Martin Davis writes: > > Not bad, not bad.... > > Using JTS 1.2, I get the following timing: (Pentium 1.1 GHz / > Win2K / Sun Java 1.4) > > n Pts: 1024000 > Executed in 20.627 s Not bad, not bad ... FWIW - Cygwin gcc 3.2.2 PIII 733 and a few local 'tweaks' n Pts: 1024000 Executed in 15222 ms. Cheers Norman
