[geos-devel] RE: CoordinateListFactory
Paul Ramsey pramsey at refractions.net
Fri Feb 7 11:31:25 EST 2003
There is also a resurgance in the use of ->at() in the newly committed
code which should probably be removed.
That stl error w/ GNU is a little worrisome.
P.
Norman Vine wrote:
> gcc 3.2 has a problem in geometry.cpp
> Coordinate& Geometry::minCoordinate(CoordinateList* coordinates){
>  vector<Coordinate> v(*(coordinates->toVector()));
> < line 80 > sort(v.begin(),v.end(),lessThen);
>  return v.front();
> < comment >
> If this is called a lot it would probably be faster to have a
> CoordinateList::minCoordinate() method so that the
> vector copy and sort need not be performed
> < / comment >
> It is nice to see some action in the CVS
> Cheers
> Norman
> g++ -DHAVE_CONFIG_H -I. -I../../../source/geom -I../../source/headers -I../../../source/headers -DGEOS_VERSION=\"1\" -O2 -MT
> Geometry.lo -MD -MP -MF .deps/Geometry.Tpo -c ../../../source/geom/Geometry.cpp  -DPIC -DPIC -o Geometry.o
> /usr/include/c++/3.2/bits/stl_algo.h: In function `const _Tp&
>    std::__median(const _Tp&, const _Tp&, const _Tp&, _Compare) [with _Tp =
>    Coordinate, _Compare = bool (*)(Coordinate&, Coordinate&)]':
> /usr/include/c++/3.2/bits/stl_algo.h:2147:   instantiated from `void std::__introsort_loop(_RandomAccessIter, _RandomAccessIter,
> _Size, _Compare) [with _RandomAccessIter = __gnu_cxx::__normal_iterator<Coordinate*, std::vector<Coordinate,
> std::allocator<Coordinate> > >, _Size = int, _Compare = bool (*)(Coordinate&, Coordinate&)]'
> /usr/include/c++/3.2/bits/stl_algo.h:2209:   instantiated from `void std::sort(_RandomAccessIter, _RandomAccessIter, _Compare) [with
> _RandomAccessIter = __gnu_cxx::__normal_iterator<Coordinate*, std::vector<Coordinate, std::allocator<Coordinate> > >, _Compare =
> ../../../source/geom/Geometry.cpp:80:   instantiated from here
> /usr/include/c++/3.2/bits/stl_algo.h:124: could not convert `__a' to `
>    Coordinate&'
> /usr/include/c++/3.2/bits/stl_algo.h:125: could not convert `__b' to `
>    Coordinate&'
> /usr/include/c++/3.2/bits/stl_algo.h:127: could not convert `__a' to `
>    Coordinate&'
> /usr/include/c++/3.2/bits/stl_algo.h:131: could not convert `__a' to `
>    Coordinate&'
> /usr/include/c++/3.2/bits/stl_algo.h:133: could not convert `__b' to `
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
