[geos-devel] Status (New Example)
Norman Vine
nhv at cape.com
Sun Apr 6 21:02:30 EDT 2003
Dave Blasby writes:
> Quoting Norman Vine <nhv at cape.com>:
> > Let me try that again I cleaned up to much of
> > my debugging 'cruft' from my earlier files
> I've tried running your files, but I get the same results as
> before. (I put
> the words "norman" in so I was sure it was using the correct .o files).
> I had a though on friday that the c++ wrapper ("test_cpp.cpp")
> might need more
> compile options than "-c"; say something like "-fpic".
Curious ?
Here is what I get with Cygwin and gcc 3.2
==== cut makeit.sh ====
#!/usr/bin/bash
HEADERS="../../source/headers"
LIBS="../source/geom/.libs/"
g++ -I${HEADERS} -c test_cpp.cpp
gcc -I./ -o test test.c test_cpp.o -L${LIBS} -lgeos -lstdc++
./test
===== cut ====
<530>
$ ./makeit
geom text (to be parsed):POLYGON((100 200,100 140,180 140,180 200,100 200))
geom (WKTWriter):POLYGON ((100.0000000000000000 200.0000000000000000,
100.0000000000000000 140.0000000000000000, 180.000
0000000000000 140.0000000000000000, 180.0000000000000000
200.0000000000000000, 100.0000000000000000 200.0000000000000000
result in C is POLYGON ((100.0000000000000000 200.0000000000000000,
100.0000000000000000 140.0000000000000000, 180.00000
00000000000 140.0000000000000000, 180.0000000000000000 200.0000000000000000,
100.0000000000000000 200.0000000000000000))
