[geos-devel] Portability
Paul Ramsey pramsey at refractions.net
Sat Aug 31 12:40:56 EDT 2002
"Yury A. Bychkov" wrote:
> I am not sure yet. If there are not a lot of such problems (and based on Paul's
> message (and on my impression that I probably already used all needed STL
> functions at least once) we can hope that it is so), it would probably be better
> to avoid external libraries. Otherwise we can always switch to STLPort
I should note that I did not work through everything until I got
complete compilation. I just worked through a portion of geom. If I go
through and commit changes which will allow compilation under GNU, would
that be OK?
