[geos-devel] Status (New Example)
dblasby at refractions.net dblasby at refractions.net
Sun Apr 6 23:37:45 EDT 2003
Norman Vine <nhv at cape.com> said:
> > > Curious ?
> > Hum - there must be some difference between how linux and cygwin
> > handle the
> > communication between C and C++.  Perhaps there are some changes in the
> > default options for gcc under cygwin??
> > What version of gcc are you using?
> 3.2 but that shouldn't make any difference as this technique is identical
> to that used by GDAL which AFAIK has had no problems reported
Perhaps someone could try your program on another linux system - then we can
narrow it down to something wrong on our system.
dave
