[geos-devel] WKTreader is broken
David Blasby
dblasby at refractions.net
Fri Apr 4 19:37:55 EST 2003
WKT reader doesnt like 3d points.
To cause a failure, modify test/WKTin so it has one line:
POINT(1 1 1)
and run ./SimpleWKTTester
You'll get an abort exception.
I've also noticed that the WKTWriter (and geom->asString()) cause
incorrect results like
POINT (%.0-2147483647f %.0-2147483647f)
This might be a problem with my code since it almost always happens.
It'll take me a bit
to track it down since there's a lots of points of failure between
postgis, the postgis adapter,
and the GEOS wrapper.
dave
