[geos-devel] automake/conf/aclocal
David Blasby
dblasby at refractions.net
Mon Apr 7 16:00:21 EDT 2003
I tried again on a different linux machine here, unfortunately with the
same wrong results.
[dblasby at lion work_dave]$ rm *.o test
[dblasby at lion work_dave]$ ./make_it
geom text (to be parsed norman):POLYGON((100 200,100 140,180 140,180
200,100 200))
geom (WKTWriter):POLYGON ((100.0000000000000000 200.0000000000000000,
100.0000000000000000 140.00000000
00000000, 180.0000000000000000 140.0000000000000000,
180.0000000000000000 200.0000000000000000, 100.000
0000000000000 200.0000000000000000))
result in C (norman) is
100.0000000000000000 140.0000000000000000, inf inf
, inf inf, inf inf))
[dblasby at lion work_dave]$ cat make_it
#!/bin/bash
HEADERS="/usr/local/include/geos"
LIBS="/usr/local/lib/"
g++ -I${HEADERS} -c test_cpp.cpp
gcc -I./ -o test test.c test_cpp.o -L${LIBS} -lgeos -lstdc++
./test
[dblasby at lion work_dave]$ cat test_cpp.cpp
// g++ -g test.cpp -c -I/usr/local/include/geos
#include <string>
#include <iostream>
#include <fstream>
#include "io.h"
#include "geos_api.h"
char *GEOSasText(GeometryWrapper g)
Geometry *g1 = (Geometry *)g;
WKTWriter *w=new WKTWriter();
string s = w->write(g1);
char *result = (char *)s.c_str();
return result ;
GeometryWrapper createGEOSFromText(char *wkt)
cout <<"geom text (to be parsed norman):"<< wkt << endl;
Geometry *g = new Geometry;
WKTReader *r = new WKTReader(new GeometryFactory(new
PrecisionModel(),-1));
g = r->read(wkt);
cout << endl << "geom (WKTWriter):"<< w->write(g) << endl;
delete r;
delete w;
return (GeometryWrapper)g;
[dblasby at lion work_dave]$ cat test.c
//c++ -c test_cpp.cpp
//gcc -g -o test test.c test_cpp.o -lm -lgeos -lstdc++
#include "stdio.h"
extern GeometryWrapper createGEOSFromText(char *wkt);
extern char * GEOSasText(GeometryWrapper g1);
int main(int argC, char* argV[])
GeometryWrapper g =
createGEOSFromText("POLYGON((100 200,100 140,180 140,180 200,100 200))");
printf("\nresult in C (norman) is
%s\n",GEOSasText(g));
[dblasby at lion work_dave]$ cat geos_api.h
#ifdef __cplusplus
# define GEOS_C_START extern "C" {
# define GEOS_C_END }
#else
# define GEOS_C_END
#endif
GEOS_C_START;
typedef void *GeometryWrapper;
GEOS_C_END;
[dblasby at lion work_dave]$ ldd test
libgeos.so.1 => /usr/local/lib/libgeos.so.1 (0x40027000)
libstdc++-libc6.2-2.so.3 => /usr/lib/libstdc++-libc6.2-2.so.3
(0x400d8000)
libc.so.6 => /lib/libc.so.6 (0x4011b000)
libm.so.6 => /lib/libm.so.6 (0x40242000)
/lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x40000000)
[dblasby at lion work_dave]$ gcc --version
2.96
[dblasby at lion work_dave]$ g++ --version
2.96
[dblasby at lion work_dave]$ ld --version
GNU ld version 2.11.93.0.2 20020207
Copyright 2002 Free Software Foundation, Inc.
This program is free software; you may redistribute it under the terms of
the GNU General Public License. This program has absolutely no warranty.
[dblasby at lion work_dave]$ libtool --version
ltmain.sh (GNU libtool) 1.4.3 (1.922.2.110 2002/10/23 01:39:54)
[dblasby at lion work_dave]$ ldd /usr/local/lib/libgeos.so
libc.so.6 => /lib/libc.so.6 (0x400c4000)
/lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x80000000)
