[geos-devel] Include Refactoring
Paul Ramsey
pramsey at refractions.net
Wed Feb 12 12:37:26 EST 2003
The headers needed by external programs in order to call geos objects
and know what functions are inside the library. The headers which a
'make install' would place in the system include directory for use by
other software. Right now, 'make install' on geos installs the
following in /usr/local/include:
-rw-r--r-- 1 root root 26474 Feb 12 09:22 geom.h
-rw-r--r-- 1 root root 6912 Feb 12 09:22 geosAlgorithm.h
-rw-r--r-- 1 root root 17260 Feb 12 09:22 graph.h
-rw-r--r-- 1 root root 4987 Feb 12 09:22 graphindex.h
-rw-r--r-- 1 root root 4301 Feb 12 09:22 io.h
-rw-r--r-- 1 root root 1630 Feb 12 09:22 operation.h
-rw-r--r-- 1 root root 3624 Feb 12 09:22 opRelate.h
-rw-r--r-- 1 root root 229 Feb 12 09:22 platform.h
-rw-r--r-- 1 root root 936 Feb 12 09:22 util.h
It also installs the libraries in /usr/local/lib
-rw-r--r-- 1 root root 15002262 Feb 12 09:22 libgeos.a
-rwxr-xr-x 1 root root 705 Feb 12 09:22 libgeos.la*
lrwxrwxrwx 1 root root 16 Feb 12 09:22 libgeos.so ->
libgeos.so.1.0.0*
lrwxrwxrwx 1 root root 16 Feb 12 09:22 libgeos.so.1 ->
libgeos.so.1.0.0*
-rwxr-xr-x 1 root root 3624493 Feb 12 09:22 libgeos.so.1.0.0*
Martin Davis wrote:
> Paul, can you give an example of what you mean? It's not clear what you mean by "API headers".
> Martin Davis, Senior Technical Specialist
> Vivid Solutions Inc.
> Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
> Phone: (250) 385 6040 Fax: (250) 385 6046
> EMail: mbdavis at vividsolutions.com Web: www.vividsolutions.com
>>-----Original Message-----
>>From: Paul Ramsey [mailto:pramsey at refractions.net]
>>Sent: Wednesday, February 12, 2003 9:25 AM
>>To: GEOS Development List
>>Subject: [geos-devel] Include Refactoring
>>For the API headers, it would probably be wise to do a mass
>>renaming, so
>>that all the headers which get installed have a geos_ prefix.
>>That way
>>we can lower our odds of name collision on systems we install on.
>>(Martin, insert comment about beauty of Java packaging here. :)
>>I was just looking at what is required to do an alpha release of geos
>>(to go alongside a pre-release of geos-enabled postgis) and having
>>nicely named includes would be good.
>>Thoughts?
>>P.
>> __
>> | Paul Ramsey
>> | Refractions Research
>> | Email: pramsey at refractions.net
>> | Phone: (250) 885-0632
>> \_
>>_______________________________________________
>>geos-devel mailing list
>>geos-devel at geos.refractions.net
>>http://geos.refractions.net/mailman/listinfo/geos-devel
__
| Paul Ramsey
\_
