[geos-devel] Performance of GEOS
Martin Davis
mbdavis at VividSolutions.com
Wed Oct 30 15:39:14 EST 2002
Something we may need to brainstorm a bit on is how much attention we should pay to the performance of the code in GEOS. Currently it seems to perform at about the level of JTS, or a bit slower. This may well be "good enough" for use in PostGIS - that's something you PostGIS wonks will have to decide. But there may be room for some real improvements in performance, if we start getting clever about how we interact with the C++ memory manager. (malloc is notoriously slow, so a bulk allocation scheme might bring some real improvements).
Yury and I are going to do a bit of investigation to make sure we're not overlooking any obvious speedups in the straightforward port.
We need to decide how to prioritize the development - are we looking for functionality first, or good performance from the relate code?
(The fact that "naively implemented" GEOS code is no faster than the Java code is quite interesting - so much for complaints that Java is "too slow" for production work!)
Martin Davis, Senior Technical Specialist
Vivid Solutions Inc.
Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
Phone: (250) 385 6040 Fax: (250) 385 6046
EMail: mbdavis at vividsolutions.com Web: www.vividsolutions.com
