[geos-devel] [] vs at()
Paul Ramsey
pramsey at refractions.net
Wed Oct 23 12:05:26 EDT 2002
Yury, do you concur? If so, globally commit that change ASAP.
Thanks, Paul
Martin Davis wrote:
>>Everyone, could we have some kind of decision on whether at() is a
>>requirement? Norman noted that there is a bounds-check in
>>at() which is
>>not there in []. Is this check required by the code, or not?
> My take on this is that using [] should be fine, in spite of the lack of bounds checking. Since we're working from
> pretty well debugged Java code, we're pretty safe in assuming that the algorithms do not go zinging off the end of arrays.
> (If they did, the Java code would report bounds exceptions - but it never does).
> Martin Davis, Senior Technical Specialist
> Vivid Solutions Inc.
> Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
> Phone: (250) 385 6040 Fax: (250) 385 6046
> EMail: mbdavis at vividsolutions.com Web: www.vividsolutions.com
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
