[geos-devel] Performance of GEOS compared to JTS (Report, Nov. 8)
Paul Ramsey pramsey at refractions.net
Fri Nov 8 16:07:58 EST 2002
Here are the Linux tests again... Yury, you have to explicitly include stdio.h
in the tester in order to get printf under GNU...
# overlapping MCs: 44
# segment intersection tests: 7
n Pts: 1000  Executed in     10 ms.
# segment intersection tests: 4
n Pts: 2000  Executed in     30 ms.
n Pts: 4000  Executed in     70 ms.
n Pts: 8000  Executed in    160 ms.
n Pts: 16000  Executed in    330 ms.
n Pts: 32000  Executed in    660 ms.
n Pts: 64000  Executed in   1300 ms.
n Pts: 128000  Executed in   2600 ms.
Quoting Martin Davis <mbdavis at VividSolutions.com>:
> Excellent work, Yury.
> But we're not done yet....  I can't see any reason why GEOS should be
> *slower* than JTS!  (I assume this comparison is made on the same hardware
> configuration...)  Perhaps we need to do some more memory management tuning
> ...  Better put your nifty vtune profiler to work before it timebombs.
> Martin Davis, Senior Technical Specialist
> Vivid Solutions Inc.
> Suite #1A-2328 Government Street   Victoria, B.C.   V8T 5G5
> Phone: (250) 385 6040    Fax: (250) 385 6046
> EMail: mbdavis at vividsolutions.com  Web: www.vividsolutions.com
> > -----Original Message-----
> > From: Yury A. Bychkov [mailto:ybychkov at direct.ca]
> > Sent: Friday, November 08, 2002 11:51 AM
> > To: geos-devel at geos.refractions.net
> > Subject: [geos-devel] Performance of GEOS compared to JTS
> > (Report, Nov.
> > 8)
> > Success !!!
> > I found a good profiler for Windows (VTune from Intel) and
> > tracked down some of
> > the problems that caused bad performance. They were mostly
> > linked with copying
> > and destroying vectors of Coordinates. I've fixed the worst
> > of them and now
> > GEOS's performance is drastically improved (though it is
> > still slower then JTS).
> > New version has been committed to the CVS.
> > Results:
> > # overlapping MCs: 36
> > # segment intersection tests: 39
> > n Pts: 10  Executed in     10 ms.
> > # overlapping MCs: 40
> > # segment intersection tests: 26
> > n Pts: 100  Executed in     10 ms.
> > n Pts: 1000  Executed in     90 ms.
> > n Pts: 2000  Executed in    100 ms.
> > n Pts: 3000  Executed in    220 ms.
> > n Pts: 4000  Executed in    271 ms.
> > # segment intersection tests: 5
> > n Pts: 5000  Executed in    330 ms.
> > n Pts: 6000  Executed in    381 ms.
> > # segment intersection tests: 6
> > n Pts: 7000  Executed in    470 ms.
> > n Pts: 8000  Executed in    460 ms.
> > n Pts: 9000  Executed in    581 ms.
> > n Pts: 10000  Executed in    681 ms.
> > Yury
> > geos-devel mailing list
> > http://geos.refractions.net/mailman/listinfo/geos-devel
This mail sent through IMP: http://horde.org/imp/
