[geos-devel] Re: [postgis-users] Call for Debuggers
Paul Ramsey
pramsey at refractions.net
Wed Apr 16 00:20:50 EDT 2003
Interesting indeed.
Instant segfault was reported to occur on object creation, which is to
say basically all the time in any test.
The only test you haven't run is in bigtest, the TestListSweep test,
but in any event it looks like the results are QUITE DIFFERENT from
what we had reported on Solaris.
Paul
On Tuesday, April 15, 2003, at 09:15 PM, Carl Anderson wrote:
> Ok in what context does "instant segfault" occur
> I compiled geos on a Solaris 5.7 with gcc3.2.2 using GNU ld
> autoheader-1.6
> automake-1.6 --add-missing --gnu
> autoconf
> configure CXXFLAGS="-g" CFLAGS="-g"
> make
> Notice that I'm disabling the default CXXFLAGS "-g -O2"
> Paul the autogen.sh calls a default aclocal and automake. Many (i
> don't know if all)
> automake ver 1.6 install themselves as automake-1.6 in addition to
> automake.
> (same for aclocal-1.6)
> I have both automake-1.4 and automake-1.6 installed. geos does not
> compile with automake-1.4 so that may be part of the issue.
> then run tests
> source/test/CTS
> ok
> source/test/XMLTester
> ok
> source/test/SimpleWKTTester
> ok
> source/example/CoordinateListsExample
> ok
> source/example/CustomCoordinateListExample
> ok
> Are there other tests to run.
> C.
> postgis-users mailing list
Paul Ramsey
Refractions Research
Email: pramsey at refractions.net
Phone: (250) 885-0632
