[geos-devel] make-error
Jean-Pierre Praz
jpraz at dplanet.ch
Wed Dec 10 17:57:13 EST 2003
Steffen,
thanks! i needed to install the gcc-g++ package and now it compiles well. i
think the check for gcc-g++ is already included in the configure-process.
the output of configure (when gcc-g++ wasn't installed) was:
------ checking whether we are using the GNU C compiler ................. yes
----- checking whether we are using the GNU C++ compiler ................. no
but i didn't know what to do at this point.
jean-pierre
At 20:10 10.12.2003 +0200, you wrote:
>Jean-Pierre,
>>CC: installation problem, cannot exec `cc1plus': No such file or directory
>Could you make sure that you have the Cygwin gcc-g++ package installed?
>I think it would be a good idea to have configure explicitly check for g++
>- but I don't have the necessary automake/autoconf experience to add this
>check.
>Steffen
