[geos-devel] Status Report (October 15)
Paul Ramsey pramsey at refractions.net
Wed Oct 16 13:59:11 EDT 2002
Thanks Yury,
Would you commit your working-but-slow changes so that the portability
crew can get things compiling under GNU? It looks like things are in a
state where some integration work would not be impossible and the API to
Relate should be stable here on in...
P.
Yury A. Bychkov wrote:
> Hi Everyone.
> Last three weeks I was debugging relate() operation. There were numerous
> problems mostly caused by subtle differences between C++ and Java.
> Current state of GEOS:
> Relate() operation works and my tester successfully executes all 500 tests from
> JTS/test/validate. However 2 of those tests take too long to execute.
> Next to do:
> Profile the code in order to fix these 2 tests. Fix some memory leaks.
> Yury
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
