[geos-devel] Performance of GEOS compared to JTS (Report, Nov. 8)
Yury A. Bychkov
ybychkov at direct.ca
Fri Nov 8 14:51:07 EST 2002
Success !!!
I found a good profiler for Windows (VTune from Intel) and tracked down some of
the problems that caused bad performance. They were mostly linked with copying
and destroying vectors of Coordinates. I've fixed the worst of them and now
GEOS's performance is drastically improved (though it is still slower then JTS).
New version has been committed to the CVS.
Results:
# overlapping MCs: 36
# segment intersection tests: 39
n Pts: 10 Executed in 10 ms.
# overlapping MCs: 40
# segment intersection tests: 26
n Pts: 100 Executed in 10 ms.
# overlapping MCs: 44
# segment intersection tests: 7
n Pts: 1000 Executed in 90 ms.
# segment intersection tests: 4
n Pts: 2000 Executed in 100 ms.
n Pts: 3000 Executed in 220 ms.
n Pts: 4000 Executed in 271 ms.
# segment intersection tests: 5
n Pts: 5000 Executed in 330 ms.
n Pts: 6000 Executed in 381 ms.
# segment intersection tests: 6
n Pts: 7000 Executed in 470 ms.
n Pts: 8000 Executed in 460 ms.
n Pts: 9000 Executed in 581 ms.
n Pts: 10000 Executed in 681 ms.
Yury
