[geos-devel] Current project status
Norman Vine
nhv at cape.com
Sun Nov 24 23:53:51 EST 2002
FYI
To days CVS code with following classes inlined
Coordinate, CoordinateList, Envelope,
RobustCGAlgorithms, RobustLineIntersector
compiled with
-O3 -fomit-frame-pointer
and tweak below
(PIII 733)
Pts: 1000 Executed in 20 ms.
Pts: 2000 Executed in 40 ms.
Pts: 4000 Executed in 70 ms.
Pts: 8000 Executed in 160 ms.
Pts: 16000 Executed in 351 ms.
Pts: 32000 Executed in 661 ms.
Pts: 64000 Executed in 1302 ms.
Pts: 128000 Executed in 2593 ms.
Pts: 256000 Executed in 5267 ms.
Note Yury reported
n Pts: 256000 Executed in 7120 ms.
on a (P4-2.53):
Norman
// below I am assuming this means
// "is on line segment" between getAt(i) and getAt(i-1)
bool RobustCGAlgorithms::isOnLine(Coordinate p,CoordinateList pt) {
for(int i=1;i<pt.getSize();i++) {
if( pt.inRange(p,i-1,i) ) {
lineIntersector->computeIntersection(p,pt.getAt(i-1),pt.getAt(i));
if (lineIntersector->hasIntersection()) {
return true;
return false;
class CoordinateList
public
bool inXrange( double x, int idx1, int idx2) {
if( x >= (*vect)[idx1].x )
return x <= (*vect)[idx2].x;
else if( x <= (*vect)[idx1].x )
return x >= (*vect)[idx2].x;
return false;
bool inYrange( double y, int idx1, int idx2) {
if( y >= (*vect)[idx1].y )
return y <= (*vect)[idx2].y;
else if( y <= (*vect)[idx1].y )
return y >= (*vect)[idx2].y;
return false;
bool inRange( Coordinate &pt, int idx1, int idx2) {
return( inXrange(pt.x,idx1,idx2) && inYrange(pt.y,idx1,idx2) );
