[geos-devel] Is it possible to build currentCVSversionofgeosbyMinGW
Hisaji Ono hi_ono2001 at ybb.ne.jp
Thu Aug 21 18:14:54 EDT 2003
Many thanks for you quick & kind responses, Mr. Vine.
> I suggest that you will probably have better luck using MSys
> as trying to duplicate my build environment requires a fairly
> complete understanding of how gcc finds the files that it uses
> and setting up your system accordingly
I upadated latest MingW and succeeded to built Geos-CVS.
Regards.
