[geos-devel] GEOS Make error
Paul Ramsey
pramsey at refractions.net
Thu Aug 28 01:31:41 EDT 2003
On RedHat 7.3, compile and tests work fine.
I download the cvs snap, run ./configure ; make, and all is happy.
P
On Wednesday, August 27, 2003, at 07:52 AM, Düster Horst wrote:
> My last attempt to compile geos stopped after a time of compilation
> (10'')
> with the attached error message.
> All files with the extension .lo exists but not in the demanded
> directories.
> The files are located at the directory geos/source/geom
> My System
> RedHat 7.2
> GEOS-20030827
> What I have to do??
> Horst
> gcc: ../algorithm/CentroidArea.lo: No such file or directory
> gcc: ../algorithm/CentroidLine.lo: No such file or directory
> gcc: ../algorithm/CentroidPoint.lo: No such file or directory
> gcc: ../algorithm/CGAlgorithms.lo: No such file or directory
> gcc: ../algorithm/ConvexHull.lo: No such file or directory
> gcc: ../algorithm/HCoordinate.lo: No such file or directory
> gcc: ../algorithm/InteriorPointArea.lo: No such file or directory
> gcc: ../algorithm/InteriorPointLine.lo: No such file or directory
> gcc: ../algorithm/InteriorPointPoint.lo: No such file or directory
> gcc: ../algorithm/LineIntersector.lo: No such file or directory
> gcc: ../algorithm/MCPointInRing.lo: No such file or directory
> gcc: ../algorithm/NonRobustCGAlgorithms.lo: No such file or directory
> gcc: ../algorithm/NonRobustLineIntersector.lo: No such file or
> directory
> gcc: ../algorithm/NotRepresentableException.lo: No such file or
> directory
> gcc: ../algorithm/PointLocator.lo: No such file or directory
> gcc: ../algorithm/RobustCGAlgorithms.lo: No such file or directory
> gcc: ../algorithm/RobustDeterminant.lo: No such file or directory
> gcc: ../algorithm/RobustLineIntersector.lo: No such file or directory
> gcc: ../algorithm/SimplePointInAreaLocator.lo: No such file or
> directory
> gcc: ../algorithm/SimplePointInRing.lo: No such file or directory
> gcc: ../algorithm/SIRtreePointInRing.lo: No such file or directory
> gcc: ../graph/Depth.lo: No such file or directory
> gcc: ../graph/DirectedEdge.lo: No such file or directory
> gcc: ../graph/DirectedEdgeStar.lo: No such file or directory
> gcc: ../graph/Edge.lo: No such file or directory
> gcc: ../graph/EdgeEnd.lo: No such file or directory
> gcc: ../graph/EdgeEndStar.lo: No such file or directory
> gcc: ../graph/EdgeIntersection.lo: No such file or directory
> gcc: ../graph/EdgeIntersectionList.lo: No such file or directory
> gcc: ../graph/EdgeList.lo: No such file or directory
> gcc: ../graph/EdgeRing.lo: No such file or directory
> gcc: ../graph/GeometryGraph.lo: No such file or directory
> gcc: ../graph/GraphComponent.lo: No such file or directory
> gcc: ../graph/Label.lo: No such file or directory
> gcc: ../graph/Node.lo: No such file or directory
> gcc: ../graph/NodeFactory.lo: No such file or directory
> gcc: ../graph/NodeMap.lo: No such file or directory
> gcc: ../graph/PlanarGraph.lo: No such file or directory
> gcc: ../graph/Position.lo: No such file or directory
> gcc: ../graph/Quadrant.lo: No such file or directory
> gcc: ../graph/TopologyLocation.lo: No such file or directory
> gcc: ../graph/index/MonotoneChain.lo: No such file or directory
> gcc: ../graph/index/MonotoneChainEdge.lo: No such file or directory
> gcc: ../graph/index/MonotoneChainIndexer.lo: No such file or directory
> gcc: ../graph/index/SegmentIntersector.lo: No such file or directory
> gcc: ../graph/index/SimpleEdgeSetIntersector.lo: No such file or
> directory
> gcc: ../graph/index/SimpleMCSweepLineIntersector.lo: No such file or
> directory
> gcc: ../graph/index/SimpleSweepLineIntersector.lo: No such file or
> directory
> gcc: ../graph/index/SweepLineEvent.lo: No such file or directory
> gcc: ../graph/index/SweepLineSegment.lo: No such file or directory
> gcc: ../index/bintree/Bintree.lo: No such file or directory
> gcc: ../index/bintree/BinTreeInterval.lo: No such file or directory
> gcc: ../index/bintree/BinTreeNode.lo: No such file or directory
> gcc: ../index/bintree/Key.lo: No such file or directory
> gcc: ../index/bintree/NodeBase.lo: No such file or directory
> gcc: ../index/bintree/Root.lo: No such file or directory
> gcc: ../index/chain/indexMonotoneChain.lo: No such file or directory
> gcc: ../index/chain/MonotoneChainBuilder.lo: No such file or directory
> gcc: ../index/chain/MonotoneChainOverlapAction.lo: No such file or
> directory
> gcc: ../index/chain/MonotoneChainSelectAction.lo: No such file or
> directory
> gcc: ../index/quadtree/DoubleBits.lo: No such file or directory
> gcc: ../index/quadtree/IntervalSize.lo: No such file or directory
> gcc: ../index/quadtree/Quadtree.lo: No such file or directory
> gcc: ../index/quadtree/QuadTreeKey.lo: No such file or directory
> gcc: ../index/quadtree/QuadTreeNode.lo: No such file or directory
> gcc: ../index/quadtree/QuadTreeNodeBase.lo: No such file or directory
> gcc: ../index/quadtree/QuadTreeRoot.lo: No such file or directory
> gcc: ../index/strtree/AbstractNode.lo: No such file or directory
> gcc: ../index/strtree/AbstractSTRtree.lo: No such file or directory
> gcc: ../index/strtree/Interval.lo: No such file or directory
> gcc: ../index/strtree/ItemBoundable.lo: No such file or directory
> gcc: ../index/strtree/SIRtree.lo: No such file or directory
> gcc: ../index/strtree/STRtree.lo: No such file or directory
> gcc: ../index/sweepline/indexSweepLineEvent.lo: No such file or
> directory
> gcc: ../index/sweepline/SweepLineIndex.lo: No such file or directory
> gcc: ../index/sweepline/SweepLineInterval.lo: No such file or directory
> gcc: ../io/ParseException.lo: No such file or directory
> gcc: ../io/StringTokenizer.lo: No such file or directory
> gcc: ../io/WKTReader.lo: No such file or directory
> gcc: ../io/WKTWriter.lo: No such file or directory
> gcc: ../io/Writer.lo: No such file or directory
> gcc: ../io/markup/MarkupSTL.lo: No such file or directory
> gcc: ../operation/GeometryGraphOperation.lo: No such file or directory
> gcc: ../operation/IsSimpleOp.lo: No such file or directory
> gcc: ../operation/buffer/BufferEdgeBuilder.lo: No such file or
> directory
> gcc: ../operation/buffer/BufferLineBuilder.lo: No such file or
> directory
> gcc: ../operation/buffer/BufferOp.lo: No such file or directory
> gcc: ../operation/buffer/BufferSubgraph.lo: No such file or directory
> gcc: ../operation/buffer/LoopFilter.lo: No such file or directory
> gcc: ../operation/buffer/RightmostEdgeFinder.lo: No such file or
> directory
> gcc: ../operation/distance/ConnectedElementPointFilter.lo: No such
> file or
> directory
> gcc: ../operation/distance/DistanceOp.lo: No such file or directory
> gcc: ../operation/distance/LineExtracterFilter.lo: No such file or
> directory
> gcc: ../operation/distance/PointExtracterFilter.lo: No such file or
> directory
> gcc: ../operation/distance/PolygonExtracterFilter.lo: No such file or
> directory
> gcc: ../operation/overlay/EdgeSetNoder.lo: No such file or directory
> gcc: ../operation/overlay/LineBuilder.lo: No such file or directory
> gcc: ../operation/overlay/MaximalEdgeRing.lo: No such file or directory
> gcc: ../operation/overlay/MinimalEdgeRing.lo: No such file or directory
> gcc: ../operation/overlay/OverlayNodeFactory.lo: No such file or
> directory
> gcc: ../operation/overlay/OverlayOp.lo: No such file or directory
> gcc: ../operation/overlay/PointBuilder.lo: No such file or directory
> gcc: ../operation/overlay/PolygonBuilder.lo: No such file or directory
> gcc: ../operation/relate/EdgeEndBuilder.lo: No such file or directory
> gcc: ../operation/relate/EdgeEndBundle.lo: No such file or directory
> gcc: ../operation/relate/EdgeEndBundleStar.lo: No such file or
> directory
> gcc: ../operation/relate/RelateComputer.lo: No such file or directory
> gcc: ../operation/relate/RelateNode.lo: No such file or directory
> gcc: ../operation/relate/RelateNodeFactory.lo: No such file or
> directory
> gcc: ../operation/relate/RelateNodeGraph.lo: No such file or directory
> gcc: ../operation/relate/RelateOp.lo: No such file or directory
> gcc: ../operation/valid/ConnectedInteriorTester.lo: No such file or
> directory
> gcc: ../operation/valid/ConsistentAreaTester.lo: No such file or
> directory
> gcc: ../operation/valid/IsValidOp.lo: No such file or directory
> gcc: ../operation/valid/QuadtreeNestedRingTester.lo: No such file or
> directory
> gcc: ../operation/valid/RepeatedPointTester.lo: No such file or
> directory
> gcc: ../operation/valid/SimpleNestedRingTester.lo: No such file or
> directory
> gcc: ../operation/valid/SweeplineNestedRingTester.lo: No such file or
> directory
> gcc: ../operation/valid/TopologyValidationError.lo: No such file or
> directory
> gcc: ../util/Assert.lo: No such file or directory
> gcc: ../util/AssertionFailedException.lo: No such file or directory
> gcc: ../util/CoordinateArrayFiter.lo: No such file or directory
> gcc: ../util/GEOSException.lo: No such file or directory
> gcc: ../util/IllegalArgumentException.lo: No such file or directory
> gcc: ../util/UniqueCoordinateArrayFilter.lo: No such file or directory
> gcc: ../util/UnsupportedOperationException.lo: No such file or
> directory
> make[2]: *** [libgeos.la] error 1
> make[2]: Verlassen des Verzeichnisses Verzeichnis
> »/usr/local/src/sogis/geos-20030827/source/geom«
> make[1]: *** [all-recursive] error 1
> make[1]: Verlassen des Verzeichnisses Verzeichnis
> »/usr/local/src/sogis/geos-20030827/source«
> make: *** [all-recursive] error 1
> Mit freundlichen Grüssen
> Dr. Horst Düster
> Leiter
> Abteilung SO!GIS Koordination
> Rötihof
> 4500 Solothurn
> Tel.: 032 627 25 32
> Fax: 032 627 22 14
> horst.duester at bd.so.ch <mailto:horst.duester at bd.so.ch>
> www.sogis.so.ch <http://www.sogis.so.ch/>
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
Paul Ramsey
Refractions Research
Email: pramsey at refractions.net
Phone: (250) 885-0632
