[geos-devel] Design of exception-trapping wrapper
Martin Davis
mbdavis at VividSolutions.com
Fri Apr 11 20:35:56 EDT 2003
Sounds good to me then... press on!
Martin Davis, Senior Technical Architect
Vivid Solutions Inc.
Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
Phone: (250) 385 6040 Fax: (250) 385 6046
EMail: mbdavis at vividsolutions.com Web: www.vividsolutions.com
> -----Original Message-----
> From: David Blasby [mailto:dblasby at refractions.net]
> Sent: Friday, April 11, 2003 5:33 PM
> To: GEOS Development List
> Subject: Re: [geos-devel] Design of exception-trapping wrapper
> Martin Davis wrote:
> >Does anyone have time and ideas to prototype the design of
> this wrapper? I'm not sure I understand the problem quite
> well enough yet to propose a design. A small mockup might
> help to clarify the situation.
> Something like the function included below.
> NOTE: this is an *added* interface, not the ONLY interface. C++ and
> simple C programs could use the system exactly the way it is now.
> We'd have to come up with name so we dont have any redundant symbols.
> >>This seems like a pretty substantial change to GEOS.
> No - I think it would be pretty easy. We could add another class to
> GEOS. It wouldnt even have to be compiled unless you're
> using postgis...
> Unfortunately, there could be a lot of these little
> functions. But, if
> we stick to just wrapping the Geometry interface, we should
> be okay. I
> dont think postgis requires more than this.
> // call g1->contains(g2)
> // returns 0 = false
> // 1 = true
> // 2 = error was trapped
> char GEOSrelateContains(Geometry *g1, Geometry*g2)
> try {
> bool result;
> result = g1->contains(g2);
> if (result)
> return 1;
> else
> return 0;
> catch (...)
> return 2;
> The postgis_wrapper.cpp would be very simple:
> char relate(Geometry *g1, Geometry *g2)
> return GEOSrelateContains(g1,g2);
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
