[geos-devel] test for interior(A) intersects interior(B)
Martin Davis mbdavis at VividSolutions.com
Tue Apr 8 17:27:47 EDT 2003
A.relate(B, "T********")
Good thing we have the relate operation!  I had to use this in JCS, and I suspect it will be used a fair bit by others too.
Martin Davis, Senior Technical Architect
Vivid Solutions Inc.
Suite #1A-2328 Government Street   Victoria, B.C.   V8T 5G5
Phone: (250) 385 6040    Fax: (250) 385 6046
EMail: mbdavis at vividsolutions.com  Web: www.vividsolutions.com
> -----Original Message-----
> From: Paul Ramsey [mailto:pramsey at refractions.net]
> Sent: Tuesday, April 08, 2003 2:02 PM
> To: GEOS Development List
> Subject: Re: [geos-devel] BUG: relate(g1,g2) crashes with
> GEOMETRYCOLLECTION?
> Nice. Overlaps is not what I thought it was. What is the test for
> interior(A) intersects interior(B)?
> P.
> On Tuesday, April 8, 2003, at 01:57 PM, Martin Davis wrote:
> > Nope - if you look at the spec it clearly spells out that A and B
> > overlap *only* if A intersects exterior(B) or vice-versa.  They
> > clearly intended the answer to be FALSE if the geometries were the
> > same.
> >> From: Martin Davis
> >> Sent: Tuesday, April 08, 2003 1:52 PM
> >> Subject: RE: [geos-devel] BUG: relate(g1,g2) crashes with
> >> GEOMETRYCOLLECTION?
> >> Yep, overlaps(G,G) = false according to the OGC spec.  This
> >> may be a bit counter-intuitive.  Not sure what the rationale
> >> behind this decision was.
> >> I usually use A.relate(B, "T********") to determine if things
> >> overlap "properly".
> >>> From: David Blasby [mailto:dblasby at refractions.net]
> >>> Sent: Tuesday, April 08, 2003 1:43 PM
> >>> GEOMETRYCOLLECTION?
> >>> Martin Davis wrote:
> >>>> Yep.  Neither GEOS nor JTS support GeometryCollections as
> >>> arguments to relate.  This is partly because the semantics
> >>> aren't very well defined, and partly because the obvious
> >>> semantics [ X.relate(GC) = X.relate(union(GC.components) ]
> >>> would make the operation non-robust.
> >>>> That said, we or you could always implement the above
> >>> semantics fairly easily...
> >>> Its unfortunate that the spec doesnt tell you what to do in
> >>> the case of
> >>> GEOMETRYCOLLECTIONs.
> >>> I've also noticed that overlaps(g,g) is FALSE!
> >>> dave
> >>> _______________________________________________
> >>> geos-devel mailing list
> >>> geos-devel at geos.refractions.net
> >>> http://geos.refractions.net/mailman/listinfo/geos-devel
>       Paul Ramsey
>       Refractions Research
>       Email: pramsey at refractions.net
>       Phone: (250) 885-0632
