Martin Davis writes: > > As for the other compatibility problems, is using STLPort the best solution for MSVC developers to ensure compatibility? Or would it better to cross compile with gcc Ver 3.2 ? Cross compiling with gcc Ver 3.2 would be GREAT ! You can use msys on a Windows machine. http://www.mingw.org Cheers Norman
