[geos-devel] Dealing with GEOS exceptions
David Blasby
dblasby at refractions.net
Mon May 12 16:37:47 EDT 2003
Just before I left for holidays (I returned today), I tried to create a
wrapper around the GEOS functions so that proper exception handling
would occur.
Unfortunately, it failed. The code is in CVS (i think) -
headers/GeometryCAPI.h and util/GeometryCAPI.cpp. I've include some of
it below so you could see what its doing.
Unfortunately, this wrappers did not work. It works in situations like
this where there is no stack-unrolling-exception handling:
// this function always returns 0
int f()
try
throw "an exception occurred";
// never get here
catch (...)
return 0;
return 1; // never get here either
If you try something like this, where there is a stack-unrolling, it
doesnt work:
int g()
throw "an exception occured";
// never get here
// this function will cause a SIGABORT and terminate.
int f()
try
g(); // g() throws an exception
// never get here
catch (...)
return 0;
I'm out of simple solutions now. The only thing I can think of trying
is using the most
up-to-date gcc/g++ and libc/libc++. Unfortunately, this isnt a very
nice option (I'm not
even sure if it would work) because it would force everyone to use these
programs
and libraries - that could be difficult.
Another solution would be to link postgresql with libc++ instead of
libc. Unfortunately, this would force people to have a non-standard
postgresql installation,
something I dont think is an option.
If anyone has *ANY* suggestions or thoughts, please let me know.
// This is just a simple wrapper for basic geometry functions. See the
// Geometry type documentation for exact definition for these functions.
// Because some C programs might have trouble calling C++ (most notably
// postgresql, PERL, PYTHON, JAVA, etc...) when there is triple indirect
// access (postgresql -> libpostgis -> libgeos).
// A more technical discussion of this bug is at
http://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=37
933
// Basically, if libc is loaded before libc++ exception handling might
be comprimised.
// This class solves this problem. It basically wraps try..catch blocks
around the obvious
// calls to GEOS functions.
// For functions that return a boolean (ie. g->isValid() or
g1->disjoint(g2)), these functions
// return:
// 0 -- FALSE
// 1 -- TRUE
// 2 -- ERROR OCCURRED * usually due to invalid geometry or
robustness failure
// For functions that return objects (ie. g->asText(), g1->relate(g2)),
these functions
// return either the appropriate object or NULL if an error occurred.
// Usage:
// if you want to do
// g1->relate(g2);
// then you do:
// GeometryCAPI *capi = new GeometryCAPI();
// char result = capi->relate(g1,g2);
// if (result ==2)
// //handle error
// GeometryCAPI also handles geometry construction. When you create a
GeometryCAPI,
// you also make a new GeometryFactory (see GeometryCAPI constructors
vis-a-vis GeometryFactory).
Geometry *GeometryCAPI::createPoint(Coordinate *c)
try{
Geometry *result =factory->createPoint(*c);
return result;
catch (...)
return NULL;
char GeometryCAPI::touches(Geometry *g1, Geometry*g2)
try {
bool result;
result = g1->touches(g2);
if (result)
return 1;
else
return 0;
catch (...)
return 2;
