[geos-devel] CVS OK?
mbdavis at vividsolutions.com
Tue Jun 11 16:57:29 EDT 2002
It doesn't hurt for you to check in code fairly frequently, even if it's
broken, Yury. No-one else is compiling the code right now anyway. In the
spirit of XP and Open Source, it helps to have more eyes on your code in
order to validate design and style decisions.
Martin Davis, Senior Technical Specialist
Vivid Solutions Inc.
Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
Phone: (250) 385 6040 Fax: (250) 385 6046
EMail: mbdavis at vividsolutions.com Web: www.vividsolutions.com
> -----Original Message-----
> From: Yury A. Bychkov [mailto:ybychkov at direct.ca]
> Sent: Monday, June 10, 2002 11:18 PM
> To: geos-devel at geos.refractions.net
> Subject: Re: [geos-devel] CVS OK?
> Hi Paul.
> CVS is working fine. The problem is that my porting doesn't
> go as fast as I
> expected. I hit several problems over the weekend and it took
> me a while to
> solve them and to verify that my solutions work as they supposed to.
> Yury
> ----- Original Message -----
> From: "Paul Ramsey" <pramsey at refractions.net>
> To: <geos-devel at geos.refractions.net>
> Sent: Monday, June 10, 2002 8:32 PM
> Subject: [geos-devel] CVS OK?
> > Yury,
> > Is the CVS archive working OK for you? There have been no
> checkins since
> > it was set up.
> > Thanks,
> > Paul
> > geos-devel mailing list
> > http://geos.refractions.net/mailman/listinfo/geos-devel
