[geos-devel] UVic colloquium dates
Jens H. Jahnke jens at cs.uvic.ca
Wed Jul 17 15:28:12 EDT 2002
Paul,
The CAG seminar slot are listed at
http://csr.uvic.ca/~wendym/cag/f02talks.html
The SEG colloquium is typically on Fridays. The slots for September are
still all open. (http://www.cs.UVic.CA/~sweng/)
Please select dates and I will arrange it with the department.
Jens
On 7/16/02 4:22 PM, "Paul Ramsey" <pramsey at refractions.net> wrote:
> Gentlemen,
>> From Tuesdays meeting:
> - We reviewed Yury's progress. He has finished the object model and test
> harness, and is into the Graph classes. Graph and some other algorithms
> will need to be finished before binary predicates can be tackled.
> - Looking ahead, Yury predicted that the Graph should be done in the
> next two weeks, and that binary predicates should be done by August 20.
> - Refractions will start to play with integrating GEOS into the PostGIS
> framework, and try some tests of instantiation and writing back GEOS
> objects.
> - Refractions will be doing some UNIX compilation tests on GEOS over the
> next month, and will start to publish the GEOS docs online with doxygen.
> - Paul will review the SEG schedule and pick a date in September to do a
> presentation.
> - Jens or Daniel will send information about the computational
> algorithms seminar, and Martin will pick a date to give a presentation
> on the problems of robustness in computational geometry. Hopefully this
> will yield some interest in exploring our practical robustness issues
> around intersections and buffers.
> - Dave and Martin and Yury/Daniel/Jens will check out GeoTex 2003
> (http://www.geoplace.com/gt/) and think about abstracts for papers.
> Martin/Yury will consider a JTS/GEOS presentation. Martin will consider
> a JCS presentation. Dave will think about a PostGIS presentation.
> Paul
Dr. Jens Jahnke
University of Victoria
www.cs.uvic.ca/~jens
