[geos-commits] [SCM] GEOS branch 3.12 updated. 65573fff75ca4ab8b6aaacf558259a2df128bc48
Mon Oct 19 16:47:05 PDT 2026
the project "GEOS".
The branch, 3.12 has been updated
       via  65573fff75ca4ab8b6aaacf558259a2df128bc48 (commit)
      from  69e0d518a60521a4bbc6b72f98718ea18d2b0fd7 (commit)
revisions in full, below.
commit 65573fff75ca4ab8b6aaacf558259a2df128bc48
Author: Mike Taves <mwtoews at gmail.com>
Date:   Tue Oct 20 12:41:44 2026 +1300
    Skip testing FE_INVALID from unit-geom-Envelope for some Clang builds (GH-1555, Mike Taves)
diff --git a/NEWS.md b/NEWS.md
index 0934edb9d..a3ee0a152 100644
--- a/NEWS.md
+++ b/NEWS.md
@@ -6,6 +6,7 @@
   - Fix DepthSegment comparison logic (really this time) (GH-1266, Martin Davis)
   - Change CoverageGapFinder to return polygons (Martin Davis)
   - Avoid crash on buffer of geometry with only invalid coordinates (GH-1335, Dan Baston)
+  - Skip testing FE_INVALID from unit-geom-Envelope for some Clang builds (GH-1555, Mike Taves)
 ## Changes in 3.12.3
 2025-03-03
diff --git a/tests/unit/geom/EnvelopeTest.cpp b/tests/unit/geom/EnvelopeTest.cpp
index b1250a63e..1c9282532 100644
--- a/tests/unit/geom/EnvelopeTest.cpp
+++ b/tests/unit/geom/EnvelopeTest.cpp
@@ -250,7 +250,10 @@ void object::test<6>
     check_intersects(small, {-1, -1}, true);
     check_intersects(small, {5, 5}, false);
+#if !( defined(__OPTIMIZE__) && defined(__x86_64__) && defined(__clang__) && (__clang_major__ >= 15) )
+//  Exclude optimized Clang 15 or later on x86_64 - raises FE_INVALID
     check_intersects(empty, {0, 0}, false);
+#endif
     ensure_no_fp_except();
Summary of changes:
 NEWS.md                          | 1 +
 tests/unit/geom/EnvelopeTest.cpp | 3 +++
 2 files changed, 4 insertions(+)
hooks/post-receive
More information about the geos-commits mailing list
