[geos-devel] buffer() segfaults
Yury A. Bychkov
me at yury.ca
Fri Aug 1 15:59:49 EDT 2003
Strange, this didn't happen during my tests. I'll check it out and try to fix
it.
Yury
----- Original Message -----
To: "GEOS Development List" <geos-devel at geos.refractions.net>
Sent: Friday, August 01, 2003 11:57 AM
Subject: [geos-devel] buffer() segfaults
> This little program segfaults in the buffer() function:
> #0 0x4009138e in geos::Label::setLocation (this=0x8054610,
> geomIndex=1076957745, location=1) at ../graph/Label.cpp:94
> #1 0x4009082c in geos::GeometryGraph::insertPoint (this=0x8054588,
> argIndex=1076957745, coord=@0x8054a60, onLocation=1)
> at ../graph/GeometryGraph.cpp:285
> #2 0x4009052c in geos::GeometryGraph::addEdge (this=0x8054588, e=0x8054478)
> at ../graph/GeometryGraph.cpp:231
> #3 0x400b22ed in geos::BufferOp::nodeEdges (this=0x80535f8,
> edges=0x8053be0)
> at ../operation/buffer/BufferOp.cpp:82
> #4 0x400b217a in geos::BufferOp::computeBuffer (this=0x80535f8,
> distance=10,
> quadrantSegments=6) at ../operation/buffer/BufferOp.cpp:57
> #5 0x400b20c4 in geos::BufferOp::getResultGeometry (this=0x80535f8,
> distance=10) at ../operation/buffer/BufferOp.cpp:45
> #6 0x400b1d24 in geos::BufferOp::bufferOp (g=0x804de40, distance=10)
> #7 0x4006f513 in geos::Geometry::buffer (this=0x804de40, distance=10)
> at Geometry.cpp:283
> #8 0x08049e82 in main (argc=1, argv=0xbffff754) at test.cpp:30
> #9 0x4018e280 in __libc_start_main () from /lib/libc.so.6
> It throws an ABORT if you buffer(1.0).
> #include "io.h"
> //g++ -g test.cpp -I/usr/local/include/geos -lgeos ; ./a.out
> using namespace geos;
> int main(int argc, char** argv)
> try {
> WKTReader *r = new WKTReader();
> Geometry *g1,*g2, *g3;
> g1 =r->read("POLYGON((0 0, 10 0, 10 10, 0 10, 0 0))");
> g2 =r->read("POLYGON((5 5, 15 5, 15 7, 5 7, 5 5))");
> cout << "g1 is valid:" << g1->isValid()<< endl;
> cout << "g2 is valid:" << g2->isValid()<< endl<< endl;
> //g3 = g1->intersection(g2);
> //cout <<"g1->intersection(g2)::" << g3->toText()<< endl;
> g3 = g1->buffer(10.0);
> cout << "g1->buffer(10.0)::" << g3->toText() << endl;
> catch (char *message)
> cout << message << endl;
> catch (...)
> cout << "unknown error occured"<< endl;
> return 0;
> geos-devel mailing list
> http://geos.refractions.net/mailman/listinfo/geos-devel
