[geos-devel] Exception Issues
David Blasby dblasby at refractions.net
Tue May 27 12:09:31 EDT 2003
I'm not 100% sure of the exact nature of the problem, but
http://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=37933
has some more technical details.
To summarize the article, the problem is not with the C++ exception
mechanism; it works just fine if you link your program to libc++.  The
problem is when you link the main program to libc (which doesnt
understand c++ exception handling).  When the c++ code throws and
exception that has to unwind the stack (ie. leave the function that
threw it) a problem occurs because the default unwind mechinism in
libc is SIGABRT (terminate the program).
If the same program were linked to libc++, then the default unwind
mechanism would handle the exception properly.
Anyways, read the article and see if my summary is accurate.
This isnt an issue in most program - a C program that is using libgeos
would link it in at compile time.  This will cause it to link to libc++
not libc.
In postgresql, it is compiled and linked to libc.  When it want to load
in postgis, it just openes up the .so at runtime (not compile time).
dave
