetDistance;
+namespace geos {
+namespace {
+constexpr double EMPTY_DISTANCE = std::numeric_limits<double>::quiet_NaN();
+constexpr double AUTO_TOLERANCE_FACTOR = 1.0e4;
+constexpr double AREA_INTERIOR_TOLERANCE_FACTOR = 20;
+constexpr double FULLY_WITHIN_TOLERANCE_FACTOR = 10 * AUTO_TOLERANCE_FACTOR;
+} // namespace
+class DirectedHausdorffDistance::TargetDistance {
+public:
+ explicit TargetDistance(const Geometry& geom)
+ : distanceToFacets(&geom)
+ , isArea(geom.getDimension() >= Dimension::A)
+ if (isArea) {
+ ptInArea = std::make_unique<IndexedPointInPolygonsLocator>(geom);
+ CoordinateXY nearestFacetPoint(const CoordinateXY& p) const
+ CoordinateXY np = distanceToFacets.nearestPoint(p);
+ return np;
+ CoordinateXY nearestPoint(const CoordinateXY& p) const
+ if (ptInArea) {
+ if (ptInArea->locate(&p) != Location::EXTERIOR) {
+ return p;
+ return distanceToFacets.nearestPoint(p);
+ bool isInterior(const CoordinateXY& p) const
+ if (!isArea) {
+ return false;
+ return ptInArea->locate(&p) == Location::INTERIOR;
+ bool isInterior(const CoordinateXY& p0, const CoordinateXY& p1) const
+ if (!isArea) {
+ return false;
+ double segDist = distanceToFacets.distance(p0, p1);
+ if (segDist == 0.0) {
+ return false;
+ return isInterior(p0);
+ /// JTS isSameOrCollinear: both endpoints project onto the same target segment.
+ bool isSameOrCollinear(const CoordinateXY& p0, const CoordinateXY& p1) const
+ const auto f0 = distanceToFacets.nearestLocation(p0);
+ const auto f1 = distanceToFacets.nearestLocation(p1);
+ return f0.isSameSegment(f1);
+private:
+ IndexedFacetDistance distanceToFacets;
+ bool isArea;
+ std::unique_ptr<IndexedPointInPolygonsLocator> ptInArea;
+class DHDSegment {
+public:
+ static DHDSegment create(const CoordinateXY& p0, const CoordinateXY& p1,
+ DirectedHausdorffDistance::TargetDistance& dist)
+ DHDSegment seg(p0, p1);
+ seg.init(dist);
+ return seg;
+ static DHDSegment create(const DHDSegment& prevSeg, const CoordinateXY& p1,
+ DHDSegment seg(prevSeg.p1, p1);
+ seg.init(prevSeg.nearPt1, dist);
+ return seg;
+ CoordinateXY getEndpoint(int index) const
+ return index == 0 ? p0 : p1;
+ double getLength() const
+ return p0.distance(p1);
+ double getMaxDistance() const
+ return maxDistance;
+ double getMaxDistanceBound() const
+ return maxDistanceBound;
+ DirectedHausdorffDistance::PointPair getMaxDistPts() const
+ double dist0 = p0.distance(nearPt0);
+ double dist1 = p1.distance(nearPt1);
+ if (dist0 > dist1) {
+ return DirectedHausdorffDistance::PointPair{p0, nearPt0};
+ return DirectedHausdorffDistance::PointPair{p1, nearPt1};
+ std::array<DHDSegment, 2> bisect(DirectedHausdorffDistance::TargetDistance& dist) const
+ CoordinateXY mid((p0.x + p1.x) / 2.0, (p0.y + p1.y) / 2.0);
+ CoordinateXY nearPtMid = dist.nearestPoint(mid);
+ return {
+ DHDSegment(p0, nearPt0, mid, nearPtMid),
+ DHDSegment(mid, nearPtMid, p1, nearPt1)
+ bool operator<(const DHDSegment& other) const
+ // priority_queue is a max-heap: larger bound first
+ return maxDistanceBound < other.maxDistanceBound;
+ CoordinateXY p0;
+ CoordinateXY nearPt0;
+ CoordinateXY p1;
+ CoordinateXY nearPt1;
+private:
+ DHDSegment(const CoordinateXY& p0_, const CoordinateXY& p1_)
+ : p0(p0_)
+ , p1(p1_)
+ , maxDistanceBound(-std::numeric_limits<double>::infinity())
+ , maxDistance(0.0)
+ DHDSegment(const CoordinateXY& p0_, const CoordinateXY& nearPt0_,
+ const CoordinateXY& p1_, const CoordinateXY& nearPt1_)
+ : p0(p0_)
+ , nearPt0(nearPt0_)
+ , p1(p1_)
+ , nearPt1(nearPt1_)
+ computeMaxDistances();
+ void init(DirectedHausdorffDistance::TargetDistance& dist)
+ nearPt0 = dist.nearestPoint(p0);
+ nearPt1 = dist.nearestPoint(p1);
+ void init(const CoordinateXY& nearest0, DirectedHausdorffDistance::TargetDistance& dist)
+ nearPt0 = nearest0;
+ void computeMaxDistances()
+ maxDistance = std::max(dist0, dist1);
+ maxDistanceBound = maxDistance + getLength() / 2.0;
+ double maxDistanceBound;
+ double maxDistance;
+/* static */
+double
+DirectedHausdorffDistance::pairDistance(const std::optional<PointPair>& pts)
+ if (!pts) {
+ return EMPTY_DISTANCE;
+ return (*pts)[0].distance((*pts)[1]);
+/* static */
+DirectedHausdorffDistance::PointPair
+DirectedHausdorffDistance::pair(const CoordinateXY& p0, const CoordinateXY& p1)
+ return PointPair{p0, p1};
+/* static */
+double
+DirectedHausdorffDistance::computeTolerance(const Geometry& geom)
+ return geom.getEnvelopeInternal()->getDiameter() / AUTO_TOLERANCE_FACTOR;
+/* static */
+bool
+DirectedHausdorffDistance::isBeyond(
+ const Envelope& envA, const Envelope& envB, double maxDistance)
+ if (envA.isNull() || envB.isNull()) {
+ return false;
+ return envA.getMinX() < envB.getMinX() - maxDistance
+ || envA.getMinY() < envB.getMinY() - maxDistance
+ || envA.getMaxX() > envB.getMaxX() + maxDistance
+ || envA.getMaxY() > envB.getMaxY() + maxDistance;
+/* static */
+bool
+DirectedHausdorffDistance::isValidLimit(double limit)
+ return limit >= 0.0;
+/* static */
+bool
+DirectedHausdorffDistance::isBeyondLimit(double maxDist, double maxDistanceLimit)
+ return maxDistanceLimit >= 0 && maxDist > maxDistanceLimit;
+/* static */
+bool
+DirectedHausdorffDistance::isWithinLimit(double maxDist, double maxDistanceLimit)
+ return maxDistanceLimit >= 0 && maxDist <= maxDistanceLimit;
+/* static */
+double
+DirectedHausdorffDistance::distance(const Geometry& a, const Geometry& b)
+ DirectedHausdorffDistance hd(b);
+ return pairDistance(hd.farthestPoints(a));
+/* static */
+double
+DirectedHausdorffDistance::distance(const Geometry& a, const Geometry& b, double tolerance)
+ return pairDistance(hd.farthestPoints(a, tolerance));
+/* static */
+std::optional<DirectedHausdorffDistance::PointPair>
+DirectedHausdorffDistance::distancePoints(const Geometry& a, const Geometry& b)
+ DirectedHausdorffDistance dhd(b);
+ return dhd.farthestPoints(a);
+/* static */
+ const Geometry& a, const Geometry& b, double tolerance)
+ return dhd.farthestPoints(a, tolerance);
+/* static */
+DirectedHausdorffDistance::hausdorffDistancePoints(const Geometry& a, const Geometry& b)
+ DirectedHausdorffDistance hdAB(b);
+ auto ptsAB = hdAB.farthestPoints(a);
+ DirectedHausdorffDistance hdBA(a);
+ auto ptsBA = hdBA.farthestPoints(b);
+ if (!ptsAB) {
+ return ptsBA ? std::optional<PointPair>(pair((*ptsBA)[1], (*ptsBA)[0])) : std::nullopt;
+ if (!ptsBA) {
+ return ptsAB;
+ if (pairDistance(ptsBA) > pairDistance(ptsAB)) {
+ return pair((*ptsBA)[1], (*ptsBA)[0]);
+ return ptsAB;
+/* static */
+double
+DirectedHausdorffDistance::hausdorffDistance(const Geometry& a, const Geometry& b)
+ return pairDistance(hausdorffDistancePoints(a, b));
+/* static */
+bool
+DirectedHausdorffDistance::isFullyWithinDistance(
+ const Geometry& a, const Geometry& b, double maxDistance)
+ return hd.isFullyWithinDistance(a, maxDistance);
+/* static */
+bool
+ const Geometry& a, const Geometry& b, double maxDistance, double tolerance)
+ return hd.isFullyWithinDistance(a, maxDistance, tolerance);
+DirectedHausdorffDistance::DirectedHausdorffDistance(const Geometry& geom)
+ : target(geom)
+ , targetDistance(std::make_unique<TargetDistance>(geom))
+DirectedHausdorffDistance::~DirectedHausdorffDistance() = default;
+bool
+ const Geometry& geom, double maxDistance) const
+ double tolerance = maxDistance / FULLY_WITHIN_TOLERANCE_FACTOR;
+ return isFullyWithinDistance(geom, maxDistance, tolerance);
+bool
+ const Geometry& geom, double maxDistance, double tolerance) const
+ if (geom.isEmpty() || target.isEmpty()) {
+ return false;
+ if (isBeyond(*geom.getEnvelopeInternal(), *target.getEnvelopeInternal(), maxDistance)) {
+ return false;
+ auto maxDistCoords = computeDistancePoints(geom, tolerance, maxDistance);
+ if (!maxDistCoords) {
+ return false;
+ return pairDistance(maxDistCoords) <= maxDistance;
+DirectedHausdorffDistance::farthestPoints(const Geometry& geom) const
+ return farthestPoints(geom, computeTolerance(geom));
+DirectedHausdorffDistance::farthestPoints(const Geometry& geom, double tolerance) const
+ return computeDistancePoints(geom, tolerance, -1.0);
+DirectedHausdorffDistance::computeDistancePoints(
+ const Geometry& geom, double tolerance, double maxDistanceLimit) const
+ if (tolerance < 0.0) {
+ throw util::IllegalArgumentException("Tolerance must be non-negative");
+ return std::nullopt;
+ if (geom.getDimension() == Dimension::P) {
+ return computeForPoints(geom, maxDistanceLimit);
+ auto maxDistPtsEdge = computeForEdges(geom, tolerance, maxDistanceLimit);
+ if (isBeyondLimit(pairDistance(maxDistPtsEdge), maxDistanceLimit)) {
+ return maxDistPtsEdge;
+ if (geom.getDimension() == Dimension::A) {
+ auto maxDistPtsInterior = computeForAreaInterior(geom, tolerance);
+ if (maxDistPtsInterior
+ && pairDistance(maxDistPtsInterior) > pairDistance(maxDistPtsEdge)) {
+ return maxDistPtsInterior;
+DirectedHausdorffDistance::computeForPoints(
+ const Geometry& geom, double maxDistanceLimit) const
+ double maxDist = -1.0;
+ std::optional<PointPair> maxDistPtsAB;
+ struct PointFilter : public GeometryComponentFilter {
+ PointFilter(TargetDistance& td, double& md, std::optional<PointPair>& pts,
+ double limit)
+ : targetDistance(td), maxDist(md), maxDistPtsAB(pts), maxDistanceLimit(limit), done(false)
+ bool isDone() override {
+ return done;
+ void filter_ro(const Geometry* geomElem) override
+ if (geomElem->getGeometryTypeId() != geom::GEOS_POINT) {
+ return;
+ const CoordinateXY* pA = geomElem->getCoordinate();
+ CoordinateXY pB = targetDistance.nearestPoint(*pA);
+ double dist = pA->distance(pB);
+ bool interior = dist > 0 && targetDistance.isInterior(*pA);
+ if (interior) {
+ dist = 0;
+ pB = *pA;
+ if (dist > maxDist) {
+ maxDist = dist;
+ maxDistPtsAB = DirectedHausdorffDistance::pair(*pA, pB);
+ if (DirectedHausdorffDistance::isValidLimit(maxDistanceLimit)
+ && DirectedHausdorffDistance::isBeyondLimit(maxDist, maxDistanceLimit)) {
+ done = true;
+ TargetDistance& targetDistance;
+ double& maxDist;
+ std::optional<PointPair>& maxDistPtsAB;
+ double maxDistanceLimit;
+ bool done;
+ PointFilter filter(*targetDistance, maxDist, maxDistPtsAB, maxDistanceLimit);
+ geom.apply_ro(&filter);
+ return maxDistPtsAB;
+DirectedHausdorffDistance::computeForEdges(
+ std::priority_queue<DHDSegment> segQueue;
+ struct LineFilter : public GeometryComponentFilter {
+ LineFilter(std::priority_queue<DHDSegment>& q, TargetDistance& td)
+ : segQueue(q), targetDistance(td)
+ void filter_ro(const Geometry* g) override
+ const LineString* ls = dynamic_cast<const LineString*>(g);
+ if (!ls || ls->isEmpty()) {
+ return;
+ const auto* pts = ls->getCoordinatesRO();
+ if (!pts || pts->size() < 2) {
+ return;
+ DHDSegment prevSeg = DHDSegment::create(pts->getAt<CoordinateXY>(0),
+ pts->getAt<CoordinateXY>(1),
+ targetDistance);
+ consider(prevSeg);
+ for (std::size_t i = 1; i < pts->size() - 1; i++) {
+ DHDSegment seg = DHDSegment::create(prevSeg, pts->getAt<CoordinateXY>(i + 1), targetDistance);
+ consider(seg);
+ prevSeg = seg;
+ void addNonInterior(const DHDSegment& segment) const
+ if (segment.getMaxDistance() > 0.0) {
+ segQueue.push(segment);
+ return;
+ if (targetDistance.isInterior(segment.getEndpoint(0), segment.getEndpoint(1))) {
+ return;
+ void consider(const DHDSegment& seg)
+ if (!segMaxDist || seg.getMaxDistanceBound() > segMaxDist->getMaxDistance()) {
+ addNonInterior(seg);
+ if (!segMaxDist || seg.getMaxDistance() > segMaxDist->getMaxDistance()) {
+ segMaxDist = seg;
+ std::priority_queue<DHDSegment>& segQueue;
+ std::optional<DHDSegment> segMaxDist;
+ LineFilter filter(segQueue, *targetDistance);
+ while (!segQueue.empty()) {
+ DHDSegment segMaxBound = segQueue.top();
+ segQueue.pop();
+ // Save if segment point is farther than current farthest
+ if (!segMaxDist || segMaxBound.getMaxDistance() > segMaxDist->getMaxDistance()) {
+ segMaxDist = segMaxBound;
+ // Stop searching if remaining items in queue must all be closer
+ // than the current maximum distance.
+ if (segMaxBound.getMaxDistanceBound() <= segMaxDist->getMaxDistance()) {
+ break;
+ // If maxDistanceLimit is specified, can stop searching if:
+ // - if segment distance bound is less than distance limit, no other segment can be farther
+ // - if a point of segment is farther than limit, isFullyWithin must be false
+ if (isValidLimit(maxDistanceLimit)) {
+ if (isWithinLimit(segMaxBound.getMaxDistanceBound(), maxDistanceLimit)
+ || isBeyondLimit(segMaxBound.getMaxDistance(), maxDistanceLimit)) {
+ break;
+ // Check for equal or collinear segments.
+ // If so, don't bisect the segment further.
+ // This greatly improves performance when the inputs
+ // have identical or collinear segments
+ // (in particular, the case when the inputs are identical).
+ if (segMaxBound.getMaxDistance() == 0.0
+ && targetDistance->isSameOrCollinear(
+ segMaxBound.getEndpoint(0), segMaxBound.getEndpoint(1))) {
+ continue;
+ // If segment is longer than tolerance
+ // it might provide a better max distance point,
+ // so bisect and keep searching.
+ if (tolerance > 0 && segMaxBound.getLength() > tolerance) {
+ auto bisects = segMaxBound.bisect(*targetDistance);
+ filter.addNonInterior(bisects[0]);
+ filter.addNonInterior(bisects[1]);
+ // A segment at maximum distance was found.
+ // Return the farthest point pair
+ if (segMaxDist) {
+ return segMaxDist->getMaxDistPts();
+ // No DHD segment was found.
+ // This must be because all were inside the target.
+ // In this case distance is zero.
+ // Return a single coordinate of the input as a representative point
+ const CoordinateXY *maxPt = geom.getCoordinate();
+ if (!maxPt) {
+ return pair(*maxPt, *maxPt);
+DirectedHausdorffDistance::computeForAreaInterior(
+ const Geometry& geom, double tolerance) const
+ if (tolerance <= 0.0) {
+ const Geometry& polygonal = geom;
+ if (polygonal.getEnvelopeInternal()->disjoint(target.getEnvelopeInternal())) {
+ LargestEmptyCircle lec(&target, &polygonal, tolerance * AREA_INTERIOR_TOLERANCE_FACTOR);
+ auto centerPt = lec.getCenter();
+ const CoordinateXY* ptA = centerPt->getCoordinate();
+ if (!ptA) {
+ if (targetDistance->isInterior(*ptA)) {
+ CoordinateXY ptB = targetDistance->nearestFacetPoint(*ptA);
+ return pair(*ptA, ptB);
diff --git a/src/operation/distance/CoordinateSequenceLocation.cpp b/src/operation/distance/CoordinateSequenceLocation.cpp
index 000000000..7e6281a02
--- /dev/null
+++ b/src/operation/distance/CoordinateSequenceLocation.cpp
@@ -0,0 +1,107 @@
+using geos::geom::CoordinateSequence;
+namespace geos {
+CoordinateSequenceLocation::CoordinateSequenceLocation(
+ const CoordinateSequence* p_seq, std::size_t p_index, const CoordinateXY& p_pt)
+ : seq(p_seq)
+ , index(p_index)
+ , pt(p_pt)
+ if (seq && index >= seq->size() && seq->size() > 0) {
+ index = seq->size() - 1;
+const CoordinateXY&
+CoordinateSequenceLocation::getCoordinate() const
+ return pt;
+std::size_t
+CoordinateSequenceLocation::getIndex() const
+ return index;
+bool
+CoordinateSequenceLocation::isSameSegment(const CoordinateSequenceLocation& f) const
+ if (seq != f.seq) {
+ return false;
+ if (index == f.index) {
+ return true;
+ //-- check for end pt same as start point of next segment
+ if (isNext(index, f.index)) {
+ const CoordinateXY& endPt = seq->getAt<CoordinateXY>(index + 1);
+ return f.pt.equals2D(endPt);
+ if (isNext(f.index, index)) {
+ const CoordinateXY& endPt = f.seq->getAt<CoordinateXY>(index + 1);
+ return pt.equals2D(endPt);
+ return false;
+bool
+CoordinateSequenceLocation::isNext(std::size_t p_index, std::size_t index1) const
+ if (index1 == p_index + 1) {
+ return true;
+ // JTS writes `index1 == 0 && isRing && index1 == size-1`, which is
+ // unreachable. The ring wrap is last segment (size-2) adjacent to 0.
+ if (seq && seq->isRing() && index1 == 0 && p_index + 1 == seq->size() - 1) {
+ return true;
+ return false;
+CoordinateSequenceLocation::getEndPoint(int i) const
+ if (i == 0) {
+ return seq->getAt<CoordinateXY>(index);
+ return seq->getAt<CoordinateXY>(index + 1);
+std::size_t
+CoordinateSequenceLocation::normalize(std::size_t p_index) const
+ if (seq && p_index >= seq->size() - 1 && seq->isRing()) {
+ return 0;
+ return p_index;
diff --git a/src/operation/distance/FacetSequence.cpp b/src/operation/distance/FacetSequence.cpp
index ebc1501dd..2b08f1b72 100644
--- a/src/operation/distance/FacetSequence.cpp
+++ b/src/operation/distance/FacetSequence.cpp
@@ -12,10 +12,11 @@
#include <geos/geom/LineSegment.h>
#include <geos/algorithm/Distance.h>
@@ -229,3 +230,57 @@ FacetSequence::getCoordinate(std::size_t index) const
return &(pts->getAt(start + index));
+std::size_t
+FacetSequence::normalize(const CoordinateSequence& pts, std::size_t index)
+ if (index >= pts.size() - 1 && pts.isRing()) {
+ return 0;
+ return index;
+FacetSequence::nearestLocation(const CoordinateXY& p) const
+ if (isPoint()) {
+ // JTS uses index 0 / pts[0]; use start so a one-point facet
+ // that is a subsequence of a longer CoordinateSequence is correct.
+ return CoordinateSequenceLocation(pts, start, pts->getAt(start));
+ return nearestLocationOnLine(p);
+FacetSequence::nearestLocationOnLine(const CoordinateXY& pt) const
+ double minDistance = DoubleInfinity;
+ std::size_t index = start;
+ Coordinate nearestPt;
+ const Coordinate queryPt(pt);
+ for (std::size_t i = start; i < end - 1; i++) {
+ const Coordinate& q0 = pts->getAt(i);
+ const Coordinate& q1 = pts->getAt(i + 1);
+ double dist = Distance::pointToSegment(queryPt, q0, q1);
+ if (dist < minDistance) {
+ minDistance = dist;
+ LineSegment seg(q0, q1);
+ seg.closestPoint(queryPt, nearestPt);
+ index = i;
+ //-- segments are half-open, so 2nd endpoint belongs to next segment
+ //-- except for last segment on non-closed sequence
+ if (dist == 0.0 && queryPt.equals2D(q1)) {
+ if (index < pts->size() - 1) {
+ index++;
+ //-- normalize index for a ring
+ index = normalize(*pts, index);
+ if (minDistance <= 0.0) {
+ break;
+ return CoordinateSequenceLocation(pts, index, nearestPt);
diff --git a/src/operation/distance/IndexedFacetDistance.cpp b/src/operation/distance/IndexedFacetDistance.cpp
index 6555920cd..babe15438 100644
--- a/src/operation/distance/IndexedFacetDistance.cpp
+++ b/src/operation/distance/IndexedFacetDistance.cpp
@@ -12,13 +12,16 @@
#include <geos/index/strtree/STRtree.h>
+#include <geos/operation/distance/FacetSequence.h>
+#include <geos/util/GEOSException.h>
using namespace geos::geom;
using namespace geos::index::strtree;
@@ -105,6 +108,48 @@ IndexedFacetDistance::isWithinDistance(const Geometry* g, double maxDistance) co
return cachedTree->isWithinDistance<FacetDistance>(*tree2, maxDistance);
+IndexedFacetDistance::nearestLocation(const geom::CoordinateXY& p) const
+ // JTS wraps p in a CoordinateArraySequence; GEOS CoordinateSequence is the equivalent.
+ CoordinateSequence seq{CoordinateXY(p.x, p.y)};
+ FacetSequence query(&seq, 0, 1);
+ FacetDistance itemDist;
+ const FacetSequence* nearest = cachedTree->nearestNeighbour<FacetDistance>(
+ *query.getEnvelope(), &query, itemDist);
+ if (!nearest) {
+ throw util::GEOSException("Cannot calculate IndexedFacetDistance on empty geometries.");
+ return nearest->nearestLocation(p);
+geom::CoordinateXY
+IndexedFacetDistance::nearestPoint(const geom::CoordinateXY& p) const
+ return nearestLocation(p).getCoordinate();
+double
+IndexedFacetDistance::distance(const geom::CoordinateXY& p) const
+ return p.distance(nearestPoint(p));
+double
+IndexedFacetDistance::distance(const geom::CoordinateXY& p0, const geom::CoordinateXY& p1) const
+ CoordinateSequence seq{CoordinateXY(p0.x, p0.y), CoordinateXY(p1.x, p1.y)};
+ FacetSequence query(&seq, 0, 2);
+ if (!nearest) {
+ auto locs = nearest->nearestLocations(query);
+ return locs[0].distance(locs[1]);
diff --git a/tests/unit/algorithm/distance/DirectedHausdorffDistanceTest.cpp b/tests/unit/algorithm/distance/DirectedHausdorffDistanceTest.cpp
index 000000000..5d9c4ce09
--- /dev/null
+++ b/tests/unit/algorithm/distance/DirectedHausdorffDistanceTest.cpp
@@ -0,0 +1,630 @@
+// Test Suite for geos::algorithm::distance::DirectedHausdorffDistance
+// Ported from JTS DirectedHausdorffDistanceTest (locationtech/jts#1182)
+// plus the discrete-under-estimate witness from DiscreteHausdorffDistance.
+#include <tut/tut.hpp>
+#include <tut/tut_macros.hpp>
+#include <geos/algorithm/distance/DiscreteHausdorffDistance.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/PrecisionModel.h>
+#include <geos/io/WKTReader.h>
+#include <cmath>
+#include <memory>
+#include <string>
+#include "utility.h"
+using geos::algorithm::distance::DiscreteHausdorffDistance;
+using geos::geom::GeometryFactory;
+using geos::geom::PrecisionModel;
+namespace tut {
+struct test_directedhausdorffdistance_data {
+ test_directedhausdorffdistance_data()
+ : pm()
+ , gf(GeometryFactory::create(&pm))
+ , reader(gf.get())
+ static constexpr double TOLERANCE = 0.001;
+ std::unique_ptr<Geometry>
+ read(const std::string& wkt) const
+ return reader.read(wkt);
+ void
+ checkDistance(const std::string& wkt1, const std::string& wkt2,
+ double expectedDistance) const
+ auto g1 = read(wkt1);
+ auto g2 = read(wkt2);
+ double dist = DirectedHausdorffDistance::distance(*g1, *g2);
+ ensure(std::fabs(dist - expectedDistance) <= TOLERANCE);
+ void checkDistance(const std::string& wkt1, const std::string& wkt2,
+ double tolerance, const std::string& wktExpected) const
+ auto pts = DirectedHausdorffDistance::distancePoints(*g1, *g2, tolerance);
+ ensure(pts.has_value());
+ auto seq = std::make_unique<geos::geom::CoordinateSequence>(2);
+ seq->setAt(pts.value()[0], 0);
+ seq->setAt(pts.value()[1], 1);
+ auto result = g1->getFactory()->createLineString(std::move(seq));
+ ensure_equals_exact_geometry(static_cast<const Geometry*>(result.get()), read(wktExpected).get(), TOLERANCE);
+ void checkDistanceStartPtLen(const std::string wkt1, const std::string& wkt2,
+ const std::string& wktExpected, double resultTolerance) const
+ auto pts = DirectedHausdorffDistance::distancePoints(*g1, *g2);
+ auto expected = reader.read<LineString>(wktExpected);
+ const CoordinateXY& resultPt = result->getCoordinatesRO()->getAt<CoordinateXY>(0);
+ const CoordinateXY& expectedPt = expected->getCoordinatesRO()->getAt<CoordinateXY>(0);
+ ensure_equals_xy(expectedPt, resultPt, resultTolerance);
+ double distResult = result->getLength();
+ double distExpected = expected->getLength();
+ ensure_equals("distance is not within tolerance of expected", distExpected, distResult, resultTolerance);
+ void
+ double tolerance, double expectedDistance) const
+ double dist = DirectedHausdorffDistance::distance(*g1, *g2, tolerance);
+ void
+ const std::string& wktExpected) const
+ void
+ checkHausdorff(const std::string& wkt1, const std::string& wkt2,
+ std::unique_ptr<Geometry> g1 = read(wkt1);
+ std::unique_ptr<Geometry> g2 = read(wkt2);
+ auto pts = DirectedHausdorffDistance::hausdorffDistancePoints(*g1, *g2);
+ void
+ checkDistanceEmpty(const std::string& a, const std::string& b) const
+ std::unique_ptr<Geometry> g1 = read(a);
+ std::unique_ptr<Geometry> g2 = read(b);
+ ensure(!DirectedHausdorffDistance::distancePoints(*g1, *g2).has_value());
+ ensure(std::isnan(DirectedHausdorffDistance::distance(*g1, *g2)));
+ ensure(std::isnan(DirectedHausdorffDistance::hausdorffDistance(*g1, *g2)));
+ void
+ checkFullyWithinDistance(const std::string& a, const std::string& b,
+ double distance, bool expected) const
+ bool result = DirectedHausdorffDistance::isFullyWithinDistance(*g1, *g2, distance);
+ ensure_equals(result, expected);
+ void checkFullyWithinDistanceEmpty(const std::string& a, const std::string& b) const
+ checkFullyWithinDistance(a, b, 0, false);
+ checkFullyWithinDistance(b, a, 0, false);
+ checkFullyWithinDistance(a, b, 1, false);
+ checkFullyWithinDistance(b, a, 1, false);
+ checkFullyWithinDistance(a, b, 1000, false);
+ checkFullyWithinDistance(b, a, 1000, false);
+ PrecisionModel pm;
+ GeometryFactory::Ptr gf;
+ geos::io::WKTReader reader;
+typedef test_group<test_directedhausdorffdistance_data> group;
+typedef group::object object;
+group test_DirectedHausdorffDistance_group(
+ "geos::algorithm::distance::DirectedHausdorffDistance");
+template<>
+template<>
+void object::test<1>()
+ set_test_name("testEmpty");
+ checkDistanceEmpty("POINT EMPTY", "POINT (1 1)");
+ checkDistanceEmpty("LINESTRING EMPTY", "LINESTRING (0 0, 2 1)");
+ checkDistanceEmpty("POLYGON EMPTY", "POLYGON ((1 9, 9 9, 9 1, 1 1, 1 9))");
+template<>
+template<>
+void object::test<2>()
+ set_test_name("testZeroTolerancePoint");
+ checkDistance("POINT (5 5)", "LINESTRING (5 1, 9 5)",
+ 0,
+ "LINESTRING (5 5, 7 3)");
+template<>
+template<>
+void object::test<3>()
+ set_test_name("testZeroToleranceLine");
+ checkDistance("LINESTRING (1 5, 5 5)", "LINESTRING (5 1, 9 5)",
+ 0,
+ "LINESTRING (1 5, 5 1)");
+template<>
+template<>
+void object::test<4>()
+ set_test_name("testZeroToleranceZeroLengthLineQuery");
+ checkDistance("LINESTRING (5 5, 5 5)", "LINESTRING (5 1, 9 5)",
+ 0,
+template<>
+template<>
+void object::test<5>()
+ set_test_name("testZeroLengthLineQuery");
+template<>
+template<>
+void object::test<6>()
+ set_test_name("testZeroLengthPolygonQuery");
+ checkDistance("POLYGON ((5 5, 5 5, 5 5, 5 5))", "LINESTRING (5 1, 9 5)",
+template<>
+template<>
+void object::test<7>()
+ set_test_name("testZeroLengthLineTarget");
+ checkDistance("POINT (5 5)", "LINESTRING (5 1, 5 1)",
+ "LINESTRING (5 5, 5 1)");
+template<>
+template<>
+void object::test<8>()
+ set_test_name("testNegativeTolerancePoint");
+ auto g1 = read("POINT (5 5)");
+ auto g2 = read("LINESTRING (5 1, 9 5)");
+ ensure_THROW(DirectedHausdorffDistance::distance(*g1, *g2, -1.0), geos::util::IllegalArgumentException);
+template<>
+template<>
+void object::test<9>()
+ set_test_name("testNegativeToleranceLine");
+ auto g1 = read("LINESTRING (1 1, 5 5)");
+template<>
+template<>
+void object::test<10>()
+ set_test_name("testPointPoint");
+ checkHausdorff("POINT (0 0)", "POINT (1 1)", "LINESTRING (0 0, 1 1)");
+template<>
+template<>
+void object::test<11>()
+ set_test_name("testPointPoints");
+ std::string a = "MULTIPOINT ((0 1), (2 3), (4 5), (6 6))";
+ std::string b = "MULTIPOINT ((0.1 0), (1 0), (2 0), (3 0), (4 0), (5 0))";
+ checkDistance(a, b, "LINESTRING (6 6, 5 0)");
+ checkDistance(b, a, "LINESTRING (5 0, 2 3)");
+ checkHausdorff(a, b, "LINESTRING (6 6, 5 0)");
+template<>
+template<>
+void object::test<12>()
+ set_test_name("testPointPolygonInterior");
+ checkDistance("POINT (3 4)", "POLYGON ((1 9, 9 9, 9 1, 1 1, 1 9))",
+ 0);
+template<>
+template<>
+void object::test<13>()
+ set_test_name("testPointsPolygon");
+ checkDistance("MULTIPOINT ((4 3), (2 8), (8 5))", "POLYGON ((6 9, 6 4, 9 1, 1 1, 6 9))",
+ "LINESTRING (2 8, 4.426966292134832 6.48314606741573)");
+template<>
+template<>
+void object::test<14>()
+ set_test_name("testLineSegments");
+ checkHausdorff("LINESTRING (0 0, 2 0)", "LINESTRING (0 0, 2 1)",
+ "LINESTRING (2 0, 2 1)");
+template<>
+template<>
+void object::test<15>()
+ set_test_name("testLineSegments2");
+ checkHausdorff("LINESTRING (0 0, 2 0)", "LINESTRING (0 1, 1 2, 2 1)",
+ "LINESTRING (1 0, 1 2)");
+template<>
+template<>
+void object::test<16>()
+ set_test_name("testLinePoints");
+ checkHausdorff("LINESTRING (0 0, 2 0)", "MULTIPOINT (0 2, 1 0, 2 1)",
+ "LINESTRING (0 0, 0 2)");
+template<>
+template<>
+void object::test<17>()
+ set_test_name("testLinesTopoEqual");
+ checkDistance("MULTILINESTRING ((10 10, 10 90, 40 30), (40 30, 60 80, 90 30, 40 10))",
+ "LINESTRING (10 10, 10 90, 40 30, 60 80, 90 30, 40 10)",
+ 0.0);
+template<>
+template<>
+void object::test<18>()
+ set_test_name("testLinesPolygon");
+ checkHausdorff("MULTILINESTRING ((1 1, 2 7), (7 1, 9 9))",
+ "POLYGON ((3 7, 6 7, 6 4, 3 4, 3 7))",
+ "LINESTRING (9 9, 6 7)");
+template<>
+template<>
+void object::test<19>()
+ set_test_name("testLinesPolygon2");
+ std::string a = "MULTILINESTRING ((2 3, 2 7), (9 1, 9 8, 4 9))";
+ std::string b = "POLYGON ((3 7, 6 8, 8 2, 3 4, 3 7))";
+ checkDistance(a, b, "LINESTRING (9 8, 6.3 7.1)");
+ checkHausdorff(a, b, "LINESTRING (2 3, 5.5 3)");
+template<>
+template<>
+void object::test<20>()
+ set_test_name("testPolygonLineCrossingBoundaryResult");
+ checkDistance("POLYGON ((2 8, 8 2, 2 1, 2 8))",
+ "LINESTRING (6 5, 4 7, 0 0, 8 4)",
+ "LINESTRING (2 8, 3.9384615384615387 6.892307692307693)");
+template<>
+template<>
+void object::test<21>()
+ set_test_name("testPolygonLineCrossingInteriorPoint");
+ checkDistanceStartPtLen("POLYGON ((2 8, 8 2, 2 1, 2 8))",
+ "LINESTRING (6 5, 4 7, 0 0, 9 1)",
+ "LINESTRING (4.555 2.989, 4.828 0.536)", 0.01);
+template<>
+template<>
+void object::test<22>()
+ set_test_name("testPolygonPolygon");
+ std::string a = "POLYGON ((2 18, 18 18, 17 3, 2 2, 2 18))";
+ std::string b = "POLYGON ((1 19, 5 12, 5 3, 14 10, 11 19, 19 19, 20 0, 1 1, 1 19))";
+ checkDistance(b, a, "LINESTRING (20 0, 17 3)");
+ checkDistance(a, b, "LINESTRING (6.6796875 18, 11 19)");
+ checkHausdorff(a, b, "LINESTRING (6.6796875 18, 11 19)");
+template<>
+template<>
+void object::test<23>()
+ set_test_name("testPolygonPolygonHolesNested");
+ // B is contained in A
+ std::string a = "POLYGON ((1 19, 19 19, 19 1, 1 1, 1 19), (6 8, 11 14, 15 7, 6 8))";
+ std::string b = "POLYGON ((2 18, 18 18, 18 2, 2 2, 2 18), (10 17, 3 7, 17 5, 10 17))";
+ checkDistance(a, b, "LINESTRING (9.817138671875 12.58056640625, 7.863620425230705 13.948029178901006)");
+ checkDistance(b, a, 0.0);
+template<>
+template<>
+void object::test<24>()
+ set_test_name("testMultiPolygons");
+ std::string a = "MULTIPOLYGON (((1 1, 1 10, 5 1, 1 1)), ((4 17, 9 15, 9 6, 4 17)))";
+ std::string b = "MULTIPOLYGON (((1 12, 4 13, 8 10, 1 12)), ((3 8, 7 7, 6 2, 3 8)))";
+ checkDistance(a, b, "LINESTRING (1 1, 5.4 3.2)");
+ checkDistanceStartPtLen(b, a,
+ "LINESTRING (2.669921875 12.556640625, 5.446115154109589 13.818546660958905)",
+ 0.01);
+template<>
+template<>
+void object::test<25>()
+ set_test_name("testLinePolygonCrossing");
+ std::string wkt1 = "LINESTRING (2 5, 5 10, 6 4)";
+ std::string wkt2 = "POLYGON ((1 9, 9 9, 9 1, 1 1, 1 9))";
+ checkDistance(wkt1, wkt2, "LINESTRING (5 10, 5 9)");
+template<>
+template<>
+void object::test<26>()
+ set_test_name("testNonVertexResult");
+ std::string wkt1 = "LINESTRING (1 1, 5 10, 9 1)";
+ std::string wkt2 = "LINESTRING (0 10, 0 0, 10 0)";
+ checkHausdorff(wkt1, wkt2, "LINESTRING (6.53857421875 6.5382080078125, 6.53857421875 0)");
+ checkDistance(wkt1, wkt2, "LINESTRING (6.53857421875 6.5382080078125, 6.53857421875 0)");
+template<>
+template<>
+void object::test<27>()
+ set_test_name("testDirectedLines");
+ std::string wkt1 = "LINESTRING (1 6, 3 5, 1 4)";
+ std::string wkt2 = "LINESTRING (1 10, 9 5, 1 2)";
+ checkDistance(wkt1, wkt2, "LINESTRING (1 6, 2.797752808988764 8.876404494382022)");
+ checkDistance(wkt2, wkt1, "LINESTRING (9 5, 3 5)");
+template<>
+template<>
+void object::test<28>()
+ set_test_name("testDirectedLines2");
+ std::string wkt2 = "LINESTRING (1 3, 1 9, 9 5, 1 1)";
+ checkDistance(wkt1, wkt2, "LINESTRING (3 5, 1 5)");
+ * Tests that segments are detected as interior even for a large tolerance.
+template<>
+template<>
+void object::test<29>()
+ set_test_name("testInteriorSegmentsLargeTol");
+ std::string a = "POLYGON ((4 6, 5 6, 5 5, 4 5, 4 6))";
+ std::string b = "POLYGON ((1 9, 9 9, 9 1, 1 1, 1 9))";
+ checkDistance(a, b, 2.0, 0.0);
+ * Tests that segment endpoint nearest points
+ * which are interior to B have distance 0
+template<>
+template<>
+void object::test<30>()
+ set_test_name("testInteriorSegmentsSameExterior");
+ std::string a = "POLYGON ((1 9, 3 9, 4 5, 5.05 9, 9 9, 9 1, 1 1, 1 9))";
+ checkDistance(a, b, 0.0);
+template<>
+template<>
+void object::test<31>()
+ set_test_name("testFullyWithinDistanceEmptyPoints");
+ std::string a = "POINT EMPTY";
+ std::string b = "MULTIPOINT ((1 1), (9 9))";
+ checkFullyWithinDistanceEmpty(a, b);
+template<>
+template<>
+void object::test<32>()
+ set_test_name("testFullyWithinDistanceEmptyLine");
+ std::string a = "LINESTRING EMPTY";
+ std::string b = "LINESTRING (9 9, 1 1)";
+template<>
+template<>
+void object::test<33>()
+ //-- shows withinDistance envelope check not triggering for disconnected A
+ set_test_name("testFullyWithinDistancePoints");
+ std::string a = "MULTIPOINT ((1 9), (9 1))";
+ checkFullyWithinDistance(a, b, 8.1, true);
+template<>
+template<>
+void object::test<34>()
+ set_test_name("testFullyWithinDistanceDisconnectedLines");
+ std::string a = "MULTILINESTRING ((1 9, 2 9), (8 1, 9 1))";
+ checkFullyWithinDistance(a, b, 6, true);
+ checkFullyWithinDistance(b, a, 7.1, true);
+template<>
+template<>
+void object::test<35>()
+ set_test_name("testFullyWithinDistanceDisconnectedPolygons");
+ std::string a = "MULTIPOLYGON (((1 9, 2 9, 2 8, 1 8, 1 9)), ((8 2, 9 2, 9 1, 8 1, 8 2)))";
+ std::string b = "POLYGON ((1 2, 9 9, 2 1, 1 2))";
+ checkFullyWithinDistance(a, b, 5.3, true);
+template<>
+template<>
+void object::test<36>()
+ set_test_name("testFullyWithinDistanceLines");
+ std::string a = "MULTILINESTRING ((1 1, 3 3), (7 7, 9 9))";
+ std::string b = "MULTILINESTRING ((1 9, 1 5), (6 4, 8 2))";
+ checkFullyWithinDistance(a, b, 4, false);
+template<>
+template<>
+void object::test<37>()
+ set_test_name("testFullyWithinDistancePolygons");
+ std::string a = "POLYGON ((1 4, 4 4, 4 1, 1 1, 1 4))";
+ std::string b = "POLYGON ((10 10, 10 15, 15 15, 15 10, 10 10))";
+ checkFullyWithinDistance(a, b, 5, false);
+ checkFullyWithinDistance(a, b, 10, false);
+ checkFullyWithinDistance(a, b, 20, true);
+template<>
+template<>
+void object::test<38>()
+ set_test_name("testFullyWithinDistancePolygonsNestedWithHole");
+ std::string a = "POLYGON ((2 8, 8 8, 8 2, 2 2, 2 8))";
+ std::string b = "POLYGON ((1 9, 9 9, 9 1, 1 1, 1 9), (3 7, 7 7, 7 3, 3 3, 3 7))";
+ checkFullyWithinDistance(a, b, 2, true);
+ checkFullyWithinDistance(a, b, 3, true);
+} // namespace tut
diff --git a/tests/unit/capi/GEOSDirectedHausdorffDistanceTest.cpp b/tests/unit/capi/GEOSDirectedHausdorffDistanceTest.cpp
index 000000000..3832542e9
--- /dev/null
+++ b/tests/unit/capi/GEOSDirectedHausdorffDistanceTest.cpp
@@ -0,0 +1,96 @@
+// Test Suite for C-API GEOSDirectedHausdorffDistance /
+// GEOSSymmetricHausdorffDistance
+#include <geos_c.h>
+#include "capi_test_utils.h"
+#include <cmath>
+namespace tut {
+struct test_capigeosdirectedhausdorffdistance_data : public capitest::utility {
+typedef test_group<test_capigeosdirectedhausdorffdistance_data> group;
+group test_capigeosdirectedhausdorffdistance_group(
+ "capi::GEOSDirectedHausdorffDistance");
+template<>
+template<>
+ set_test_name("maximum distance point pair within segment interior");
+ geom1_ = fromWKT("LINESTRING (0 0, 100 0, 10 100, 10 100)");
+ geom2_ = fromWKT("LINESTRING (0 100, 0 10, 80 10)");
+ double discrete = 0.0;
+ double directed12 = 0.0;
+ double directed21 = 0.0;
+ double symmetric = 0.0;
+ ensure_equals(GEOSHausdorffDistance(geom1_, geom2_, &discrete), 1);
+ ensure_equals(GEOSDirectedHausdorffDistance(geom1_, geom2_, &directed12), 1);
+ ensure_equals(GEOSDirectedHausdorffDistance(geom2_, geom1_, &directed21), 1);
+ ensure_equals(GEOSSymmetricHausdorffDistance(geom1_, geom2_, &symmetric), 1);
+ ensure_equals("GEOSHausdorffDistance", discrete, 22.36, 1e-2);
+ ensure_equals("Directed 1->2", directed12, 47.891845703125);
+ ensure_equals("Directed 2->1", directed21, 44.533046060947164);
+ ensure_equals("Symmetric", symmetric, 47.891845703125);
+template<>
+template<>
+ set_test_name("empty writes NaN, not 0");
+ geom1_ = fromWKT("LINESTRING EMPTY");
+ geom2_ = fromWKT("LINESTRING (0 0, 2 1)");
+ double dist = 0.0;
+ ensure_equals(GEOSDirectedHausdorffDistance(geom1_, geom2_, &dist), 1);
+ ensure(std::isnan(dist));
+template<>
+template<>
+ set_test_name("GEOSDirectedHausdorffDistanceWithPoints");
+ geom1_ = fromWKT("POINT (0 0)");
+ geom2_ = fromWKT("POINT (3 4)");
+ double p1x = 0, p1y = 0, p2x = 0, p2y = 0;
+ ensure_equals(GEOSDirectedHausdorffDistanceWithPoints(
+ geom1_, geom2_, &dist, &p1x, &p1y, &p2x, &p2y), 1);
+ ensure_distance(dist, 5.0, 1e-12);
+ ensure_equals(p1x, 0.0);
+ ensure_equals(p1y, 0.0);
+ ensure_equals(p2x, 3.0);
+ ensure_equals(p2y, 4.0);
+template<>
+template<>
+ set_test_name("GEOSDirectedHausdorffDistanceWithin");
+ geom1_ = fromWKT("LINESTRING (0 0, 2 0)");
+ ensure_equals(GEOSDirectedHausdorffDistanceWithin(geom1_, geom2_, 0.5), 0);
+ ensure_equals(GEOSDirectedHausdorffDistanceWithin(geom1_, geom2_, 1.0), 1);
+ ensure_equals(GEOSDirectedHausdorffDistanceWithin(geom1_, geom2_, 2.0), 1);
+} // namespace tut
\ No newline at end of file
diff --git a/util/geosop/GeometryOp.cpp b/util/geosop/GeometryOp.cpp
index 29e0dd59f..0c0bcfb34 100644
--- a/util/geosop/GeometryOp.cpp
+++ b/util/geosop/GeometryOp.cpp
@@ -32,6 +32,7 @@
#include <geos/algorithm/MinimumDiameter.h>
#include <geos/algorithm/MinimumBoundingCircle.h>
#include <geos/geom/util/Densifier.h>
@@ -643,6 +644,22 @@ std::vector<GeometryOpCreator> opRegistry {
return new Result( geos::algorithm::distance::DiscreteHausdorffDistance::distance(geom, geomB ) );
+{"directedHausdorffDistance", [](std::string name) { return GeometryOp::create(name,
+ catDist,
+ "compute directed (locus) Hausdorff distance from geometry A to B",
+ Result::typeDouble,
+ [](const Geometry& geom, const Geometry& geomB) {
+ return new Result( geos::algorithm::distance::DirectedHausdorffDistance::distance(geom, geomB ) );
+{"symmetricHausdorffDistance", [](std::string name) { return GeometryOp::create(name,
+ catDist,
+ "compute symmetric (locus) Hausdorff distance between geometry A and B",
+ return new Result( geos::algorithm::distance::DirectedHausdorffDistance::hausdorffDistance(geom, geomB ) );
// MD - can't get this to work for now
add("frechetDistanceLine", 2, 0, Result::typeGeometry, catDist,
Summary of changes:
NEWS.md | 4 +
Version.txt | 4 +-
capi/geos_c.cpp | 24 +
capi/geos_c.h.in | 116 ++++
capi/geos_ts_c.cpp | 63 ++
.../algorithm/distance/DirectedHausdorffDistance.h | 300 ++++++++++
.../distance/CoordinateSequenceLocation.h | 76 +++
include/geos/operation/distance/FacetSequence.h | 21 +-
.../geos/operation/distance/IndexedFacetDistance.h | 18 +-
.../distance/DirectedHausdorffDistance.cpp | 659 +++++++++++++++++++++
.../distance/CoordinateSequenceLocation.cpp | 107 ++++
src/operation/distance/FacetSequence.cpp | 57 +-
src/operation/distance/IndexedFacetDistance.cpp | 47 +-
.../distance/DirectedHausdorffDistanceTest.cpp | 630 ++++++++++++++++++++
.../capi/GEOSDirectedHausdorffDistanceTest.cpp | 96 +++
util/geosop/GeometryOp.cpp | 17 +
16 files changed, 2231 insertions(+), 8 deletions(-)
create mode 100644 include/geos/algorithm/distance/DirectedHausdorffDistance.h
create mode 100644 include/geos/operation/distance/CoordinateSequenceLocation.h
create mode 100644 src/algorithm/distance/DirectedHausdorffDistance.cpp
create mode 100644 src/operation/distance/CoordinateSequenceLocation.cpp
create mode 100644 tests/unit/algorithm/distance/DirectedHausdorffDistanceTest.cpp
create mode 100644 tests/unit/capi/GEOSDirectedHausdorffDistanceTest.cpp
hooks/post-receive
More information about the geos-commits
