[geos-devel] Portability Modifications
Norman Vine nhv at cape.com
Thu Oct 24 12:09:56 EDT 2002
Paul Ramsey writes:
> Hm, this patch does not change things for me at all... the initial
> compilation of CTS.o works fine, and there are good include paths on the
> command line... it is at the link stage where things bomb.
Paul
The problem is probably in part due to that libtool support with Cygwin
is well 'sketchy' and I have only tested this with
./configure --disable-shared
I do not have a Linux system and have no way of testing the
dynamic library linking there
Norman
