[geos-devel] Why many calls to signOfDet2x2 and addIntersections
Norman Vine
nhv at cape.com
Wed Nov 20 19:59:26 EST 2002
Martin Davis writes:
> Just for grins, I disabled the self-intersection check and reran the SineStarX2 test.
> Times are below - they are up to 10 times faster!
Ah this is more like what I was expecting
> Currently JTS just checks *everything* for self-intersections.
> Since many cases involve only polygons without holes, being a bit smarter about
> what gets checked could produce a substantial performance improvement.
FWIW IMHO trivial rejection tests and caching computations for reuse
are almost *allways* worth the time it takes
cheers
norman
bool RobustCGAlgorithms::isPointInRing(Coordinate p,CoordinateList ring)
int crossings=0; // number of segment/ray crossings
int nPts=ring.getSize();
* For each segment l = (i-1, i),
* see if it crosses ray from test point in positive x direction.
double x1=ring.getAt(0).x-p.x;
double y1=ring.getAt(0).y-p.y;
for (int i=1;i<nPts;i++) {
double x2 = x1;
double y2 = y1;
x1=ring.getAt(i).x-p.x;
y1=ring.getAt(i).y-p.y;
if (((y1>0) && (y2<=0)) || ((y2>0) && (y1<=0))) {
* segment straddles x axis, so compute intersection.
* crosses ray if strictly positive intersection.
if ( RobustDeterminant::signOfDet2x2(x1,y1,x2,y2)/(y2-y1) > 0.0 ) {
crossings++;
* p is inside if number of crossings is odd.
if ((crossings%2)==1) {
return true;
} else {
return false;
