[geos-devel] Performance of GEOS compared to JTS (Report, Nov. 8)
Norman Vine
nhv at cape.com
Tue Nov 19 00:06:36 EST 2002
Martin Davis writes:
> For comparison purposes, here's the timings for JTS on the same numbers. JTS now looks linear, just like GEOS. (I think we just
didn't go quite large enough last time). It's still (a bit) faster than GEOS, though - and I'm running on a 1.1 GHz machine, not a
1.9 GHz box. Maybe Java's just bettah... 8^)
> n Pts: 1000 Executed in 3014 ms
> n Pts: 2000 Executed in 91 ms
> n Pts: 4000 Executed in 50 ms
> n Pts: 8000 Executed in 110 ms
> n Pts: 16000 Executed in 210 ms
> n Pts: 32000 Executed in 411 ms
> n Pts: 64000 Executed in 801 ms
> n Pts: 128000 Executed in 2032 ms
> n Pts: 256000 Executed in 3545 ms
I did some major hacking on the code
machine: PIII 733 Cygwin gcc 3.2 -O3
n Pts: 1000 Executed in 10 ms.
n Pts: 2000 Executed in 30 ms.
n Pts: 4000 Executed in 60 ms.
n Pts: 8000 Executed in 140 ms.
n Pts: 16000 Executed in 330 ms.
n Pts: 32000 Executed in 680 ms.
n Pts: 64000 Executed in 1321 ms.
n Pts: 128000 Executed in 2834 ms.
n Pts: 256000 Executed in 5639 ms.
And here is the profiling result
Notice that the signOfDet2x2() is dominating like we would expect :-)
I'll clean up what I did 'a little' and post a tarball somewhere tomorrow
so others can play.
Norman
Flat profile:
Each sample counts as 0.01 seconds.
% cumulative self self total
time seconds seconds calls s/call s/call name
79.17 0.95 0.95 4543842 0.00 0.00 RobustDeterminant::signOfDet2x2(double, double, double, double)
5.83 1.02 0.07 2 0.04 0.04 Geometry::hasNullElements(CoordinateList)
5.00 1.08 0.06 2 0.03 0.03 LineString::computeEnvelopeInternal()
4.17 1.13 0.05 1327961 0.00 0.00 SegmentIntersector::addIntersections(Edge*, int, Edge*, int)
3.33 1.17 0.04 511968 0.00 0.00 SegmentIntersector::isTrivialIntersection(Edge*, int, Edge*, int)
2.50 1.20 0.03 1 0.03 0.03 GeometryTestFactory::createSineStar(double, double, double, double, int, int)
0.00 1.20 0.00 1327965 0.00 0.00 LineIntersector::hasIntersection()
0.00 1.20 0.00 1071957 0.00 0.00 LineIntersector::computeIntersection(CoordinateList*, int, CoordinateList*,
int)
0.00 1.20 0.00 1071957 0.00 0.00 RobustLineIntersector::computeIntersect(Coordinate, Coordinate, Coordinate,
Coordinate)
0.00 1.20 0.00 511981 0.00 0.00 LineIntersector::getIntersectionNum()
0.00 1.20 0.00 256100 0.00 0.00 Quadrant::quadrant(double, double)
0.00 1.20 0.00 256088 0.00 0.00 Quadrant::quadrant(Coordinate, Coordinate)
0.00 1.20 0.00 256006 0.00 0.00 Coordinate::getNull()
0.00 1.20 0.00 256000 0.00 0.00 RobustLineIntersector::computeIntersection(Coordinate, Coordinate, Coordinate)
0.00 1.20 0.00 1242 0.00 0.00 sleLessThan(SweepLineEvent*, SweepLineEvent*)
0.00 1.20 0.00 1242 0.00 0.00 SweepLineEvent::compareTo(SweepLineEvent*)
