[geos-devel] count of signOfDet2x2 calls in JTS
Norman Vine nhv at cape.com
Wed Nov 20 16:36:34 EST 2002
Martin Davis writes:
> Here's the results.  (Note these are for the SineStar^2 test, comparing two offset sine stars of the same size).
> Good news: there's lots of calls to signOfDet2x2 , so GEOS looks like it's mirroring JTS
> Bad news: why so many calls?
> I'll try and figure out the reason for the bad news...   8^(
Hmm...  the patch I posted should help a bit
Note there are two separate early out tricks
the first is the obvious 'trivial reject'
the other is doing the orientationIndex() on 'Qp'
only after testing for an early reject on 'Pq'
this should save ~30% of the tests or better
Hopefully there are bigger gains to be had elsewhere too :-)
Norman
