[geos-devel] Current project status
Norman Vine
nhv at cape.com
Mon Nov 25 00:31:44 EST 2002
Yury A. Bychkov writes:
> Slight error. You didn't look far enough in my results. 7120 ms was for the
> original version. The version that is in CVS now (before your inlining) has "n
> Pts: 256000 Executed in 4276 ms".
Ooops ...
I didn't think I could had speeded it up that much
But the point is still valid
as I would expect that to be ~2000 ms with inlined the code
since your machine is much faster then mine
Cheers
Norman
