[geos-commits] [SCM] GEOS branch dependabot/github_actions/all-actions-65867ac573 created. adc567d81e4b311061c7f3a5bbd3603f7919255b
git at osgeo.org
git at osgeo.org
Tue Sep 1 08:49:57 PDT 2026
the project "GEOS".
The branch, dependabot/github_actions/all-actions-65867ac573 has been created
at adc567d81e4b311061c7f3a5bbd3603f7919255b (commit)
commit adc567d81e4b311061c7f3a5bbd3603f7919255b
Author: dependabot[bot] <49699333+dependabot[bot]@users.noreply.github.com>
Date: Tue Sep 1 15:49:39 2026 +0000
Bump the all-actions group with 3 updates
Bumps the all-actions group with 3 updates: [vmactions/freebsd-vm](https://github.com/vmactions/freebsd-vm), [github/codeql-action](https://github.com/github/codeql-action) and [docker/login-action](https://github.com/docker/login-action).
Updates `vmactions/freebsd-vm` from 1.5.2 to 1.5.5
- [Release notes](https://github.com/vmactions/freebsd-vm/releases)
- [Commits](https://github.com/vmactions/freebsd-vm/compare/v1.5.2...v1.5.5)
Updates `github/codeql-action` from 4.37.3 to 4.37.8
- [Release notes](https://github.com/github/codeql-action/releases)
- [Changelog](https://github.com/github/codeql-action/blob/main/CHANGELOG.md)
- [Commits](https://github.com/github/codeql-action/compare/v4.37.3...v4.37.8)
Updates `docker/login-action` from 4.5.1 to 4.6.0
- [Release notes](https://github.com/docker/login-action/releases)
- [Commits](https://github.com/docker/login-action/compare/v4.5.1...v4.6.0)
updated-dependencies:
- dependency-name: vmactions/freebsd-vm
dependency-version: 1.5.5
dependency-type: direct:production
update-type: version-update:semver-patch
dependency-group: all-actions
- dependency-name: github/codeql-action
dependency-version: 4.37.8
- dependency-name: docker/login-action
dependency-version: 4.6.0
update-type: version-update:semver-minor
Signed-off-by: dependabot[bot] <support at github.com>
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 4858ec65e..c7c1f174e 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -527,7 +527,7 @@ jobs:
restore-keys: freebsd
- name: Build and test
- uses: vmactions/freebsd-vm at v1.5.2
+ uses: vmactions/freebsd-vm at v1.5.5
with:
release: "15.0"
envs: CCACHE_COMPRESS CCACHE_COMPRESSLEVEL CCACHE_MAXSIZE
diff --git a/.github/workflows/codeql.yml b/.github/workflows/codeql.yml
index a42d66e77..6905e122d 100644
--- a/.github/workflows/codeql.yml
+++ b/.github/workflows/codeql.yml
@@ -40,7 +40,7 @@ jobs:
# Initializes the CodeQL tools for scanning.
- name: Initialize CodeQL
- uses: github/codeql-action/init at v4.37.3
+ uses: github/codeql-action/init at v4.37.8
with:
languages: ${{ matrix.language }}
# If you wish to specify custom queries, you can do so here or in a config file.
@@ -63,6 +63,6 @@ jobs:
make -j$(nproc)
- name: Perform CodeQL Analysis
- uses: github/codeql-action/analyze at v4.37.3
+ uses: github/codeql-action/analyze at v4.37.8
with:
category: "/language:${{matrix.language}}"
diff --git a/.github/workflows/container.yml b/.github/workflows/container.yml
index 649c23048..c1726e7d3 100644
--- a/.github/workflows/container.yml
+++ b/.github/workflows/container.yml
type=sha,prefix=
- name: Login to GitHub Container Registry
- uses: docker/login-action at v4.5.1
+ uses: docker/login-action at v4.6.0
with:
registry: ghcr.io
username: ${{ github.repository_owner }}
hooks/post-receive
More information about the geos-commits
