[geos-devel] Current project status
Yury A. Bychkov
ybychkov at direct.ca
Sun Nov 24 05:58:52 EST 2002
1. RobustLineIntersector has been updated.
2. MonotoneChainIndexer::getChainStartIndices was a biggest single contributor
to Coordinate() calls (~20% of total calls). I've replaced instances
CoordinateList with references to gauge performance increase (See results
below).
3. Currently I am redoing the CoordinateList (and calls to its methods) with
respect to the suggestions on the list.
Here are the performance results (P4-2.53):
No modifications:
# overlapping MCs: 406
# segment intersection tests: 226
n Pts: 1000 Executed in 30 ms.
# segment intersection tests: 278
n Pts: 2000 Executed in 50 ms.
# segment intersection tests: 248
n Pts: 4000 Executed in 100 ms.
# segment intersection tests: 250
n Pts: 8000 Executed in 150 ms.
# segment intersection tests: 272
n Pts: 16000 Executed in 391 ms.
# segment intersection tests: 264
n Pts: 32000 Executed in 751 ms.
# segment intersection tests: 236
n Pts: 64000 Executed in 1513 ms.
n Pts: 128000 Executed in 3395 ms.
# segment intersection tests: 238
n Pts: 256000 Executed in 7120 ms.
# segment intersection tests: 232
n Pts: 512000 Executed in 12788 ms.
n Pts: 1024000 Executed in 25296 ms.
New RobustLineIntersector:
n Pts: 1000 Executed in 20 ms.
n Pts: 2000 Executed in 40 ms.
n Pts: 4000 Executed in 90 ms.
n Pts: 8000 Executed in 130 ms.
n Pts: 16000 Executed in 311 ms.
n Pts: 32000 Executed in 621 ms.
n Pts: 64000 Executed in 1252 ms.
n Pts: 128000 Executed in 2754 ms.
n Pts: 256000 Executed in 5688 ms.
n Pts: 512000 Executed in 10895 ms.
n Pts: 1024000 Executed in 22042 ms.
CoordinateList instances replaced with references in MonotoneChainIndexer; some
tweaking of CoordinateList:
n Pts: 2000 Executed in 30 ms.
n Pts: 4000 Executed in 70 ms.
n Pts: 8000 Executed in 120 ms.
n Pts: 16000 Executed in 270 ms.
n Pts: 32000 Executed in 500 ms.
n Pts: 64000 Executed in 991 ms.
n Pts: 128000 Executed in 2023 ms.
n Pts: 256000 Executed in 4276 ms.
n Pts: 512000 Executed in 7861 ms.
n Pts: 1024000 Executed in 15993 ms.
Yury
