[geos-devel] GEOS Report (November 1, 2002)
Yury A. Bychkov ybychkov at direct.ca
Mon Nov 4 17:18:59 EST 2002
Hi Everyone,
Current status:
1. WKTReader related classes were changed to make the XMLTester less fragile.
2. Tests of the code on a VERY BIG starfish-shaped geometry (10, 100, 1000 and
10000 nodes) had somewhat unusual results. 10, 100 and 1000 node test gave the
time very close to Java version, however 10000 node test took an extremely long
time to finish.
Things to do:
Try to solve the above problem.
Yury
